Need some PLC programming training - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
Old 09-11-2020, 03:20 PM   #21
Rewards Points: 26
Originally Posted by just the cowboy View Post
Don't jump the gun, he said make a change as an example. What if he just needs to add something in the future or change a timer. He did not say " change program to fix something" Does he call an engineer??
Cowboy
In general, if you don't know what you are doing because you don't have PLC programming experience, then you don't have to do the work because it can be unsafe. Nobody can force you to work in unsafe conditions either.
Also, if the machine worked before, then it will likely work again without changes to the PLC program. The problem is that some electricians don't want to troubleshoot because that requires work. Some people are lazy and they don't want to get in the rats nest of wires to look for ground faults. They don't even want to check if the sensor is not aligned properly. But they want to immediately change how the machine works by altering the PLC code.
Corporate_Big_Shot is offline   Reply With Quote
Old 09-11-2020, 07:51 PM   #22
Rewards Points: 20
Ive worked with at least 30 programmers and its no surprise to find code that needs to be patched.
I have never meet a programmer that has truly tested there code in every situation. Just last week i had to toggle a bit simply because the reset on wonderware didn't agree with the tag in the code and that program is over 5 years old (first time we have tripped that motor and the full time programmer fixed it next day).
We have to sign out the program to change the code so everyone gets a alert if you make a change so no one is jumping/AFI a bad sensor unless everyone agrees. Its just easier to fix the sensor then deal with the emails.
Its getting to a point that electricians really need a laptop as everything is networked. Im not even going to bother trying to mess with a AB powerflex drive HIM when i can simply pull it up on the laptop. (also means i can dial in and see whats going on before leaving home)
