P&S AFCI/GFCI Receptacle Issues - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By Switched
Old 02-21-2017, 12:35 PM   #1
Rewards Points: 804
Default P&S AFCI/GFCI Receptacle Issues
We've install a few P&S AFCI/GFCI receptacles and we've had issues with them nuisance tripping. Anyone else having issues with P&S? I will try a different brand see if I get different results.
Old 02-21-2017, 04:14 PM   #2
drspec's Avatar
Rewards Points: 1,114
Ive used very few P&S in the past few years but don't recall any issues with the ones weve installed
Weve been using Hubbell for several years now and install hundreds a year and as far as I remember weve only had a few give us any trouble. Maybe half a dozen.
Old 02-21-2017, 06:54 PM   #3
sbrn33's Avatar
Rewards Points: 3,252
never used one. I just change the breaker. It would piss me off as a customer to find one tripped behind a china cabinet.
Old 02-21-2017, 07:43 PM   #4
Can't Remember
Rewards Points: 878
I use these on kitchen counters where there are the FPE/zinsco panels in apt closets. This is the best I can do when it comes to receptacle replacement. I may have used one. I have had a couple of the leviton receptacles trip. One was a bad light fixture, so not its fault, the second happened earlier this week, not sure what the issue was, other than the tenant had trouble resetting it due to the force required to reset it. Is it a perfect solution, no, but about the only card I can play.
Old 02-21-2017, 07:52 PM   #5
Rewards Points: 804
It seems like I've been getting callbacks an the AFCI/GFCI receptacles with P&S brand. I'm going to put Easton in and see if it resolves the nuisance tripping issues.
Old 06-07-2017, 10:39 PM   #6
MTW
MTW's Avatar
Rewards Points: 7,984
Old 06-07-2017, 11:04 PM   #7
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
Where you getting them? I use almost solely legrands from viking and not a single issue (knock on wood).
Old 06-07-2017, 11:18 PM   #8
Switched's Avatar
Rewards Points: 8,858
Don't knock your wood too hard....
I'm with Sabrina... I change out the breaker. Trying to explain to a customer where the stupid reset is.. much easier on the CB.
Majewski likes this.
Old 06-08-2017, 09:55 AM   #9
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,046
If I may ask , is this topic about GFCI/AFCI devices? ...or is the OP
talking about duel function CB's? I have not seen devices yet.
Melted split receptacle tabs otif Residential Electrical Forum 21 10-26-2016 09:07 PM
CEC regulation on light and receptacle on same circuit katwalatapan Canadian Electrical Forum 13 10-19-2016 02:39 PM
New sump pump receptacle on an old circuit. Mugs Canadian Electrical Forum 14 07-30-2016 10:30 PM
Gfci receptacle feeds pool receptacle. Pool pump trips gfci and an hour or less Chevyman30571 Residential Electrical Forum 21 06-08-2016 12:47 PM
Are those little round ears on a receptacle grounded? JasonCo General Electrical Discussion 13 01-26-2016 10:42 AM
