Ideas to hang a 500lb Chandelier? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 03-22-2010, 09:50 PM   #21
I own stock in FotoMat!
Rewards Points: 6,520
How big is the chandelier?
Figure out the square footage, then hire some Craigslist wannabe who advertises resi work for $2/ft². Slip him a 20-spot and tell him to keep the change, just have it done by lunch.
Magnettica (03-23-2010)
Old 03-22-2010, 11:02 PM   #22
Les Voltage
Originally Posted by drsparky View Post
I've always relied on iron workers or millwrights for the heavy stuff. Let the structural pros take the liability.
Could not have said it better, there is a reason 4 other people turned it down.
Old 03-22-2010, 11:59 PM   #23
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Originally Posted by ms12987 View Post
she called 4 different people already and nobody wants to get involved
I can see why
Hope you make much $$$ for doing this one.
Good luck.
Replies based on NEC 2014
Old 03-23-2010, 12:25 AM   #24
NO high voltage here
Rewards Points: 1,248
If you have called 4 people, and no one wants to do it... That should get you thinking...
Old 03-23-2010, 02:03 AM   #25
les
I agreee with Drsparky Let someone Who knows about structure do the xtra bracing and support, it,s your job and her life on the line
les is offline   Reply With Quote
Old 03-23-2010, 02:27 AM   #26
That threaded piece is supposed to go into a hickey or box mount. Also called a crows foot. But I would also be inclined to use an Aladdin lift. Those guys know how to hang a heave fixture. Even though you say it will run into the stairs, they have stops you set. They also move very slow. All the ones I have put in where to make cleaning possible. So it would, even stopping at the stair level make that possible. They are surprisingly cheap considering. And they do make them rated for the load.
egads is offline   Reply With Quote
Old 03-23-2010, 06:10 AM   #27
Default Lift
I would install the lift. I just think its is the right way to go. Its rated for that kind of weight.
r_merc is offline   Reply With Quote
Old 03-23-2010, 12:51 PM   #28
Lurker...
LJSMITH1's Avatar
Rewards Points: 322
It would be irresponsible to hang a fixture that heavy without a structural engineer being involved. A 500# point load is much different than a distributed load. Anyone who tells you "just to hang it" has no concept of the tremendous liability this job has. If this thing falls, it WILL kill someone standing near it. If beefing up the structure really is as simple as sistering some joists, then a structural engineer sign-off will be easy.
Larry
LJSMITH1 is offline   Reply With Quote
Old 03-23-2010, 07:19 PM   #29
220/221's Avatar
Rewards Points: 4,352
500 pounds....seriously?
I doubt it weighs that much. A 500 pound chandelier would be massive.
1. Check the framing.
2. Spread the load over as many rafters/joists as you can.
3. Use BIG hardware.
You mentioned lag bolts but I wasn't clear on the application. Obviously, never use lags to support anything this big. You want to thru bolt whatever hardware you use.
Old 03-23-2010, 07:42 PM   #30
The ceiling has enough support i could hang a car off it, im not worried about the ceiling coming down. Im more concerned about the fact that i can only use a piece of 1/8" all thread... thats all the light fixture will accept.
Its got about a 8-9' span when fully assembled. Its all brass. The main fixture is about 180 lbs with (12) 3' long arms that weigh 25lbs each.
The steel im going to use will span across 5 beams, but im going to frame it so it is supported by the walls instead of the rafters. I will post some pics of my framing job and the light when i get it all up.
ms12987 is offline   Reply With Quote
Old 03-23-2010, 08:44 PM   #31
Bababoee
captkirk's Avatar
Rewards Points: 2,030
Dont mess with the 3/8 stuff. Go right to half inch. I would do the same as the above
Old 03-23-2010, 09:31 PM   #32
Although this is my first post it anit my first rodeo. You need to get an engineer to design the how to on this for liability reasons. Oh yeah, they anit cheap. 500 lbs? Thats more than a piano.
Old man is offline   Reply With Quote
Old 03-23-2010, 09:33 PM   #33
Rewards Points: 5,198
It's just labor, and doable...ANIT?
Old 03-23-2010, 09:39 PM   #34
He ain't spellin' ain't right.
Old 03-23-2010, 09:40 PM   #35
Ya think?
Old 03-23-2010, 09:53 PM   #36
william1978's Avatar
Rewards Points: 2,000
It is your 2nd post.
Old 03-23-2010, 09:56 PM   #37
I am an electrian not an english major. Now its my 3rd post and the previous post still indicates first post. By the way thanks for the "warm" welcome.
Old 03-23-2010, 09:57 PM   #38
Originally Posted by old man View Post
i am an electrian not an english major. Now its my 3rd post and the previous post still indicates first post. By the way thanks for the "warm" welcome.
cool
Old 03-23-2010, 10:03 PM   #39
kbsparky's Avatar
Rewards Points: 1,000
.... Im more concerned about the fact that i can only use a piece of 1/8" all thread... thats all the light fixture will accept.
That pipe is actually 3/8" x 27 threads per inch. Commonly called 1/8 NPT.
For larger fixtures, I would recommend using at least ¼" NPT or ½"x16 threads per inch pipe.
-KB
Old 03-23-2010, 10:20 PM   #40
Toronto Sparky's Avatar
Rewards Points: 1,008
Sorta like hanging a ceiling fan from 2 8-32s on a octagon box.
Don't fight .. Play nice!
any ideas? charlie Bob General Electrical Discussion 17 09-25-2009 09:53 PM
Pre Fab Ideas 3rdgeneration General Electrical Discussion 26 03-31-2009 09:57 PM
Plenum Rated Chandelier Lift wayne_fitzpatrick Commercial Electrical Forum 10 02-11-2009 08:09 AM
who needs to buy special mounts to hang a plasma? dowmace Off Topic (Non Trade) 11 09-11-2008 06:27 PM
how do you hang multiple lights? shotdown General Electrical Discussion 11 08-04-2007 10:14 PM
