Old work fixture support box?? - Electrician Talk - Professional Electrical Contractors Forum
Old 06-24-2015, 11:39 PM   #1
Rewards Points: 184
Default Old work fixture support box??
I do a lot of high end kitchens with pendants over islands and locating them exactly during the rough is next to impossible since sometimes they get moved to make walkways larger. I usually leave coils of wire in the ceiling and let the rockers cover it, then cut in old work ceiling boxes on the final. I haven't had any issues with inspectors until now, he's calling me out on the fact that they're not rated for a fixture. how is everyone else going about this? I'm always open to new ideas. Thx
NJSparky is offline   Reply With Quote
Old 06-24-2015, 11:42 PM   #2
corn-fused
papaotis's Avatar
Rewards Points: 620
depends on the weight of the fixture. if the arent rated for a fixture what are they for?
Old 06-24-2015, 11:47 PM   #3
Rewards Points: 184
Straight from Carlon's website
What is the weight limit for your old work round box #B618R if you are
hanging a light fixture from the ceiling.
The B618R is a round old work outlet box and is not listed for fixture support in
the ceiling. Only approved ceiling boxes are allowed to support fixtures in the
ceiling. These boxes will be permitted to support a minimum weight of 50
pounds. The B618R can be used in the ceiling as a junction box. Do not hang a
fixture from it since it relies on the strength of the ceiling itself
Old 06-24-2015, 11:47 PM   #4
backstay's Avatar
Rewards Points: 296
If you're talking about a blue winged box, they are not listed for fixture support.
Old 06-24-2015, 11:50 PM   #5
corn-fused
papaotis's Avatar
Rewards Points: 620
and those answered my question. satisfied?
Old 06-24-2015, 11:56 PM   #6
Rewards Points: 26,360
http://www.homedepot.com/p/Raco-Retr...-936/203743171
This ^^^ is the kind of old work box suited for pendants.
If a beam is right in the way -- go with a classic pancake -- perhaps with some additional blocking.
Old 06-24-2015, 11:57 PM   #7
Rewards Points: 184
I'm only having this issue in 1 town, he told me if i was gonna old work them, i had to use a fan support box or a pancake right on the joist. Than I bet he bangs me for box fill with the pancake since they're daisy chained.
Old 06-24-2015, 11:59 PM   #8
Rewards Points: 184
Thx, this is exactly the sort of thing I was looking for.
Old 06-25-2015, 03:25 AM   #9
There's a general tendency to forget that many listed fixtures actually have a cubic inch allowance for conductors -- THEMSELVES.
In this, they are very much like mud rings/ plaster rings -- which also have a cubic inch allowance.
You may have to poke around, but the typical pendant has as much wire space to work with as the pancake, itself. When this is true, daisy chaining 14-2 is not going to bust through the Code limit.
Old 06-25-2015, 08:51 PM   #10
Rewards Points: 318
Speaking of crappy blue boxes, can someone tell me what they have used this box for or if anyone has? A switch fed by a switch loop with 14/2 would still be a violation of code by exceeding the 8ci box fill? I've never seen one used.
http://t.homedepot.com/p/Carlon-1-Ga...-UPC/100404057
Jay82304 is offline   Reply With Quote
Old 06-25-2015, 09:26 PM   #11
Rewards Points: 864
[QUOTE=Jay82304;2061202]Speaking of crappy blue boxes, can someone tell me what they have used this box for or if anyone has? A switch fed by a switch loop with 14/2 would still be a violation of code by exceeding the 8ci box fill? I've never seen one used.
I've seen a few usually used by Joe the handy man who knows no better, they usually get ripped out for the correct box.
On a different note to the OP watch the fixture canopies cubic capacity. Doesn't it have to be stamped inside somewhere? Just saying as the inspector sounds like a d#ck.
Pride is doing what you know is right especially when no one else is looking.
Sparky J is offline   Reply With Quote
The Following User Says Thank You to Sparky J For This Useful Post:
danhasenauer (06-27-2015)
Old 06-25-2015, 09:54 PM   #12
LawnGuyLandSparky's Avatar
Rewards Points: 172
I suggest you either hone your ceiling layout skills and eliminate the problem alltogether
Old 06-25-2015, 10:08 PM   #13
ponyboy's Avatar
Rewards Points: 709
Ten four. Buy a laser bob and tell those ****ers you're laying out the ceiling with the plans you were given and if it changes there will be charges. If they're that high end they shouldn't mind paying you to get the pendants right on the nuts.
Old 06-25-2015, 11:01 PM   #14
Rewards Points: 84
What about the allied flange boxes
http://www.alliedmoulded.com/catalog...rt-boxes/9305/
tceek is offline   Reply With Quote
Old 06-25-2015, 11:17 PM   #15
canadian-dj's Avatar
Rewards Points: 14
I was just about to say this
canadian-dj is offline   Reply With Quote
Old 06-25-2015, 11:20 PM   #16
Rewards Points: 12,825
Exactly. If they want it moved after the fact, it's a service call and they can do the patching.
Laser plumbs rock .
Old 06-26-2015, 01:29 AM   #17
backstay's Avatar
Rewards Points: 296
Originally Posted by tceek View Post
How is that going in as old work?
Old 06-26-2015, 05:15 PM   #18
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
Boxes for ceiling fixtures have to be rated to support 50 pounds minimum. I don't think I've seen an old work box that has that rating. 314.27(A)(2)
Life is hard
Old 06-26-2015, 07:24 PM   #19
For LV use, and not too many of those.
You'd go that way if there was a filthy stud bay (retro re-hab) and you wanted to box-in for a door-bell/ intercom/ CAT 5e -- and shield the connection from falling junk.
It also can handle a 14-2 switch-leg:
In 2"
Out 2"
Yoke 2"
Ground 2"
Sum: 8"
No neutral, of course.
It's a size shunned by ECs, of course.
Old 06-26-2015, 07:35 PM   #20
"Brace is designed for maximum support load of 75 lbs. ceiling fans or 110 lbs. light fixture on 16 in. joist span."
Strictly speaking, this IS an old work box designed for cutting in.
The technique presumes a hole-saw penetration -- and then the gadget is worked up and through the hole -- the arm, first -- and cranked into position between the lumber. This puppy can even reach out to 24" O.C. joists.
Its design causes it to sit -- just 'so' -- Then the box itself is anchored to the bracing bar -- which then puts the face of the box in the correct spot.
Before the box is shoved up, the Romex is stubbed into it, some slack is permitted in old work situations, of course.
Many j-men could go years at a stretch without touching one of these puppies. They really are a one-trick pony.
Wall sconces use a different old work box entirely, as the brace is no help in a wall cavity.
stevek (07-20-2015)
Fixture support... T&K General Electrical Discussion 9 05-21-2014 04:48 PM
Fixture support Magnettica General Electrical Discussion 12 03-01-2012 10:53 PM
junction box support. kaboler Canadian Electrical Forum 17 11-20-2011 09:17 PM
Box Support rlc3854 NEC Code Forum 7 02-09-2011 09:39 AM
box support voltz General Electrical Discussion 6 09-13-2010 02:02 AM
