Old 3 way Wiring - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
  • 2 Post By telsa
  • 1 Post By WronGun
  • 3 Post By WronGun
  • 3 Post By Majewski
  • 1 Post By drewsserviceco
  • 2 Post By Majewski
  • 3 Post By macmikeman
Old 12-29-2017, 02:13 PM   #1
WronGun's Avatar
Rewards Points: 702
Default Old 3 way Wiring
Losing my head a little bit. Is there another method they used to wire 3-way switches 60-70 yrs ago ?
Iím working on a known 3-way circuit that I canít put back together with conventional wiring methods.
It seems this was working before with only 1 wire between each 3 way box as a traveler
Line on 1 switch load on the other
Old 12-29-2017, 03:15 PM   #2
Rewards Points: 26,838
1) Identify line side cable -- both hot and neutral -- they become big clues.
Wire nuts and a voltage tic do wonders on this front -- that and flicking the breaker.
You should find that BOTH boxes are line-side entry j-boxes.
You should find that the Neutral and the Hot are landed upon the 3-way switch...
with the Common pole running off to the lamp -- as just one wire -- from each j-box.
You should also expect that only one 120VAC lamp is on this weird switch leg.
2) Go to David E. Shapiro's "Old Electrical Wiring" page 57 for the wiring diagram.
ISBN 0-07-057879-6
If you STILL don't own this tome and you're working the Residential Repairs Beat -- then go to the back of the class.
Shapiro covers a LOT more than Carter 3-ways.
WronGun, ET has beaten the Carter 3-way to DEATH.
chicken steve and WronGun like this.
Old 12-29-2017, 04:57 PM   #3
Retired Account
Rewards Points: 14,650
yup..... Carter 3W.....~CS~
Old 12-29-2017, 05:01 PM   #4
WronGun's Avatar
Rewards Points: 702
Yup drove us nuts for a bit.... first time ever seeing this method.
chicken steve likes this.
Old 12-29-2017, 05:04 PM   #5
WronGun's Avatar
Rewards Points: 702
You know your in trouble when you find this book left behind by the previous Home
Owner~1960
Old 12-29-2017, 06:46 PM   #6
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,820
Owner~1960
I want this on my dash board everytime I wait to meet someone, so they can see it and lose all confidence before shaking my hand.
Old 12-29-2017, 07:41 PM   #7
drewsserviceco's Avatar
"You think that's impressive? You should see Complex Electric Wiring, it's a three volume set!" - Majewski
Majewski likes this.
Old 12-29-2017, 07:51 PM   #8
Majewski's Avatar
A menards or home depot book would suffice.
MTW and telsa like this.
Old 12-31-2017, 12:35 PM   #9
Rewards Points: 2,149
Code wise the problem with the 1 wire 3 way is it reverses the lamp connection depending on the switch position. So the shell could be energized.
To make things worse a person might think there is no electrical potential because the switch turned off the lamp. When it could be no neutral, with the shell and center socket energized. That's another code problem is switching the neutral only without the hot is not permitted.
Then there is all conductors need to be run together violation. Because the hot is from one direction and the neutral is from another.
When it was in conduit we would rewire the circuit.
I understand the problem with cable or even K&T in finished walls.
But at some point it really should be corrected.
Also should look to see if it has a EG.
At least if you could install lamps without screw in sockets, such as LEDs, you wouldn't have the energized socket.
Another possibility is you could wire it like a SP switch and install wireless 3 ways.
Or is the 3 way still needed. Sometime homeowner remodels will leave old switches but remove the door.
Old 12-31-2017, 12:38 PM   #10
WronGun's Avatar
Rewards Points: 702
We actually went with a The Lutron Wireless set-up
Old 12-31-2017, 01:56 PM   #11
Rewards Points: 20,929
Owner~1960
As a true nerd in high school, I saw that book in the school library, and checked it out. I didn't try any experiments at home , just found it highly interesting and it sparked an interest that led me to desiring to become an electrician. I love my trade, thats a true confession. I don't always like dealing with my customers and doing business, but I truly love my trade.
All that started with that there edition of that there book.
lighterup, WronGun and B-Nabs like this.
Old 01-03-2018, 07:18 PM   #12
WronGun's Avatar
Rewards Points: 702
I took the book home , suppose itís good to have to reference old wiring.
No carter 3-way though , that must of been far before 1960?
Old 01-03-2018, 09:46 PM   #13
Modťrateur
Rewards Points: 21,898
Ya it further than 1960 in fact it was start used from edison days and the NEC code do not allow it in 1930's for a good reason due the shell can be switched between hot and netural.
but ya still see it from time to time especially with older home with tube and knob system in there.
you may have to goggle some older three way diagram to get the idea.
Line voltage and control wiring in same JB katwalatapan Canadian Electrical Forum 10 10-21-2017 08:00 AM
Fire Alarm wiring stdave General Electrical Discussion 7 10-03-2017 08:45 PM
Damaged wiring inside a water heater - questions Islander General Electrical Discussion 14 01-01-2017 04:37 AM
Wiring Left in Distribution Panel Hdinj Code Violation Discussion 26 02-07-2016 11:31 PM
NPLFA circuit wiring khfiei General Electrical Discussion 5 02-05-2016 11:03 PM
