Neon Sign in Residential Dwelling Unit - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
Old 03-04-2016, 06:52 AM   #1
Rewards Points: 14
Default Neon Sign in Residential Dwelling Unit
I have just been asked by a designer to wire a remoted transformer in a crawl space, with two 1/2 inch greenfield leads to a skeleton tubing neon sign in the game room just above. Having never hard wired for this type of installation before I went right to article 600 to see what the code requirement would be. The secondary voltage of the transformer for the sign is 9000 volts so I started reading in 600.32 and believe I found the deal breaker in 600.32 ( i ) which states, Equipment having an open circuit voltage exceeding 1000 volts shall not be installed in or on dwelling occupancies. I believe the code is referring to the secondary output voltage of the transformer when it says "open circuit voltage".
If anyone could confirm that my interpretation is correct, I want to have my ducks in a row as I am about to say no to the signs instalation and create a lot of unhappy faces. Thanks
A6USMC is offline   Reply With Quote
Old 03-04-2016, 07:29 AM   #2
Retired Account
Rewards Points: 14,650
Default rutt roo....
(I) Dwelling Occupancies. Equipment having an open cir-
Could it be you've just trashed every dwelling store front from sea to freakin' shinin' sea A6...? ~CS~
Old 03-04-2016, 07:51 AM   #3
V-Dough's Avatar
Rewards Points: 225
You best ask your inspector. Im not sure how it works in States but here we can get field approvals for equipment that isnt ULC or CSA certified... Maybe he would allow it that way.
And if that isn't an option, get the designer to switch to LED 'neon' tubes
V-Dough is offline   Reply With Quote
Old 03-04-2016, 08:10 AM   #4
Rewards Points: 14
I don't feel I have "trashed" anything, I am just asking a group of trade professionals their take on the wording and intent of the written code, so that I might make the proper interpretation of the code.
Old 03-04-2016, 11:03 AM   #5
Rewards Points: 20,713
I have always considered that it means no neon in dwellings if the secondary output of the neon transformer is 1,000 volts or greater.
They make led's that look pretty close nowadays.
Nationalize all foreign owned farmland now. Now.
A6USMC (03-04-2016)
Old 03-04-2016, 01:48 PM   #6
Rewards Points: 7,869
What kind of conductors were you planning to use? I don't recall ever seeing 9000v. conductors in flex.
Old 03-04-2016, 03:50 PM   #7
Retired Account
What is the meaning of 'open circuit voltage' here?
Old 03-04-2016, 05:09 PM   #8
No load voltage.
Old 03-04-2016, 05:22 PM   #9
Retired Account
I was hopin' for something along the lines of 'exposed contacts' Joe.....~CS~
Old 03-07-2016, 10:47 PM   #10
Rewards Points: 375
During my career as maintenance supervisor for a chain of stores, every neon conductor was routed from the transformer to the sign can with greenfield, including voltages in excess of 14,000. It's common practice.
Missouri Bound is offline   Reply With Quote
Old 03-08-2016, 01:16 AM   #11
V-Dough's Avatar
Rewards Points: 225
Whats a greenfield?
GTO wire (15KV rating) is standard for neons. You can also run any wire you like in a GTO sleeving (like a stiff heat shrink). As far as conduit usually liquidtight metallic flex but the lenght has to be limited due to capacitance effect.
Old 03-08-2016, 01:48 AM   #12
Rewards Points: 23,894
Originally Posted by V-Dough View Post
Whats a greenfield?
Greenfield is the metal armor jacket on MC and Bx.
V-Dough (03-08-2016)
Old 03-08-2016, 02:26 PM   #13
Rewards Points: 375
Well..........almost.
They look alike, but greenfield is not the same as bx. Bx doesn't have the continuity that greenfield does nor the flexibility. BX is just a wrap over wires where greenfield is a flexible conduit.
Old 03-08-2016, 03:53 PM   #14
Does it really have to be that specific ? I'm sure the description I gave is adequate for someone that asks what 'greenfield' is. Do you honestly think the armor on bx and mc made by one manufacturer is different ? And YES I KNOW THEY COME IN STEEL JACKET AND ALUMINUM !!
Old 03-09-2016, 01:30 PM   #15
RGH
RGH's Avatar
Rewards Points: 2,044
Bx was a slang name for Mc back in the day when it was made by the Bronx wire Company of New York. Mech D , like myself is an old timer and that's what we all called it just like we still call and nm romex been calling that stuff that way for 35 years now we have to be politically correct I guess like everything else
donaldelectrician likes this.
I rather be fishing......
RGH is offline   Reply With Quote
The Following User Says Thank You to RGH For This Useful Post:
donaldelectrician (03-09-2016)
Old 03-09-2016, 08:39 PM   #16
neutral member
readydave8's Avatar
Rewards Points: 260
I'd always heard that "x" stands for experimental, and that type "ax" didn't work out, sometime around the year 1900
Dave Ruth
readydave8 is online now   Reply With Quote
Old 03-09-2016, 11:54 PM   #17
Rewards Points: 1,539
TRUE
That is the way of " BX "
We will always call it that ....
Like the steel heavy Greenfield of the old days ...Man is that heavy ...
can not mistake it to the stuff today , or the weight .
I will always SAVE all old GREENFIELD , it is really a different Product
than other stuff you will find in the market with way better Qualities ...
Charge more for it ... Top Quality . Better for certain Work .
Don
donaldelectrician is offline   Reply With Quote
Old 03-10-2016, 12:13 AM   #18
Take it from a Real Old Timer , " Greenfield " the old stuff . is a " Heavy Gauge Steel Wrapped / corogate Pipe /tube / flex / system
Kinda explain it .
Very Heavy in weight and content / steel and thick gauge /hard to cut .
The best product out there by far .
It is sold empty / so wire is added later / different grounding rules apply /
always better to pull a Ground with it /
Oh when you Find It on Jobs ...RIP IT OUT AND PUT IT ON TRUCK !!!
RESTOCK ON TRUCK .
LOVE THAT STUFF .
Don
Old 03-10-2016, 12:26 AM   #19
WE RIB ANYBODY ....
FIRE AWAY
MAN THE GUNS
FILL THE BEER
FILL THE BEER
FILL THE BEER
Don
Old 03-10-2016, 09:38 AM   #20
To me BX was always conductors with maybe a thin aluminum wannabe ground in steel armor, MC was always conductors with a copper ground conductor usually in aluminum jacket. Not sure your idea back in the day. Did they have bx on the wagontrain west ?
Dwelling unit explained? TechieBecky General Electrical Discussion 11 01-31-2016 08:35 PM
