Digital IO over Fiber - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By Peewee0413
  • 1 Post By MikeFL
  • 1 Post By Navyguy
  • 1 Post By Rora
  • 1 Post By triden
Old 04-22-2019, 09:48 AM   #1
Rewards Points: 3,712
Default Digital IO over Fiber
Can anyone recommend a brand to extend digital IO or dry contact closure over fiber? An internet search turns up lots of these with prices from not-cheap to not-cheap-at-all to pretty-goddamned-expensive. I am looking for a brand recommendation, hoping to pick out the right one on the first try.
The distance is not too long, maybe 1000'. No need for a bidirectional device. No need for multiple IO, just the one. An industrial type device with DIN rail mount would be preferable but not a deal breaker.
It does need to be fast, 1ms or less, so I don't want to use anything IP / ethernet based or probably any other standard communications or control protocol. Just a transmitter and a receiver.
Old 04-22-2019, 01:09 PM   #2
Peewee0413's Avatar
Rewards Points: 254
Why fiber may I ask? Can it be wireless? Phoenix contact does transceivers that work well. line of sight needed.
The Following User Says Thank You to Peewee0413 For This Useful Post:
splatz (04-22-2019)
Old 04-22-2019, 01:30 PM   #3
MikeFL's Avatar
Rewards Points: 2,684
I think with wireless he'd have latency in excess of 1ms.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
splatz (04-22-2019)
Old 04-22-2019, 04:56 PM   #4
I wouldn't rule out wireless but the fiber is already there. Even if the wireless hardware is cheaper, the fiber hardware would probably still be cheaper all-in, once you pay for mounting the antennas outside of the enclosures with line of sight.
Old 04-22-2019, 04:58 PM   #5
It looks like you are correct, the wireless offerings from Phoenix are at best 10ms.
https://www.phoenixcontact.com/onlin...1-1e1f9718e2b8
Old 04-22-2019, 06:32 PM   #6
Peewee0413's Avatar
Rewards Points: 254
I read wrong, I thought he said it doesn't need to be fast.
Old 04-22-2019, 06:39 PM   #7
Rewards Points: 3,840
I don't know if Omega makes what you are looking for... we used Omega for a lot of instrumentation and communications items connected to PLCs over the years. Even today I still have a couple of Omega Thermocouples on the shelf for emergency use.
Short of someone going in there and willfully damaging an item, I have had great success with Omega products.
Cheers
John
The Following User Says Thank You to Navyguy For This Useful Post:
splatz (04-22-2019)
Old 04-23-2019, 05:12 PM   #8
Rewards Points: 1,982
What is the device you want to connect the fiber optic input to? can it just be replaced with a fiber optic sensor directly?
Old 04-23-2019, 05:31 PM   #9
It's to the trigger on a camera, so there's no getting around the converter.
Old 04-29-2019, 07:09 PM   #10
Rora's Avatar
Rewards Points: 680
I'm guessing the fiber equipment you're looking at is going to involve a price for the industrial rating?
What kind of fiber is in place, and how/if is it terminated? Assuming it's multimode and industrial ratings are not required, look at something with an SC or LC interface. It's become mainstream enough that it's not too ridiculous. You should also figure in the price of terminating the fiber properly to said interface.
Edit: looking around it seems most are either purpose built industrial IO extension for a lot of money, or cheaper Ethernet based applications, as I'm sure you've already seen. Sorry I couldn't be of help, maybe someone else knows of a brand.
Old 04-29-2019, 07:43 PM   #11
Peewee0413's Avatar
Rewards Points: 254
How about
FRM220-CCF20
Old 05-02-2019, 02:28 AM   #12
triden's Avatar
Rewards Points: 360
Why does it have to be fiber - why not just use copper? If it's a high impedance input, voltage drop is negligible.
Old 05-02-2019, 04:52 AM   #13
The fiber is already there!
triden (05-12-2019)
Old 05-02-2019, 04:53 AM   #14
How about
FRM220-CCF20
I saw that one in my search results, it looks like a great value but it looks like it uses a network protocol from point to point, so you'd never achieve reliable speed under a millisecond.
Old 05-02-2019, 06:53 AM   #15
Peewee0413's Avatar
Rewards Points: 254
I would check on that.. I think it can be set up to send an immediate signal.
All Digital HackWork Business, Marketing, and Sales 17 06-07-2017 11:47 PM
Giveaway: Digital Inverter Generator by Millbank! Cricket General Electrical Discussion 63 09-28-2016 08:35 AM
Purchasing the digital NEC Speedy Petey Business, Marketing, and Sales 7 06-28-2016 09:32 PM
