Need help. Iím baffled - dead outlet - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 1 Post By LARMGUY
  • 4 Post By HackWork
  • 1 Post By E-Rack
  • 3 Post By frenchelectrican
Closed Thread
Old 09-14-2018, 09:32 PM   #1
Rewards Points: 6
Default Need help. Iím baffled - dead outlet
Hello. Thanks in advance for the help/advice. I will do my best to give all details.
State- Washington
Built- 2008
Type- condo
Now to the problem; outlet just stopped working. Itís a washing machine outlet dedicated. Electrical box has 20 amp breaker, outlet has 15 amp standard outlet. Everything has been working fine until 2 days ago. The outlet just went dead, washer does not turn on, it died mid wash. I thought maybe the breaker tripped so I reset it multiple times, nothing. I purchased a new breaker thinking maybe it just went bad, nope, new one does the same. I replaced the outlet with a new gfci and still nothing. The outlet is tripped and wonít reset. I put a sniffer to the hot wire and it lights up. I put a outlet tester in and nothing, no lights. I tested both on an outlet in the hallway and both work.
I have read that both the breaker and outlet should be rated the same. This was apparently not done when the house was built, same with it not being a gfci outlet. Iím not sure what WA state code is, thatís why I included where Iím from.
I believe Iíve given all the info, if I missed something
Let me know. Again, any help is greatly appreciated. My next move is to go buy a standard outlet, my only concern is the box is directly below the hot/cold lines.
E-Rack is offline
Old 09-14-2018, 09:35 PM   #2
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 526
ibtl
wildleg likes this.
Cowboy words of wisdom.
LARMGUY is offline
Old 09-14-2018, 09:36 PM   #3
Bird dog's Avatar
Rewards Points: 1,232
This site is for electrical pros only. Please post on...
https://www.diychatroom.com/
Bird dog is online now
Old 09-14-2018, 09:38 PM   #4
Bird dog's Avatar
Dominoes delivers!
Old 09-14-2018, 09:42 PM   #5
Rewards Points: 6
If itís full of pros then I came to the right place. Why would I want to ask a plumber a question about electrical?
E-Rack is offline
Old 09-14-2018, 09:53 PM   #6
Rewards Points: 1,373
It is most likely illegal for you to do this in a condo.
The reason is because if you do it in your own house you are only risking the lives of yourself and your own family. If you do it in a condo, you are risking the lives of all the other people.
Hire an electrician. Everything you said is way off base, nowhere near what you should be doing. You are wasting your time and if something goes wrong I think they should file manslaughter charges on you.
HackWork is online now
Old 09-14-2018, 09:58 PM   #7
Rewards Points: 6
Well, I didnít expect someone with 27k plus post to be a troll. Thanks for your advice.
Kevin_Essiambre likes this.
E-Rack is offline
Old 09-14-2018, 10:06 PM   #8
Modťrateur
Rewards Points: 16,692
Erack.,
Just stop right there and you are NOT aware of your state law saying the condos it have a electrician come out and do the repair on the condos.
same rules applies to the apartment complexes too.
I going close this thread on this one.
oh yuh please do not get Hackwork ticked off.,, he gave you a hard direct answer to your situation.
readydave8, HackWork and 99cents like this.
frenchelectrican is offline
Signal1 (09-14-2018)
Closed Thread
Old outlet stuck to plate rant bostonPedro General Electrical Discussion 3 05-19-2018 11:43 AM
adding an outlet off a Dimmer switch iluvspl General Electrical Discussion 2 01-19-2018 08:14 PM
Running outlet off exsisting one COwboys518 General Electrical Discussion 5 03-02-2017 06:55 PM
Troubleshooting outlet not working 3DDesign General Electrical Discussion 17 06-17-2016 06:00 PM
