Milwaukee Hackzall's - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree29Likes
Old 04-25-2019, 08:06 AM   #21
Liberal Lesbian
Rewards Points: 152
He said in his opening post that it vibrated like crazy. That means the pipe is moving with the saw blade. You will never cut anything unless the shoe is snug against the pipe and the pipe stays stationary.
Yes, if you look at the top you will see where I explained that he had to hold the pipe tight against the guard to avoid that. But that doesn't change the fact that the Fuel model is significantly more powerful. It's a night and day difference. I've had the non-Fuel bog down while cutting thru older 2x framing, and it's a dog on thicker steel.
My preference is 18V anyway. Longer blade travel and lots of power.
While the tool itself is around the same size, the M18 battery is much larger and heavier. If I needed more power than the M12 Fuel, I would skip over the M18 model and just get the conventional M18 sawzall, which is a brute.
Old 04-25-2019, 09:32 AM   #22
Rewards Points: 2,979
Personal preference I guess. I use the Bosch 18V now which is a Milwaukee clone. Even with a fat 6.3 battery, it’s easy to use. A full blown Sawzall is a completely different beast. I have one but never use it.
Old 04-25-2019, 09:37 AM   #23
Liberal Lesbian
Rewards Points: 152
I haven't had to use a sawzall in a long time since the M12 Fuel Hackzawl does everything that I need. The last time I used a sawzall was to cut an 8" exhaust hole thru a very old house which had multiple sheathings.
The non-Fuel M12 Hackzawl is good for some instances, and if you have the money to spend on both then its fine. But the OP seems to only want to buy 1 tool now, so the Fuel model makes more sense, IMO.
Old 04-25-2019, 09:46 AM   #24
sbrn33's Avatar
Rewards Points: 3,616
The M12 bandsaw gives me a woody.
Old 04-25-2019, 10:18 AM   #25
Yeah, like I say, personal preference. The 18V can handle some pretty gnarly chit but it is bigger and bulkier.
Old 04-25-2019, 10:54 AM   #26
zac
Rewards Points: 826
Originally Posted by Rey View Post
Those are pretty efficient but too noisy for me, however, they could be deemed on the versatile side by changing the blade to a wood blade.
But we are electricians - not carpenters.
I like the m12 hackzalls and will head down to HD to go see how the fuel feels in my hands compared to the non fuel.
I find that people who say that use an impact over a fuel drill (all m12).
Old 04-25-2019, 11:47 AM   #27
Rey
Rewards Points: 70
@HackWork, which blades and batteries do you like/prefer for the m12 fuel hackzall?
Rey is offline   Reply With Quote
Old 04-25-2019, 11:48 AM   #28
Rey
Rewards Points: 70
sorry for the repost...
Old 04-25-2019, 11:58 AM   #29
sbrn33's Avatar
You better be or we will kick you to the curb in a second.
Have you stepped in any human waste this week?
Old 04-25-2019, 01:47 PM   #30
Diablo blades are the best bang for the buck (made by Bosch I think). Milwaukee blades are overpriced.
Old 04-25-2019, 02:25 PM   #31
Rey
Rewards Points: 70
I can get Milwaukee blades @ cost + 10% so I'm good there. How many tpi do you like for EMT? I've ususally just went with 32tpi or 24tpi. I see Milwaukee makes some EMT blades but they are 14tpi
And then it seems at least the 4.0 batteries for the 12v fuel is recommended to get any real work done?
Old 04-25-2019, 02:32 PM   #32
Liberal Lesbian
Rewards Points: 152
My father gave me a could hundred sawzall blades so I just use them. I don't even know the TPI. I just pick one with a lot of small teeth for metal and bigger teeth for wood.
I did buy some of those short Milwaukee blades which have come in handy a couple times.
The nice thing about the M12 line is that you can use the smaller batteries when needed. Sometimes you have to get the Hackzall into a tight spot and the 2.0 or 3.0 little battery works best. All other times I use the larger XC sized 4.0 or 6.0 batteries.
Rey likes this.
Old 04-25-2019, 02:48 PM   #33
Rey
Rewards Points: 70
Okay, thanks.
Old 04-25-2019, 04:59 PM   #34
Same here. Small teeth metal; big, ugly teeth, wood. I was using 1/2” EMT for stakes and used an Axe blade. Worked good .
Rey likes this.
Old 04-25-2019, 06:10 PM   #35
Rey
Rewards Points: 70
ok, thanks guys.
Old 04-25-2019, 06:12 PM   #36
Rey
Rewards Points: 70
Who has the best deal on the M12 Fuel Hackzall's?
Old 04-25-2019, 06:27 PM   #37
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 470
I agree with this, if you are doing a good amount of conduit work.
But this...
..is kinda crazy. Since I don't do that much conduit work, I don't use my bandsaw often at all. For the 4-5 cuts I might have to do, I will use my M12 Fuel Hackzawl which cuts thru EMT like butter.
Walking out the the truck for a bandsaw to make 1 cut?
I also walk out to the van to get my bandsaw. The thing is awesome. Use it for EMT and just last week was using it to cut 500MCM copper on a 400 amp service... I had manual cutters beside me but went to get that bandsaw.
tjb likes this.
Vote Kevin for Moderator!
Old 04-25-2019, 07:10 PM   #38
Rewards Points: 2,836
Originally Posted by Forge Boyz View Post
I will walk out to my truck to get the bandsaw a lot of times rather than pick up the sawzall right beside me for even one cut.
I'll walk out to get the bandsaw for one cut but that has nothing to do with saving time. Sometimes I go out and take it out, pull the trigger, chuckle, pull the trigger, chuckle, do that a few more times, then put it away and go back to work.
zac, tjb, Forge Boyz and 1 others like this.
Old 04-25-2019, 07:29 PM   #39
Liberal Lesbian
Rewards Points: 152
I gotta be honest with you, the bandsaw isn't that great.
I primarily use it to cut old 1-1/4" service risers down to 4' lengths when doing a service upgrade and it doesn't cut thru all that quickly. It's pretty good, but nothing that special. And the 5 or 6 cuts I make will bring a new 4.0 battery down to 2 bars. I've noticed that with all my newer 4.0's.
Old 04-25-2019, 07:41 PM   #40
I wonder if you got a lemon. I think I cut more strut than that to get to two bars and that's a lot harder than 1-1/4" conduit.
Milwaukee Tools and 9.0ah battery problems Going_Commando Tools, Equipment and New Products 27 11-22-2018 09:33 PM
Milwaukee M18, 9.0 battery warning 3DDesign Tools, Equipment and New Products 25 07-14-2017 07:22 PM
Harbor Freight Milwaukee Tool Knock Offs active1 Tools, Equipment and New Products 15 04-29-2017 06:46 PM
Issue Resolved-I'm not happy with Milwaukee Tools as a company HackWork Tools, Equipment and New Products 60 10-27-2016 06:16 PM
milwaukee 12v power tools HAL9000 Tools, Equipment and New Products 21 09-19-2016 11:45 PM
