Can I mount din rail in a nema 3r weatherproof enclosure? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
  • 2 Post By Peewee0413
  • 3 Post By joebanana
  • 1 Post By B-Nabs
  • 3 Post By Wavelet8
  • 2 Post By Cow
  • 1 Post By JRaef
Old 10-31-2019, 01:39 PM   #1
Rewards Points: 30
Default Can I mount din rail in a nema 3r weatherproof enclosure?
First question is can I do this with no backplate, And second is what is the best method. Drill and tap? Self tap? Or bolt and nut?
Family guy is offline   Reply With Quote
Old 10-31-2019, 01:57 PM   #2
Peewee0413's Avatar
Rewards Points: 254
Why opt to not use a backplate?
dronai and Bird dog like this.
Old 10-31-2019, 02:01 PM   #3
Rewards Points: 30
I don’t have one at this point.
Old 10-31-2019, 02:11 PM   #4
Rewards Points: 2,060
yes but it may lose its 3r rating unless you can spotweld the din rail
Old 10-31-2019, 02:22 PM   #5
Rewards Points: 30
That is the question. If it loses the 3R rating if I drill through the back of the box. Going to have to do some checking.
Old 10-31-2019, 02:38 PM   #6
Rewards Points: 7,475
If you use neoprene washers on the outside you should be good.
micromind, splatz and joe-nwt like this.
Old 10-31-2019, 02:42 PM   #7
Rewards Points: 30
Do you know where I could get some neoprene washers?
Old 10-31-2019, 02:52 PM   #8
Peewee0413's Avatar
Rewards Points: 254
Hardware store.. plumbing section, sometimes in bolt bin area. Neoprene is used for sinks, washers, toilets etc.
Old 10-31-2019, 03:01 PM   #9
Rewards Points: 30
Thanks
Old 10-31-2019, 03:07 PM   #10
joe-nwt's Avatar
Rewards Points: 982
This. Many outdoor panels come with washers to seal the mounting holes at installation.
joe-nwt is online now   Reply With Quote
Old 10-31-2019, 03:18 PM   #11
Watt Pusher
B-Nabs's Avatar
Rewards Points: 470
2/2 joes agree
SpaceMonkey likes this.
Old 10-31-2019, 05:20 PM   #12
I would just drill and tap. If your concerned about water you can place some sealing substance on the 8-32 threads.
micromind, dronai and MHElectric like this.
Wavelet8 is offline   Reply With Quote
Old 10-31-2019, 06:02 PM   #13
Rewards Points: 802
You can buy them but I usually have sheet metal tek screws around that come with the gasket washers, I just use those.
It's also fine to just use some flat gasket material on the outside between the washer and the box.
I usually back it up by coating the gasket or washer with a little silicone, can't hurt, probably helps.
I have done it this way for years. Remember a 3R as far as I know will always be set up to drain if a little water gets in, so at worst you'll have some seepage from the bolt hole down to the floor of the container where it will escape, harmless. If you can help it don't put anything below holes.
Another thing to consider, if the enclosure was made for a back plate, you can usually mount din rail or strut vertically between the holes made for the back plate, then mount the horizontal din rail to the vertical. I actually sometimes much prefer this method if you're mounting anything big in there.
Old 10-31-2019, 07:32 PM   #14
MHElectric's Avatar
Rewards Points: 4,624
Agreed. Why would drilling into the back of a NEMA 3R box take away it's rating? You know there's holes on the back side for mounting to a wall, so why would zipping a dinner rail with a couple of screws make it any less outdoor rated?
Old 10-31-2019, 11:02 PM   #15
dronai's Avatar
Rewards Points: 4,571
Drill and tap 8-32
Old 10-31-2019, 11:19 PM   #16
Chief Flunky
Rewards Points: 338
If the metal isn’t thick enough taps fail so then bolt and nut. I use self tapping screws mostly but be careful of what’s behind the panel.
Old 11-01-2019, 10:02 AM   #17
Cow
Rewards Points: 4,842
3R boxes have open factory holes at the back for securing the box.
I'm not sure why sealing washers would be necessary for field installed holes when they are not provided or installed for the factory drilled holes?
I use #10 panhead self drillers right through the back. No silicone, no sealing washers, etc.
A 3R box is simply a rainproof box. It is not intended to keep all water out, but simply to keep it off components inside and drain what may get in to the drain holes in the corners of the box if needed.
If this was a 4X box or similar NEMA rating, I would agree with sealing the holes you make to maintain the NEMA rating.
splatz and gpop like this.
Old 11-02-2019, 09:20 AM   #18
Rewards Points: 30
Thanks for all your input. Sometimes I feel like I just overthink things too much, but If I know to do something I need to do it. Sometimes I don’t know and am trying to learn and work through issues and there is a lot more weight doing this by yourself and not just doing what your told.
Just to let you know at the end of the day I got the wrong washers, and got spun around a bit, then I actually reverted back to asking a local electrician that knows the AHJ of the area I was doing the project in and decided to self tap and silicone because there was another metal plate behind the enclosure. Then bought some silicone to touch it up.
Old 11-02-2019, 03:14 PM   #19
Rewards Points: 254
Type 3R does not actually mean that water will not enter an enclosure, only that it will not get to any live parts. The bigger concern to me is actually the corrosion aspect. Drilling through the back will expose the edges of the holes to moisture and eventual rusting. Using sealing washers against the screws will help prevent that.
glen1971 likes this.
