12VDC Power Supply and Diode - Electrician Talk - Professional Electrical Contractors Forum
Like Tree16Likes
Old 03-18-2019, 01:12 PM   #1
Rewards Points: 2,472
Default 12VDC Power Supply and Diode
I have to supply power for some very expensive process cameras. I need a top quality regulated 12VDC DIN rail mount power supply. Made in USA if at all possible. I'd prefer something I can set up in parallel for redundancy but that's not really a must.
Can anyone recommend a brand?
These cameras have warnings about reverse polarity in the documentation. I am worried someone (including me) will accidentally cross wires and fry a camera, people don't agree about the color code for 12VDC like they do with line voltages. Is there maybe a good brand terminal block with a diode in it?
This too shall pass.
Old 03-18-2019, 01:24 PM   #2
Peewee0413's Avatar
Rewards Points: 254
I think I've seen once that Wago makes terminal blocks with diodes. I have a machine that uses Wago I/O, and have no complaints.
The Following User Says Thank You to Peewee0413 For This Useful Post:
splatz (03-18-2019)
Old 03-18-2019, 05:13 PM   #3
CoolWill's Avatar
Rewards Points: 644
Holy cripes... I just did something similar not too long ago. I used an Eaton PSG480R24RM
power supply and the Altec 5702.2 diode module. The diodes are rated up to 1 amp, but you could parallel a few because there's 8 per module. I like that power supply because it's adjustable. I bumped the output voltage up to compensate for the diode drop.
splatz (03-19-2019)
Old 03-19-2019, 03:51 PM   #4
gnuuser's Avatar
Rewards Points: 1,538
this may suit your needs
https://www.amazon.com/SDR-120-12-DI...SIN=B005T8XR08
The Following User Says Thank You to gnuuser For This Useful Post:
splatz (03-19-2019)
Old 03-19-2019, 03:57 PM   #5
Going_Commando's Avatar
Rewards Points: 1,620
People use other than black for - and red for + on 12VDC?
Old 03-19-2019, 08:08 PM   #6
I guess it's supposed to be red+ and white- if negative is grounded, white+ and black- if positive is grounded, red+ and black- if ungrounded. This is more nuance than some can abide and also some will just think it doesn't matter, like the speakers in their basement, and do whatever.
Old 03-19-2019, 08:55 PM   #7
Southeast Power's Avatar
Rewards Points: 9,086
We used these a few times, I'm sure they were 12vdc.
https://www.plchardware.com/Products...0aAgtLEALw_wcB
splatz (03-19-2019)
Old 03-19-2019, 09:42 PM   #8
Rewards Points: 1,684
https://www.phoenixcontact.com/onlin...4-1dfd436785c3
Phoenix has what you need. You can also get a redundancy module to tie both P/S together. They are not cheap but very reliable.
I’m not sure about the diodes or why you would need them.
The Following User Says Thank You to bill39 For This Useful Post:
splatz (03-20-2019)
Old 03-20-2019, 05:50 AM   #9
Iím not sure about the diodes or why you would need them.
I bought the Phoenix last time I shopped. I am not sure where they were made, might have been somewhere you wouldn't guess, eastern European country? But Phoenix is a very good company to deal with as far as I can tell.
The diodes are to kill the circuit if someone crosses wires and reverses polarity.
bill39 (03-20-2019)
Old 03-20-2019, 05:53 AM   #10
Originally Posted by gnuuser View Post
I see the Meanwell brand comes up a lot when internet shopping - have you had good luck with them?
The AB are pricey but nobody can say you cut corners if you buy them ... are they made in USA?
Old 03-20-2019, 05:59 AM   #11
I found these,
3A
made in Italy
I have to measure current - I could see it going higher but 3A is probably going to do it.
https://www.asi-ez.com/pix/doc/sf901....pdf#view=fitv
I did not know of this diode drop you speak of. I like the idea because I could probably compensate for voltage drop so the voltage is right on the money at the device.
Old 03-20-2019, 06:21 AM   #12
Service Call's Avatar
Rewards Points: 36
Iíve used Meanwell power supplies several times for DC and have not had a problem.
Service Call is online now   Reply With Quote
The Following User Says Thank You to Service Call For This Useful Post:
splatz (03-20-2019)
Old 03-20-2019, 08:24 AM   #13
CoolWill's Avatar
Rewards Points: 644
Diodes (and similar semiconductor devices) have an inherent voltage drop across them no matter what the load is. It's usually between 0.5 and 0.7 volts. Not usually a big deal for high voltage, but needs to be addressed when sensitive electronics operate on low voltage.
splatz (03-20-2019)
Old 03-20-2019, 09:59 AM   #14
Band Member
emtnut's Avatar
Rewards Points: 2,522
We used Xp Power DIN supplies in traffic cabinets.
They performed well, and in some tough environmental conditions. Dusty, and -20˚C to +40˚C
Spec sheet ... https://www.xppower.com/Portals/0/pdfs/SF_DNR05-60.pdf
**edit** adjustable output as well.
I would get a higher rated diode than 3A. If you're pushing close to that range for extended times, you creating a failure point IMO.
That, or use multiple diodes like OneCallWilly said
splatz (03-20-2019)
Old 03-25-2019, 11:51 PM   #15
gnuuser's Avatar
[QUOTE=splatz;5179256]I see the Meanwell brand comes up a lot when internet shopping - have you had good luck with them?
we had some equipment installed at the plant that had them.
never had any issues with them! and they were quite tolerant to power fluctuation as i recall
Old 03-26-2019, 07:14 AM   #16
Unfortunately, yes.
NFPA-79 and I believe UL-508A both require blue for DC circuits. If the negative is grounded then itís white w/blue stripe.
CoolWill likes this.
Old 03-26-2019, 11:49 AM   #17
So after thinking a little more about the adjustable power supplies.
I'll have to install a separate power supply, diode, and pair of wires for each device. That way I can adjust the voltage on each power supply to accommodate for voltage drop in the diode and the wire.
Any ideas for this: I don't want to make the adjustment with the expensive device, I want to connect the expensive device once the power supply is adjusted. To do this I will need some dummy load to match the device. So the dummy load will have to be something I can adjust so it matches the actual device. I haven't yet measured but based on the factory 12V 2.5A power supply, the device will draw less than 30W.
Old 03-26-2019, 07:45 PM   #18
Rewards Points: 518
The only DIN rail mount industrial power supply I know of that is still made in the USA is Acopian.
https://www.acopian.com/DINrailmount...Power-Supplies
Small company, not well known, not the low price leaders but the products are decent.
Pretty much everything else comes from the same 5 Asian suppliers; Puls, Meanwell, Chint, Delta and Idec, but most of the other brands that you see (such as Phoenix, A-B, Siemens, Power One, Eaton, Sola etc. etc.) are almost all just brand-label deals with one of these 5 Asian suppliers. Meanwell is a latecomer to the party and commands attention because they are cheap, I have had many people complain about them. They (and Chint, Delta and Idec) get cheaper by cutting corners on the magnetics inside of the PSU, so they put in a "fold-back" circuit to take it off line if there is a surge in demand on the output side. That pisses people off when it happens. Puls (who makes the Allen Bradley and Siemens products) don't do that, they have surge capacity built-in. Still made in Asia though, even though Puls is a German company.
splatz and CoolWill like this.
splatz (03-26-2019)
Old 03-27-2019, 02:35 AM   #19
ppsh's Avatar
Rewards Points: 166
I believe the Siemens SITOP lineup is Austrian or Romanian made depending on the series.
ppsh is online now   Reply With Quote
The Following User Says Thank You to ppsh For This Useful Post:
splatz (03-27-2019)
Old 03-27-2019, 10:07 AM   #20
CoolWill's Avatar
Rewards Points: 644
Rheostat? Multiple incandescent brake lamps?
splatz (03-27-2019)
