How to wire outlet constant on and toggle - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
  • 2 Post By HackWork
  • 1 Post By HackWork
  • 1 Post By Signal1
  • 1 Post By jw0445
  • 3 Post By frso
  • 5 Post By HackWork
  • 1 Post By frso
  • 3 Post By HackWork
  • 1 Post By frenchelectrican
  • 2 Post By Speedy Petey
Closed Thread
Old 11-06-2017, 11:07 AM   #1
Default How to wire outlet constant on and toggle
Hi, I and doing some bathroom renovation and i am changing some of the electrical.
I am installing a 2 gang box and i want one of the gangs to be a constant on duplex outlet. The other outlet is going to be a toggle switch to control the vanity. I am using Romex 12-2 wire and im not sure how to wire this. The only way i can think of is using a short jumper wire inside the gang box and im not sure if this is safe or not.
The way i am thinking is run the live wiring into the box and connect it to the duplex outlet. Then the wire a black jumper to the toggle. And then hook the black wire to the wire going to the vanity light to cut the power. And then hook the white wire going to the vanity to the extra screw on the duplex outlet.
Does this make sense or is there a better way?
frso is offline
Old 11-06-2017, 11:09 AM   #2
No Longer Here
Rewards Points: 578
You should definitely do this.
HackWork is offline
Old 11-06-2017, 11:14 AM   #3
So having a black jumper connecting the duplex to the toggle? Or should i wire nut 2 jumpers and connect one to the duplex outlet and one to the toggle? Or does it make any difference?
frso is offline
Old 11-06-2017, 11:15 AM   #4
No Longer Here
Rewards Points: 578
Either way will work, but you need to be sure to connect the neutral and ground together inside of this box. I also want to say that you made a good choice not using a GFCI outlet, they are rather dangerous in this situation.
emtnut likes this.
HackWork is offline
Old 11-06-2017, 11:19 AM   #5
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,720
I agree with this, and you should use Wagos for this connection.
emtnut likes this.
"Hanging ceiling fans for grandma"
M E T G A !
Signal1 is online now
Old 11-06-2017, 11:30 AM   #6
Band Member
emtnut's Avatar
Rewards Points: 160
Whatever you do, DO NOT wire on the LOAD side of the switch.
Your breaker won't see an overload, and it can actually melt the wires inside the box !
emtnut is offline
Old 11-06-2017, 11:31 AM   #7
jw0445's Avatar
Rewards Points: 1,982
Ibtl
The_Modifier likes this.
jw0445 is offline
Old 11-06-2017, 11:31 AM   #8
Rewards Points: 2,149
Your making it too complicated
active1 is offline
Old 11-06-2017, 11:33 AM   #9
active1 is offline
Old 11-06-2017, 11:37 AM   #10
I dont understand how to connect neural and ground. I did this in MS paint does this look right?
frso is offline
Old 11-06-2017, 11:42 AM   #11
No Longer Here
Rewards Points: 578
No, do it again but better this time.
HackWork is offline
Old 11-06-2017, 11:48 AM   #12
Rewards Points: 185
Call an electrician before you hurt somebody, where is the moderator?
EC2253 is offline
Old 11-06-2017, 11:50 AM   #13
****in great im getting trolled by smart asses...
I am not an electrician i just wanted to know how to wire this safely
HackWork, The_Modifier and Signal1 like this.
frso is offline
Old 11-06-2017, 11:51 AM   #14
Signal1's Avatar
This is EXACTLY how I learned to do it, only I use a blue box.
M E T G A !
Old 11-06-2017, 11:53 AM   #15
No Longer Here
Rewards Points: 578
Oh, you're not an electrician?
Then why did you register on a forum that said only professional electrician are allowed and no DIYers?
HackWork is offline
The Following 2 Users Say Thank You to HackWork For This Useful Post:
EC2253 (11-06-2017), The_Modifier (11-06-2017)
Old 11-06-2017, 11:56 AM   #16
google search and it popped up so i registered without reading the fine print... i will go find a new forum to ask on sorry for the trouble assholes.
Wiresmith likes this.
frso is offline
Old 11-06-2017, 12:09 PM   #17
No Longer Here
Rewards Points: 578
No, you clearly saw where it said electrical professionals only and then it asked for your electrical profession and you wrote "none".
The only asshole here is you.
HackWork is offline
Old 11-06-2017, 02:39 PM   #18
Modrateur
Rewards Points: 21,898
Please go to our sister site they can help you on this matter.,,
we did have a good print note when you sign in the fourm in here and you cant miss that.
frenchelectrican is offline
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
Speedy Petey (11-06-2017), The_Modifier (11-06-2017)
Old 11-06-2017, 02:43 PM   #19
Speedy Petey's Avatar
Rewards Points: 870
Some of us occasionally work.
frenchelectrican and Bird dog like this.
“If there are no dogs in Heaven, then when I die I want to go where they went.” – Will Rogers
Speedy Petey is offline
Closed Thread
