COnversion MR16 to 120V led - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 2 Post By 99cents
  • 1 Post By B-Nabs
Old 11-20-2019, 10:56 PM   #1
NDC
NDC's Avatar
Rewards Points: 2,340
Default COnversion MR16 to 120V led
Whats the easiest way to convert an mr16 new construction transformer type pot light to led?
This is super easy if its an old work type fixture because I can just pull out the entire fixture transformer and all but the new work type is a pain in the ass to rewire in a drywall ceiling.
Ive been reaching into the hole, removing the transformer and plate with one hand, struggle to remove the wire and pray its long enough to pull out of the hole and into a new fixture. Now the new slim led fixture has to fit the existing hole or I have to bore each one to fit.
I dont want to use mr16 led bulbs because they still rely on the transformer which go bad often and is usually the cause for the call.
NDC is online now   Reply With Quote
Old 11-21-2019, 03:19 PM   #2
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 254
Why can't you use the existing transformer housing as a jb and just remove the light housing?
Old 11-21-2019, 03:53 PM   #3
Rewards Points: 13,417
I have pulled apart old housings and put Lotus Lights in the hole. If the hole is too big, you can put in goof rings. I haven’t had to but it’s an option.
Old 11-21-2019, 11:18 PM   #4
NDC
NDC's Avatar
Would have to add a wire to that jb through the hole with one hand.
Old 11-22-2019, 09:08 AM   #5
Rewards Points: 254
Is there enough slack on the wire to cut it right at the transformer and bring the wire down through the hole? It's hard to suggest with no pics.
Wago's with one hand would even be difficult from what you just commented, but that's all that comes to mind.
Old 11-22-2019, 09:16 AM   #6
Watt Pusher
B-Nabs's Avatar
Rewards Points: 470
This is what I was thinking. Cut the wires off right at the transformer, then use lever nuts to attach to them.
The_Modifier likes this.
