Vibration resistant RTDs - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By joebanana
Old 05-22-2020, 04:41 PM   #1
QMED's Avatar
Rewards Points: 310
Default Vibration resistant RTDs
Anybody have experience with using MgO RTD probes for wells with a lot of vibration or do you use something else?
I just replaced a couple RTD assemblies that looked like Frankenstein with brand new components from minco but now I'm wondering if I should have used these MgO probes instead of standard ones. The vibration is pretty bad.
http://catalog.minco.com/catalog3/d/...=1_6_9-mgortds
QMED is offline   Reply With Quote
Old 05-22-2020, 05:54 PM   #2
Rewards Points: 2,658
Probes never seem to fail due to vibration but the terminal connection fails all the time.
Old 05-22-2020, 06:53 PM   #3
Rewards Points: 7,887
I agree with gpop on this one, industrial solid state components are fairly robust by their nature, unless slammed around. Are they potted, or just shoved in the well? We had all kinds of RTD's on an industrial gas turbine Co-gen, and never saw one fail. But it was a GE unit.
QMED likes this.
Old 05-22-2020, 07:19 PM   #4
MotoGP1199's Avatar
Rewards Points: 779
All of my RTD probes that just slide into the well get silicone on the outside(only) at the face of the well. Keeps them from sliding out and you can pull them out for replacement. We started doing this when a customer complained the thermostat would kick on every time someone opens the equipment room door. Apparently the cold air coming through the door would go straight into the well and the sensor would trigger the stat to kick on (1* deferential). Fixed that issue and some would slide out a little from vibration. Never had any fail due to vibration.
"The laws of physics will be strictly enforced."
MotoGP1199 is offline   Reply With Quote
Old 05-22-2020, 07:45 PM   #5
Chief Flunky
Rewards Points: 344
RTDs rely on a very thin sensor to work well. We epoxy them into motors but even then they are not vibration resistant. Thermocouples hold up much better.
Old 05-22-2020, 07:53 PM   #6
The ones I was thinking about were embedded in things like thrust bearings, and Babbitt bearings, instrument cluster ambient, or inlet air/exhaust temp. RTD's. Most of which required a complete tear-down to access.
Old 05-22-2020, 09:53 PM   #7
QMED's Avatar
Rewards Points: 310
Spring loaded minco holders. The vibration is way worse than a gas turbine, it seems to break all kinds of components. I've worked with GE LM2500 turbines and I only really ever fixed 2 or 3 things on them, they were pretty reliable for me.
Old 05-22-2020, 11:31 PM   #8
I would maybe consider a different vendor.
