Black oxidation (?) on ground wires - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By Signal1
  • 1 Post By joe-nwt
  • 1 Post By joe-nwt
  • 1 Post By joebanana
  • 2 Post By Signal1
Old 04-12-2019, 05:21 PM   #1
Rewards Points: 4,120
Default Black oxidation (?) on ground wires
So doing some renos in the basement and a couple of the boxes I've opened up have a black coating on the grounds that rubs off. It is almost like a dust that gets onto your hands, but not a large accumulation. The boxes were for a light on one side of the house, the dryer, and a couple of receptacles in the laundry. I haven't seen it before and just wondering if anyone might have an insight as to what it might be.. Naturally the basement is finished, so ripping it out isn't really an option..
As a side note... In my after life, I hope I meet the guy that wired the basement in a dark alley... Receptacles wired wrong, ground wire cut off to a switch, switching the neutrals on all of the lights I've come across, very little left for a loop, etc..
Old 04-12-2019, 05:28 PM   #2
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,676
How old is the house?
That is an indication of toxic Chinese drywall.
I hope that's not the case, but if it is the house needs to be vacated immediately.
telsa likes this.
The Following User Says Thank You to Signal1 For This Useful Post:
Southeast Power (04-13-2019)
Old 04-12-2019, 05:51 PM   #3
joe-nwt's Avatar
Rewards Points: 3,592
Usually an indication of hydrogen sulfide. Many sources besides chinese drywall. Don't panic.
Research it. At least inform the home owner.
Southeast Power likes this.
Old 04-12-2019, 06:02 PM   #4
Built in 2006.
Drywall in the basement that I can see is:
Toughrock, Edmonton, AB, 11/29/06
Old 04-12-2019, 06:03 PM   #5
I am the home owner.. lol..
I've seen tons of effects of H2S on wires and this doesn't really look like it. Not sure if maybe the wires was stored somewhere with it in the environment before it was installed here..
Old 04-12-2019, 06:38 PM   #6
joe-nwt's Avatar
Can be from rotting organics, sewer gas, many things. Any batteries in the house? Backyard pool?
I see it here from time to time. Just throwing things out there hoping one of them will ring a bell.
glen1971 likes this.
Old 04-12-2019, 06:56 PM   #7
Rewards Points: 8,105
Heat will cause black oxidation on copper. Ground fault somewhere?
Old 04-12-2019, 07:01 PM   #8
No batteries.. No pool. Sump pump sump is about 20' away.. No odors in the house. Nothing that I can find as rotten..
Old 04-12-2019, 07:04 PM   #9
The two receptacles I replaced were both back stabbed, one wired wrong, and one of the hots fell out when I touched it on the washing machine. No sign of heat degradation on the wires though. It seems like it was mainly on the grounds..
Old 04-12-2019, 07:24 PM   #10
Signal1's Avatar
Originally Posted by glen1971 View Post
Built in 2006.
Well that's good news, sounds like it isn't that Chinese crap.
It was a big problem in the southeast US right around that date range.
glen1971 and Southeast Power like this.
Old 04-12-2019, 07:56 PM   #11
I did a little googling after you had mentioned it and only found one reference to Toughrock and Edmonton, and they said there was an issue with some sulphur that got into some gypsum from a mine in BC.
There was a fair amount from the US side on the issues post hurricane issues they have had with it! I couldn't imagine having to have to replace a house full of drywall! I can't believe it got let into the country and passed inspectors!
Replacing 2 single pole switches - 3 hot wires & 1 wire connecting both switches gearsco Residential Electrical Forum 7 07-08-2018 06:06 PM
Installing smart switch with only 3 wires. (Black, White, Bare) TrevinLC1997 Lighting Design 1 06-08-2018 01:55 AM
Ground Current brian john General Electrical Discussion 13 05-22-2018 10:46 AM
3 identical black cloth wires df1524 Residential Electrical Forum 5 12-17-2017 03:16 PM
Water line used as system ground. ELECTRICK2 Residential Electrical Forum 92 05-22-2017 06:48 PM
