Homer Helper product? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 3 Post By HackWork
  • 1 Post By HackWork
Old 12-23-2018, 02:23 PM   #1
Rewards Points: 531
Default Homer Helper product?
I was paging through some Instagram posts and saw this product for the first time, and there was quite a bit of positive talk about how these speed up homerun instals by not having to staple the runs.
Has anyone ever used these? They seem a little pricy but hard to say without having experience with them.
The spec sheet shows a boat load of wires being able to be run through the same hole, are we allowed to run that many through a bored hole in wood? I don't think so but I may be wrong.
I'm sure these are UL listed but could a fella make his own out of say 1/2" plywood in the same fashion and be legal?
Thanks, John.
https://www.ti-dwire.com/
JohnJ65 is offline   Reply With Quote
Old 12-23-2018, 02:27 PM   #2
No Longer Here
Rewards Points: 578
Thanks, John.
I think those are great, but too expensive for me to actually use.
The specs show up to 3 cables thru each hole, which is the same thru a hole you make in the framing.
Yes, you can make those yourself out of anything that won't chafe the cable.
I often just use Stackers, they are cheap and easy to install. And when pulling over joists I can pull all the cables, then go back and hammer down a couple stackers and clip the cables into them.
Old 12-23-2018, 02:37 PM   #3
Rewards Points: 1,230
I have never seen those but they the look like a great idea. I will use a stacker or the 1 1/4 grommets used for metal studs in the same fashion as what you posted except screwed to the rafter not the floor joists and pull through those and it makes pulling very easy.....no one has ever called me on it. Just have to remember not to put to many wires through the grommet because of derating
bostonPedro is offline   Reply With Quote
Old 12-23-2018, 02:42 PM   #4
Rewards Points: 21,898
I like it but I dont know how often I will use them but they look good to me.
Pricewise I am not sure what they are run for now.
maybe I can use that on commercial side which I pull bunch of MC cables that may be a ticket.,,
Old 12-23-2018, 03:44 PM   #5
Rewards Points: 3,367
I like it!
Of course you can always go dumpster diving for scrap wood and make your own. I would just grab some 2 X 6’s and some framing screws and do it.
Old 12-23-2018, 03:45 PM   #6
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 496
Rack a tiers makes them too. They advertise them for pipe IIRC.
Vote Kevin for Moderator!
Old 12-23-2018, 03:51 PM   #7
Rewards Points: 3,134
These come up from time to time
https://www.electriciantalk.com/f29/...4/#post5046568
I was interested in these when I saw them but I don't see the value. They are very expensive and I don't see anything they do for you that you wouldn't be as good or better off using stackers.
Setting them first and pulling your home runs through them will take a lot of time threading each home run through each hole and will add a lot of friction, even if you are careful to line them up perfectly. You would be better off pulling the home runs and coming back and putting stackers on after. This will be just as neat, much faster, and much cheaper.
I could believe that once in a while you'll come across an odd situation where they are for some reason better than the alternatives and worth the money.
#HACKLIVESMATTER
Old 12-23-2018, 03:56 PM   #8
No Longer Here
Rewards Points: 578
You copied my idea!!!
And don't give me any crap about posting it 5 months before me! I still would have thought of it first back then!
Job interview on Monday for an electrical helper Ignitethesun Electrician Apprentice Forum 5 02-04-2018 06:25 PM
unistrut product, where do i get it?? benderbus Business, Marketing, and Sales 24 11-09-2017 06:25 PM
LED wall packs frenchelectrican General Electrical Discussion 26 04-21-2017 08:52 PM
Powering outdoor product itaist Code Violation Discussion 2 01-28-2017 08:49 AM
I passed the Test for the License to be an Electrician Helper! JosiQElectrician General Electrical Discussion 30 12-04-2016 06:23 PM
