Ferrules - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
Old 11-03-2019, 01:50 PM   #1
dronai's Avatar
Rewards Points: 439
Default Ferrules
Ferrules when panel building, yea, or nah ?
Old 11-03-2019, 03:07 PM   #2
Peewee0413's Avatar
Rewards Points: 254
Its a good thing IMO, especially on certain terminal blocks. BUT!! if panel building is your job, then you need to account for the extra cost. (Time & Material)
Old 11-03-2019, 03:10 PM   #3
Rewards Points: 2,390
I have not found them necessary on terminal blocks because I don't get stray strands making trouble with terminal blocks. (I mean DIN style terminal blocks.)
On relay bases where the screw terminations are prone to shorts from stray strands, maybe / probably.
On pain in the ass equipment with ridiculously crowded shallow terminals, hell ya.
This too shall pass.
Old 11-03-2019, 03:31 PM   #4
Peewee0413's Avatar
Rewards Points: 254
With ferrules you can usually just push the wire in the push in terminals, where as with stranded you must use a screw driver to insert the wires. I've seen the novice cause damage prying around.
dronai and splatz like this.
Old 11-03-2019, 03:59 PM   #5
dronai's Avatar
Rewards Points: 439
I don't use ferrules, but saw one guy doing it. I think it's required in Europe though
Old 11-03-2019, 05:28 PM   #6
joe-nwt's Avatar
Rewards Points: 1,808
Nice on panel devices with crowded screw terminals such as PLCs. One stray strand can cause a lot of grief. Just as an FYI they also make ferrules that accept 2 conductors. Sometimes these will save you time trying to shove 2 fine-strand conductors in the same hole. I find the cost and the time to be neither here nor there, but I don't often use the on all connections in a panel build. There will be devices in a panel that require stakons, ferrules take the same amount of time.
splatz and Southeast Power like this.
Old 11-03-2019, 06:01 PM   #7
Rewards Points: 5,558
I generally match what is there, but if going from scratch I would use them. More importantly is the numbering scheme; if I am going to putting ID numbers on the wires (which is necessary), then the extra 30 seconds to put a ferrule or sta-kon on does not even show up on the radar.
Cheers
John
MechanicalDVR, dronai and splatz like this.
Old 11-03-2019, 07:23 PM   #8
Small Potatoes
flyboy's Avatar
Rewards Points: 4,249
I took in a ferrel cat once.
The Following User Says Thank You to flyboy For This Useful Post:
dronai (11-16-2019)
Old 11-03-2019, 08:08 PM   #9
Band Member
emtnut's Avatar
Rewards Points: 2,504
Never used them, but have seen them. On 20awg and lower they are good if you're going into a TB.
Anything larger, there's no reason to use them IMO.
Old 11-03-2019, 08:27 PM   #10
Rewards Points: 3,352
Since a good part of my work is add-ons and various changes, I don't use them.
The only way to change a label is to cut the ferrule off and it's difficult to add another wire to a terminal block is there's already a ferrule there.
Old 11-03-2019, 09:29 PM   #11
Rewards Points: 4,106
Some places have had 'em spec'd. Then it's a matter of what they want to see and where. Most jobs I've been around, they aren't asked for.
dronai likes this.
Old 11-05-2019, 05:36 AM   #12
Rewards Points: 1,878
Ferrules should normally be used on spring retention terminals. I use them on equipment terminations all of the time. I like to use ferrules on equipment that is to be disconnected, relocated and reconnected. They save the wire ends from becoming frayed to where the wires will not go in the terminal without reworking the ends.
Using ferrules on SO cord, makes installing twistlock plugs and receptacles much easier.
Time and cost are trivial to use them.
Old 11-05-2019, 09:57 PM   #13
dronai's Avatar
Rewards Points: 439
That's one out of 8 people so far.
Old 11-06-2019, 08:29 AM   #14
Chief Flunky
Rewards Points: 344
Ferrules are definitely not Code. It should be obvious. Round peg in flat or square hole that is designed to accept a soft ductile metal where it cracks the oxidation then smears both metal surfaces together so we get a joint wire microohms of resistance and meets the design contact area. Ferrule joints don’t do any of that. Technically you’re not even supposed to reuse ends because they are deformed. Fine strands tend to fray or break the worst. So the fraying argument is dead wrong. We all still do it though because reterminating the end is time consuming and usually the ends aren’t that bad.
If you are going to be routinely changing wiring there are tons of much better options. First off install connectors for frequent plugging/unplugging. ThAts what plugs do. Or use lugs. That’s what most people do on motors. Or forked or ring terminals. Those are all flat so they work. Or get Phoenix Contact separable terminal strips. All of this is Code. The tiny 3-5 mm DIN rail terminals are meant for once and done or once in a few years where the wiring maybe gets disturbed three or four times in its life. If the panel shop cheaped out mount your own.
I keep ferrules on the truck for one customer.
dronai likes this.
Old 11-06-2019, 10:03 AM   #15
MTW
Rewards Points: 11,356
When I was building panels, I found them very handy for small conductors, which you run into quite frequently depending on the type of panel you're building.
Old 11-06-2019, 09:22 PM   #16
After crimping ferrules are not round and they will deform to fit a mechanical connection.
Yes, I would use rings or forks where they would work the best.
Few mechanical connectors are rated for fine strand conductors, so ferrules are helpful to use to keep the strands under the set screws.
Most European equipment uses ferrels for all connections, even power terminations.
Old 11-06-2019, 09:28 PM   #17
dronai's Avatar
Rewards Points: 439
Varmit, You work at a plant as an employee, or contract ?
It seems like there is no doubt, it's best way to terminate wires, but unless it's spec'd by the engineering documents, most contract Electricians won't spend the time to do it.
Your idea on cord and cap is a good use also.
Old 12-07-2019, 12:35 AM   #18
OldGeek
garyevp@gmail.com's Avatar
Rewards Points: 30
I always use crimped ferrules with stranded wiring in control panels.
dronai likes this.
garyevp@gmail.com is offline   Reply With Quote
Old 12-07-2019, 08:53 PM   #19
I work for a contractor doing maintenance and upgrades at several different industrial plants.
With a stock of ferrules and a good crimper, they really don't take much time to use,. If you are trying to poke stranded wire in a spring terminal, I believe that using ferrules can be faster.
dronai likes this.
Old 12-07-2019, 10:09 PM   #20
Rewards Points: 20,649
I learned how to "Tin" the end of stranded wire when I attended Lee County Voc Tech back in 1975. They have little propane solder irons nowadays that you can refill from a spray can that make doing that out on a job site incredibly easier. It's the bomb for ending stranded wire into little baby European controls and terminal blocks.
Nationalize all foreign owned farmland now. Now.
