Identifying the windings in a six lead motor - Electrician Talk - Professional Electrical Contractors Forum
Old 12-15-2011, 09:04 AM   #1
dronai's Avatar
Rewards Points: 439
Default Identifying the windings in a six lead motor
A good trick I found on another forum. Thought I would share
Can anyone explain how you would go about identifying the windings of a three-phase single speed, 6 lead AC induction motor?
It can be worked out which pairs of leads are the windings with an ohmic check but how do you find the correct orientation of each winding?
I once heard it can be done with a battery and galvanometer... but how?
Old 12-15-2011, 09:05 AM   #2
dronai's Avatar
Rewards Points: 439
Best answer
This is how you do it....
Step 1. Identify the 3 pairs of windings. This is easy, using a multimeter. Mark the ends A,A, for the first pair, then B,B, then C,C etc.
Step 2. Obtain a LOW voltage A.C supply. Around 10 volts will be sufficient. {Note that this will only work with an A.C. supply, not D.C.}. Connect this supply to the wire A,A. but do not turn on yet.
Step 3. Pick one end of the pair B,B, and connect it to one end of the pair C,C. With the remaining wires (one B and one C) connect to a multimeter set to volts AC.
Step 4. Turn on the supply. Check for a voltage reading on the multimeter. Now please note the following carefully...
The motor windings are referred to as "Starts" and "Finishes". If the connection between B and C is a "Start" joined to a "Finish", you will read a small voltage on the multimeter.
If no voltage is present, then the connection between B and C is a "Start" joined to a "Start".
If no voltage is detected, swap one of the wires at the connection between B and C.
Step 5. Lets say you have successfully produced a voltage..Should be around 4 volts..Where did this come from?? {I dont want to sound like a smart a$$, but this is important} If you get to the stage whereby a voltage is produced, then mark the B wire at the junction with C as B1. Mark the C wire at the multimeter as C1. This will give you the relationship between the B and C wires.
Step 6. The above procedure needs to be repeated for the A,A wires....
{Step 6a. Post back here if you are unsure of the steps outlined above}
Step 7. Join the wires A1, B1 and C1 to make a STAR (in Oz) or WYE (in USA) connection. Apply your 3 phase power to test your motor...Get ready to turn it off quick if something goes wrong!!
Good luck
The Following 3 Users Say Thank You to dronai For This Useful Post:
hub (01-14-2012), John Valdes (12-15-2011), Motorwinder (12-15-2011)
Old 12-15-2011, 09:06 AM   #3
dronai's Avatar
Rewards Points: 439
The follow up from the OP
IAN
That is perfect! It works... great. It's my new quiz for the workshop guys.
Many thanks
6 Lead Motor dronai PLCs, VFDs, Motors and Controls 29 12-16-2011 04:09 AM
help identifying switch adamv7010 General Electrical Discussion 6 11-04-2011 11:40 AM
Re-identifying conductors GDK 13 NEC Code Forum 7 09-13-2011 09:14 PM
need help with a 12 lead motor ArcRedoubt PLCs, VFDs, Motors and Controls 10 06-15-2011 10:29 AM
Insulating sleeve for windings subelect PLCs, VFDs, Motors and Controls 3 06-07-2009 09:18 AM
