Canada: Siemens vs. Stablok vs. Square D vs. Eaton - Electrician Talk - Professional Electrical Contractors Forum
Old 01-21-2012, 09:22 PM   #1
Default Canada: Siemens vs. Stablok vs. Square D vs. Eaton
I do commercial work and am not involved in purchasing or planning decisions. The guys I work with never touch residential at all. I do what I'm told to do and so I never learn about the up and downsides of panels, I just work with what I'm given.
I just bought a home and need to replace the old POS fused panel and have to choose a new one. Money is not really an issue; I want to put in a quality load centre. What do you guys recommend for installation, especially if it was in your own home?
cguillas is offline   Reply With Quote
Old 01-21-2012, 09:25 PM   #2
ce2two's Avatar
Rewards Points: 690
If it were my house , sq.D QO's...imho
Tell me how an ant or a lizard thinks
than i will believe in your supreme being.
ce2two is offline   Reply With Quote
Old 01-21-2012, 09:27 PM   #3
Broke
parnellelectric's Avatar
Rewards Points: 150
Second the QO
parnellelectric is offline   Reply With Quote
Old 01-21-2012, 09:31 PM   #4
Any particular reason? Quality? Affordability? Or because you can pinch breakers from work?
Old 01-21-2012, 09:49 PM   #5
Rewards Points: 250
I would use Cutler Hammer CH
________________________________
How can you have any pudding if you dont eat your meat
BurtiElectric is offline   Reply With Quote
Old 01-21-2012, 09:52 PM   #6
Same question... Why? Or why not the others?
Old 01-21-2012, 09:54 PM   #7
Broke
Rewards Points: 150
I use CH at work, they are good but the Sq-D stuff is a little more solid, seems to be built better.
Old 01-21-2012, 09:56 PM   #8
ce2two's Avatar
Rewards Points: 690
If i changed out my switch gear in my own commercial bldg. i would go with I LINE SQ.D ,the aforementioned sq.d QO'S in my houseQuality..
Old 01-21-2012, 09:56 PM   #9
SK Sparky's Avatar
Rewards Points: 25
Stablok because you can weld with their 15a breakers.
SK Sparky is offline   Reply With Quote
Old 01-21-2012, 10:02 PM   #10
Rewards Points: 250
CH is what I install. I dont like the neutral bar set up on QO, I also find that the metal expands on the breakers where it connects to the bus.
The CH panels have a higher AIC rating, a copper bus, a recessed nuetral bar for Snap on afci's, is physically larger and has many more provisions on the neutral bar. Also I can get the CH panel for less then the QO panel.
Old 01-21-2012, 10:15 PM   #11
cog
stuiec's Avatar
Rewards Points: 1,404
Keep in mind that most of the replies you are getting are from American posters, and the layout of the loadcentres may be different due to 6-306.
Old 01-21-2012, 10:30 PM   #12
If it were my house I would put a QO panel in but I don't have much experience with anything else as almost every house where I live has a QO panel. Burtielectric what don't you like about the neutral bar? I've never had an issue with not enough space. Maybe they're different in Canada.
Nigelforsythe is offline   Reply With Quote
Old 01-21-2012, 10:35 PM   #13
rdr
Expatriate in Training
rdr's Avatar
Something that has thrown me off about the panels up here is that almost always you can take the dead front off and all the lugs for the phases and neutral are separated from the breakers.
It's not a bad idea. Just a little different.
rdr is offline   Reply With Quote
Old 01-21-2012, 10:37 PM   #14
cog
stuiec's Avatar
If it is a load centre it should be always.
Old 01-21-2012, 10:46 PM   #15
rdr
rdr's Avatar
Not so in the states.
I'm an American transplant.
Old 01-21-2012, 10:47 PM   #16
cog
stuiec's Avatar
Yes, I know.
Old 01-21-2012, 10:50 PM   #17
rdr
rdr's Avatar
Yes, I know.
Nice, Columbo. It was you who stated the obvious.
I'm kind of still getting oriented again.
Old 01-21-2012, 10:53 PM   #18
I agree. I know I feel safer with that barrier there when I'm working in an energized panel.
Old 01-21-2012, 10:56 PM   #19
rdr
rdr's Avatar
Like I said, not a bad idea, just different.
It seems more regulated than the states in general.
Old 01-21-2012, 10:59 PM   #20
cog
stuiec's Avatar
Not trying to be an ass, meant yes I know you are a transplant.
Also, I prefer Kojak
Siemens vs Square D Magnettica Services and Service Equipment 142 02-06-2014 10:09 AM
Eaton-Cutler Hammer Roadshow Magnettica General Electrical Discussion 25 03-30-2011 08:55 AM
AB vs. Siemens Mike in Canada PLCs, VFDs, Motors and Controls 12 10-23-2010 08:28 AM
Eaton Contractor Tiger Business, Marketing, and Sales 38 09-20-2010 01:19 AM
Counterfiet Eaton/Cutler Hammer breakers Zog Workplace Safety 7 04-28-2010 01:22 PM
