PAT Testing: Cordless Kettles - Electrician Talk - Professional Electrical Contractors Forum
Old 02-16-2012, 02:50 PM   #1
Default PAT Testing: Cordless Kettles
Hi,
I wonder if anyone can help with the following query.
I was testing a cordless plastic body electric kettle for earth continuity and measured 0.5 Ohms between the kettle element and and earth pin on the plug. I was a bit suspisous (as I expected a lower reading, i.e. a pass reading) as the kettle seemed fairly new. The resistance between the base unit earth connector and earth pin on the plug was 0.03 Ohms.
I made the same measurement on a brand new plastic body cordless kettle which I had and obtained 0.5 Ohms between plug earth pin and kettle element? I checked the test meter on a checkbox and there were no problems with accuracy for earth continuity measurements. The meter was calibrated in November 2011 and was purchased in 2011.
The test equipment is a battery powered hand held meter and uses 200mA for the earth continuity test. Test on lots of other class 1 appliances (i.e. portable, movable and stationary etc) are fine. The resistance of the meter test lead is 0.02 Ohms.
I am aware the scaling could affect the reading but the brand new kettle
but wondering why I am getting 0.5 Ohms on a brand new plastic body cordless kettle?
Regards
Kev
KevA is offline   Reply With Quote
Old 04-25-2012, 06:45 PM   #2
Rewards Points: 25
Does seem high. Do you mean a detachable kettle i.e. the kettle comes away from the base unit?
Scaling can be an be a issue. I take it you are keeping the element covered with water when your putting a testing through it? Really not good for the element if your not.
Adjust the clamp on the element again a try an alternative spot for a better connection. If you still get a high reading then its failed - simples.
Remember - just because its new, doesn't mean its safe. You only need to look at the queue's in Argos to see people taking back faulty electrical goods.
WarrenG is offline   Reply With Quote
The Following User Says Thank You to WarrenG For This Useful Post:
76nemo (04-25-2012)
greenlee cordless donselec Residential Electrical Forum 8 08-29-2011 09:25 PM
cordless sets bduerler Tools, Equipment and New Products 22 01-10-2010 10:16 PM
Poll - Cordless - 14.4V vs. 18V - now 21 (or 24V) ? BP_redbear Tools, Equipment and New Products 17 10-02-2008 10:05 PM
For Sale: Makita cordless MechanicalDVR Electrician Swap 0 08-18-2008 10:12 AM
Cordless Power... twintask Tools, Equipment and New Products 9 05-03-2008 05:55 PM
