ICF boxes - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 2 Post By splatz
  • 1 Post By Judoka
Old 04-23-2019, 05:56 PM   #1
Rewards Points: 291
Default ICF boxes
Hi all! I’ve done box installs on ICF before. New customer wants a stove installed in the basement. I do not see a 4 -11/16 box for ICF. Anyone come across this? He may have to install a few studs to attach a metal box on. Thx in advance!
Judoka is offline   Reply With Quote
Old 04-23-2019, 06:18 PM   #2
Rewards Points: 2,470
How about this. If it's 2" foam, use a 2-1/8" deep box. Cut a 4-11/16" square recess in the foam right to the concrete. This will leave the box 1/8" proud of the foam.
Depending on the thickness of the foam and the thickness of the box you might have to shim it out a little.
If the foam is thin, you might have to put a wiremold starter box on top to get some depth.
Leviton makes low profile range receptacles that are only an inch deep, you could use a shallower box if the foam is thinner.
Bird dog and canbug like this.
This too shall pass.
Old 04-25-2019, 12:04 AM   #3
Rewards Points: 291
Thx for feedback!!
Old 04-25-2019, 12:54 AM   #4
Watt Pusher
B-Nabs's Avatar
Rewards Points: 480
That receptacle splatz posted well also fit comfortably in a 2 gang device box.
Ground splice in pull boxes or pass thru boxes ? Matthew90 General Electrical Discussion 16 12-20-2018 10:29 PM
MC and Plastic Boxes backstay NEC Code Forum 15 10-05-2017 12:44 PM
Electrical disconnect for By-Pass Boxes katwalatapan Canadian Electrical Forum 5 04-11-2017 08:23 PM
Adjoining 1900 boxes Nutmegger777 General Electrical Discussion 41 05-03-2016 12:21 PM
Exterior Box trim for recessed boxes psgama Residential Electrical Forum 7 01-22-2016 06:18 PM
