Mobile home dual voltage outlet - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 2 Post By MechanicalDVR
  • 3 Post By emtnut
  • 3 Post By Speedy Petey
  • 2 Post By B-Nabs
  • 1 Post By MechanicalDVR
Old 02-15-2017, 09:47 AM   #1
Rewards Points: 237
Default Mobile home dual voltage outlet
I wired one of these up a long time ago but cant remember what they're called but it's 50 amp 30 amp duplex outlet for 240 and 110 and please forgive me for not explaining it better than that. Mike.
besc is offline   Reply With Quote
Old 02-15-2017, 09:53 AM   #2
Rewards Points: 24,168
Just a typical 60amp RV power outlet:
http://www.houzz.com/photos/53554463...rical-supplies
Used many similar ones for dock side boat use.
Old 02-15-2017, 10:26 AM   #3
Rewards Points: 237
Na. Its not a pedestal. Its like a duplex that you install in a box where the top is 240/120 and the bottom is 120. I think I remember getting at our local ACE hardware. I'll find out and if so let you know.
Old 02-15-2017, 10:28 AM   #4
You mean just a receptacle?
Old 02-15-2017, 10:31 AM   #5
Rewards Points: 237
Ya. You can also get them at mobile home supplies but we don't have one.
Old 02-15-2017, 10:33 AM   #6
Like a Leviton 16292?
Old 02-15-2017, 10:34 AM   #7
The 50amp part is throwing me off.
Many RV receptacles are 30amp 125v.
Old 02-15-2017, 10:39 AM   #8
A TTL-30 receptacle:
telsa and vallyo323 like this.
Old 02-15-2017, 10:46 AM   #9
Rewards Points: 237
Like I said it was a long time ago. I'm not sure I have it clear in my head but I will track it down and share. Thanks. Mike.
Old 02-15-2017, 10:48 AM   #10
Anytime.
Old 02-15-2017, 10:52 AM   #11
I'll add a Leviton 5842
Old 02-15-2017, 12:09 PM   #12
Band Member
emtnut's Avatar
Rewards Points: 2,556
Are you looking for 14-50R and tt-30r in a duplex ?
Never seen one ... why not just use 2 weatherproof boxes with a nipple between them ?
Old 02-15-2017, 02:06 PM   #13
Speedy Petey's Avatar
Rewards Points: 798
Never seen one ...
Me neither. I highly doubt it even exists. Think of how big it would have to be.
I bet it was a dual box with two separate receptacles.
Old 02-15-2017, 03:00 PM   #14
Rewards Points: 1,360
I have seen combination receptacles like posted above, but in the 15 and 20 amp versions. Never laid eyes on a duplex 50/30 amp. It would have to fit in a 3 or 4 gang box...
The Following User Says Thank You to RePhase277 For This Useful Post:
MechanicalDVR (02-15-2017)
Old 02-15-2017, 06:06 PM   #15
Rewards Points: 26,904
I've seen this set up -- but with the 20A replaced by a 30A classic RV receptacle -- and the single pole breaker set to 30A 120VAC.
As you can see, it's a NEMA3R set up.
Old 02-15-2017, 08:50 PM   #16
Watt Pusher
B-Nabs's Avatar
Rewards Points: 484
Never mind how big this 50/30A duplex beast would be, how is it wired? Does it have two separate feeds like 3c #8 for the 120/240 50A and a 2c #10 for the 120 30A? Only way I could see it working and have the overcurrent protection be compliant.
MechanicalDVR and RePhase277 like this.
Old 02-15-2017, 10:00 PM   #17
ppsh's Avatar
Rewards Points: 174
This?
http://www.cesco.com/b2c/product/Mil...metered/665842
ppsh is offline   Reply With Quote
The Following User Says Thank You to ppsh For This Useful Post:
telsa (02-16-2017)
Old 02-15-2017, 10:52 PM   #18
That was my first response based on the OP, he said it isn't a pedestal.
telsa likes this.
Old 02-16-2017, 09:53 AM   #19
Rewards Points: 237
I put this thing at the local zoo a long time ago. My memory very well could be on the outs and yes the size don't jive for my original explanation. When I get around to it I will go to the zoo and see if I even know what I'm talking about. Mike.
Splices and voltage drop swimmer Residential Electrical Forum 17 12-19-2016 09:28 PM
Dual voltage, permanent split induction motor diagrams shockme123 General Electrical Discussion 2 09-18-2016 02:22 PM
Reversing 6-lead single phase dual voltage motor with forward and reversing starter DoktorSleepless PLCs, VFDs, Motors and Controls 26 07-17-2016 01:38 AM
Old mobile home Arikculwell Residential Electrical Forum 23 04-26-2016 11:45 PM
Mobile Home SparkyJ Residential Electrical Forum 10 04-08-2016 07:21 AM
