Mounting Items on a Tiled Wall - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
Old 09-15-2018, 11:58 PM   #1
A Little Short's Avatar
Rewards Points: 958
Default Mounting Items on a Tiled Wall
If you have to drill through a tiled wall (drywall behind tile) and you need to use some type of anchor to mount something, what type anchor have you found that works best for this?
Old 09-16-2018, 12:02 AM   #2
Rewards Points: 6,421
depends on the weight of the item. Could be anything from a red Rawl plug to a toggle bolt.
eddy current likes this.
Old 09-16-2018, 12:03 AM   #3
Jlarson's Avatar
Rewards Points: 4,056
Depends on what it is exactly but for small stuff usually a sharkie or a polyset.
Old 09-16-2018, 12:30 AM   #4
Rewards Points: 958
It's for a range hood vent. They are not venting it so it doesn't weigh much, maybe 10lbs.
Old 09-16-2018, 12:33 AM   #5
greenman's Avatar
Rewards Points: 698
wood screw if u can hit the stud throw the grout
“We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”THE NUCLEAR ELECTRICIAN
greenman is offline   Reply With Quote
Old 09-16-2018, 12:34 AM   #6
If there's a cupboard above, they have keyhole slots to put screws through the top. The screws in the back hold hardly any weight, if they even exist at all.
tjb likes this.
Old 09-16-2018, 12:59 AM   #7
Rewards Points: 958
No cupboard above (or anything) to mount to. I've installed several hoods, including microwave hoods, where you mount to the bottom of cabinets but never mounted one just to the wall.
This particular vent/hood is made to mount that way.
I thought I was just wiring it for them but walked into a surprise when they also wanted it mounted. Had to reschedule due to time and I didn't have a tile bit with me.
I got to thinking about the anchors and don't remember ever having to mount anything over a tiled over drywall wall before.
Old 09-16-2018, 02:45 AM   #8
Southeast Power's Avatar
Rewards Points: 8,612
Buy the fancy red hollow tile bit and use toggle bolts.
daveEM likes this.
Old 09-16-2018, 06:05 AM   #9
MikeFL's Avatar
Rewards Points: 456
Can you give us a link to the product page for this hood?
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 09-16-2018, 08:37 AM   #10
Rewards Points: 792
A hollow wall anchor might be the easiest thing, it will work with a 1/4" tile bit. A toggle is good, but they are a bit of a pain in the ass to use and you have to make a hole in the material much bigger than the shaft of the bolt, so they can shift.
They have little burrs that are made to grip the surface, but you could just flatten them out. You'd just have to buy something with a long enough neck to get through the tile and the drywall, but long neck ones are available.
http://www.shamrockexpress.com/media...chorsmolly.pdf
If it doesn't work out, you can remove it and use a toggle as plan B.
Old 09-16-2018, 08:43 AM   #11
Rewards Points: 1,829
Even if the hood is only 10lbs, there is a lot of leverage since it sticks out from the wall so far. The homeowner puts a hand on it to balance themselves when changing the bulb or filter and next thing you know it's hanging off the wall by the cable.
I would do whatever it takes to mount it to the studs. I often find myself drilling new mounting holes in items in order to fasten them to the studs. Even just one stud is good, then use anchors for the other holes.
After that, I would use toggles.
Old 09-16-2018, 09:11 AM   #12
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,198
Sounds like a "tower" style hood.
Tiled wall.... may not be able to use stud finder.
Cabinet below (cooktop?) If it is , you can look to see where
studs are ...cabinet installer already found them & you'll see
screws thru back of cabinet.
I'm kid of surprised they have an electrician installing the hood.
Usually HVAC or cabinet installers do this in my neck of the woods.
Old 09-16-2018, 09:22 AM   #13
Rewards Points: 990
https://www.homedepot.com/p/Milwauke...-204994400-_-N
i use regular plastic anchors and these small diamond hole saw they work well.
Old 09-16-2018, 01:02 PM   #14
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 242
We commonly install hood fans and sometimes even the duct work for them.... also do duct work for the dryer.
Money is money.
Old 09-16-2018, 03:14 PM   #15
lighterup's Avatar
Money is money.
I've never done duct work where there are permits.
They (AHJ) say that an HVAC contractor has to pull permit for that.
BTW , I don't install microwave hoods either.
I had one builder tell me I needed to install the dishwasher.
No...that falls under the plumbers health department permit.
Old 09-16-2018, 03:42 PM   #16
Rewards Points: 958
I added some receptacles and moved some switches a few months ago. They asked if I would come back and wire the hood and hang some lights when they finished the remodel. So I show up to hang the lights and wire the hood. I didn't see a hood when I got there and asked where it was. "Oh it's in the basement, I'll get it for you"!
I looked at it and agreed to install it while I was there. But if they had called out of the blue and asked me to install just the hood with no other work I would have declined.
Old 09-16-2018, 03:47 PM   #17
I don't do ducting or venting. But if the duct is already there I will install a bath exhaust fan or vent hood.
I also have no issue installing non-vented recirculating hoods. They are easy and profitable.
Old 09-16-2018, 04:04 PM   #18
Switched's Avatar
Rewards Points: 9,060
I will install bathroom exhaust ducting, but not a kitchen hood duct.
Old 09-16-2018, 04:05 PM   #19
Rewards Points: 958
Yeah, I install those too along with micro-hoods and also don't do venting. But this being a stand alone to be mounted on a tile wall I wouldn't normally do.
HackWork likes this.
Old 09-16-2018, 04:27 PM   #20
lighterup's Avatar
I want to clarify.
I will do any of these type jobs if I don't need an hvac permit .
This usually means remodels.
On new construction , I decline hvac scope of work because that's not
what I bid to do and 9 out of 10 times a home builder is trying to
"push this off" as electricians scope of work and I say it's not. They are just
trying to get me to do something for nothing. They're not offering to pay it
as an extra , they're acting as if it should be in the bid to begin with and
that would be a losing argument , cause all one has to do is read the description
of what an electricians state license is vs a state licensed HVAC contractor.
It's (ventilation / hoods etc) are clearly in the HVAC contractors scope.
But if you can make more money doing this ...go for it.
PV conduit inside exterior wall permitted? katwalatapan Alternative Energy Forum 11 12-05-2016 01:09 PM
Wire into bottom of insulated wall BobN Residential Electrical Forum 12 07-23-2016 09:01 PM
Venting, not HVAC 220/221 General Electrical Discussion 6 07-07-2016 11:09 AM
Hanging heavy lights on a furred wall. Year_Zero General Electrical Discussion 16 02-25-2016 07:38 PM
locating conduit or LV cable behind wall or missing conduit end? lortech Structured Wiring 3 01-18-2016 01:35 PM
