Differential Pressure Transmitter Help - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By FTC
Old 01-18-2019, 07:52 PM   #1
24V
Rewards Points: 18
Default Differential Pressure Transmitter Help
Hi,
I am working on a current system using a Bailey Differential Pressure Transmitter. Unfortunately the label is torn off, the only thing left is 0-150" H20 , 12-42VDC Max input, 1/2 NPT. Any chance that anybody knows the model number? It will be greatly appreciated.
Kind Regards,
24V
24V is offline   Reply With Quote
Old 01-18-2019, 08:26 PM   #2
FTC
Rewards Points: 34
What is the process? This seems like something you should be able to find on the manufacturer's website. You could also call the distributor.
John Valdes likes this.
FTC is offline   Reply With Quote
Old 01-18-2019, 08:53 PM   #3
Rewards Points: 2,662
Unfortunately we would need a lot more info as the code number contain details of the seating material.
This is really a vender question as with all industrial meters by the time you install them they are out of date and probably no longer available so anything you buy will have a different part number.
Old 01-18-2019, 08:55 PM   #4
Rewards Points: 792
Bailey has been gone for 20 yrs...but all the info you need for a new DP transmitter you have although Bailey did sometimes not follow the normal 4ma to 20 ma standard on some of its products ....it's time to search the internet !
Old 01-18-2019, 09:04 PM   #5
Rewards Points: 516
Bailey was bought by ABB and last I heard, ABB still supports much of it.
https://new.abb.com/products/measure...e_transmitters
Old 01-18-2019, 11:09 PM   #6
Rewards Points: 102
Knowing that it is 0 to 150" wc goes a long way to making use of it. 4-20mA Pressure transmitters are pretty ubiquitous. Knowing the above and the process material, you should be able to find a substitute pretty easily.
cmdr_suds is offline   Reply With Quote
Tags
manual, plc, pressure, transmitter, wiring diagrams
Sourcing a high pressure compressed air cylinder MikeFL Off Topic (Non Trade) 25 03-13-2017 12:52 PM
Burst pressure Helmut General Electrical Discussion 25 03-01-2017 11:40 PM
15 kv bus differential relay EC2253 Industrial Electrical Forum 5 02-17-2017 02:49 PM
How to plug in a Philips Low Pressure Sodium Bulb using a Ballast yoerez General Electrical Discussion 2 12-03-2016 06:32 PM
