What Is the Difference Between a Breaker and a Fuse? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree18Likes
  • 3 Post By Wirenuting
  • 2 Post By CWL
  • 3 Post By gpop
  • 1 Post By canbug
  • 1 Post By Bird dog
  • 1 Post By just the cowboy
  • 3 Post By 99cents
  • 1 Post By Wirenuting
  • 1 Post By CWL
  • 1 Post By paulengr
  • 1 Post By MechanicalDVR
Old 07-23-2020, 09:19 AM   #1
Default What Is the Difference Between a Breaker and a Fuse?
Hi Guys,
What Is the Difference Between a Breaker and a Fuse? because I'm not entirely sure and I've been asked this question but I couldn't answer in detail.
Paul123 is offline   Reply With Quote
Old 07-23-2020, 09:21 AM   #2
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,804
Originally Posted by Paul123 View Post
Hi Guys,
One is broke and the other fused together.
Welcome to ET
Please take the time to finish filling out your profile.
Old 07-23-2020, 09:45 AM   #3
CWL
Rewards Points: 62
Sometimes, albeit rarely, a fuse will have enough pixie dust left inside of it to ohm good with a DMM, but not carry current to the device.
Wirenuting and tmessner like this.
CWL is offline   Reply With Quote
Old 07-23-2020, 10:10 AM   #4
Rewards Points: 2,974
Hi Guys,
Fuse is one time. Breaker is reset-able and with out knowing your electrical background its not worth getting any deeper into details you may or may not understand.
Old 07-23-2020, 10:19 AM   #5
Wirenuting's Avatar
Even more so on replaceable links were they reuse the silica.
Old 07-23-2020, 11:00 AM   #6
canbug's Avatar
Rewards Points: 2,210
More often then not, a fuse will open quicker but breaker but technology has caught up and some are now faster than a fuses.
Tim
My Avatar picture is a cross-connect cabinet for airfield lighting regulators
Old 07-23-2020, 12:00 PM   #7
Bird dog's Avatar
Rewards Points: 770
Tim
HACR ckt breakers were a way for breaker companies to compete with fuse companies.
Old 07-23-2020, 12:01 PM   #8
Wardenclyffe's Avatar
Rewards Points: 804
Close a Breaker,
Open a Valve,...
Wardenclyffe is offline   Reply With Quote
Old 07-23-2020, 01:38 PM   #9
just the cowboy's Avatar
Rewards Points: 804
Originally Posted by Wardenclyffe View Post
Close a Breaker,
Open a Valve,...
Then what The panel floods with water and goes boom
"DID THIS FIX IT??"
Old 07-23-2020, 01:51 PM   #10
Rewards Points: 2,402
Hi Guys,
A breaker and a fuse are both an overcurrent protective device. As mentioned fuses would tend to open the circuit faster than breakers thus they were spec'ed for jobs where the fast opening of a circuit was critical. They do basically the same thing-- they protect the circuit from over current, short circuit and ground fault.
I can't help it if I'm lucky
Old 07-23-2020, 01:55 PM   #11
Rewards Points: 3,311
A breaker is an on/off switch that sometimes opens the circuit before the explosion.
JoeSparky, Wirenuting and tmessner like this.
Old 07-23-2020, 03:14 PM   #12
Wirenuting's Avatar
Don’t tell our safety manager that. He KNOWS that breakers are not switches.
Switches are switches...
He also turns the main off at home to change bulbs, just in case.
99cents likes this.
Old 07-23-2020, 04:02 PM   #13
CWL
Rewards Points: 62
Sounds kind of like a safety guy at a place I used to work at. Flagged me down because there was a puddle of water NEXT TO the end of an extension cord. I walked over to the outlet it was plugged into 15 feet away and unplugged it. He threatened to write me up for a lockout tagout violation. He got fired about a year later and I when I left more than a year after that it was on my own terms with well wishes.
Wirenuting likes this.
Old 07-23-2020, 05:39 PM   #14
Chief Flunky
Rewards Points: 376
Tim
Not anything more: semiconductor fuses trip in 1-2 ms. The only breakers that fast are solid state ones but those are really more of a soft start than a breaker. Fuses also have nearly unlimited interrupting current but not breakers. To get above 65 kA “breakers” have fuses built in. Standard fuses trip in 4 ms while the fastest small breakers trip in 16-20 ms.
Old 07-23-2020, 05:44 PM   #15
Chief Flunky
Rewards Points: 376
Large distribution and transmission level breakers are called switches. At medium voltage electronic switches (SCRs, GCTs, HVIGBTs) are called valves.
Old 07-23-2020, 08:29 PM   #16
Rewards Points: 24,438
Tim
If sensitive equipment is involved a fuse is often the best way to go.
Old 07-23-2020, 08:50 PM   #17
Seen it!
Old 07-23-2020, 08:52 PM   #18
"Sometimes" being the key operative phrase!
FPE and Zinsco the opposite more often than not!
99cents likes this.
Old 07-29-2020, 11:46 AM   #19
Rewards Points: 18
How is it that there are 2 pages of responses to this when we haven't even solved the notched stud problem? 🤣🤣🤣
mofos be cray is offline   Reply With Quote
