12VDC Power Supply and Diode - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree16Likes
Unread 03-27-2019, 10:32 AM   #21
Rewards Points: 24
Default Sola
Not sure about the made in usa, but we have had great success with 24vdc sola power supplies and ups.
looks like they are part of emerson and appleton.
Florida is offline   Reply With Quote
Unread 03-27-2019, 05:01 PM   #22
Band Member
emtnut's Avatar
Rewards Points: 546
I'll have to install a separate power supply, diode, and pair of wires for each device. That way I can adjust the voltage on each power supply to accommodate for voltage drop in the diode and the wire.
Any ideas for this: I don't want to make the adjustment with the expensive device, I want to connect the expensive device once the power supply is adjusted. To do this I will need some dummy load to match the device. So the dummy load will have to be something I can adjust so it matches the actual device. I haven't yet measured but based on the factory 12V 2.5A power supply, the device will draw less than 30W.
I would look up the specs for the camera, and just do a voltage drop calculation based on the spec amps. Add 0.8V for the diode (the drop is current dependent, but doesn't change much.. from what I've seen). You could look up the curve for your diode if you want thou.
You should be able to calculate within .2V I would think.
Unread 06-11-2019, 01:33 PM   #23
Rewards Points: 3,064
I still haven't finished this project. The Phoenix power supplies are good quality as far as I can tell but a little big, they have other models that would have fit the enclosure better. Adjusting for voltage drop was simple and easy.
I also bought the Phoenix Contact DIN rail diodes and they are good, just as advertised. However, it occurred to me that some cross-ups you'd be safer with the diode closer to the camera. The DIN rail diodes are pretty big and hard to work with in the enclosure by the camera.
I found these beauties which I will be swapping in
http://eco-energy.us/diodes/diodes.html
CoolWill likes this.
Unread 06-11-2019, 04:14 PM   #24
CoolWill's Avatar
Rewards Points: 910
That's cool. They are Schottky diodes too, so the voltage drop across them will be lower than standard diodes.
I'm With Her! Hillary 2016
splatz (06-11-2019)
