Replace a 20 amp fuse - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 1 Post By The_Modifier
  • 1 Post By circuitman1
  • 4 Post By LuckyLuke
  • 2 Post By DesignerMan
  • 1 Post By Southeast Power
Old 11-05-2017, 07:56 PM   #1
Rewards Points: 12
Default Replace a 20 amp fuse
Can I replace a 20 amp fuse with a 15 amp fuse?
MrDmitrij is offline   Reply With Quote
Old 11-05-2017, 07:58 PM   #2
Rewards Points: 2,149
If it fits it ships
Old 11-05-2017, 07:58 PM   #3
Rewards Points: 21,856
It depending on type of fuse it is in there.
what kind of load it is serving there?
Old 11-05-2017, 08:01 PM   #4
Rewards Points: 26,360
Down fusing is permitted.
However, you just hardly ever run across this situation.
Old 11-05-2017, 08:18 PM   #5
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 244
Ibtl!
The Following User Says Thank You to The_Modifier For This Useful Post:
MechanicalDVR (11-06-2017)
Old 11-06-2017, 12:42 AM   #6
Magic Smoke Remover
Rewards Points: 1,966
It may not fit. I tried to replace one once and the 15 wouldn't make contact where the 20 would.
Old 11-06-2017, 11:44 AM   #7
Rewards Points: 660
edison base are easily interchangeable, that's why they came up with the "S" type. they made it harder to interchange.
Signal1 likes this.
circuitman1 is offline   Reply With Quote
Old 11-06-2017, 11:55 AM   #8
LuckyLuke's Avatar
Rewards Points: 546
Are you talking residential type fuse or control fuses etc? Are you using the same class fuse? Same SCCR? Same voltage rating?
It's not that I am afraid to die, I just don't want to be there when it happens.
LuckyLuke is offline   Reply With Quote
The Following User Says Thank You to LuckyLuke For This Useful Post:
hardworkingstiff (11-06-2017)
Old 11-06-2017, 05:47 PM   #9
Rewards Points: 12
I'm talking about residential fuse, type TL.
Old 11-06-2017, 05:51 PM   #10
Rewards Points: 2,812
'TL' so a basic Edison type fuse!
Exacty what type of 'electrical engineering' do you do?
Southeast Power (11-07-2017)
Old 11-07-2017, 07:52 AM   #11
DesignerMan's Avatar
Rewards Points: 443
I wouldn't expect an EE (especially a young one) to have much knowledge of Edison fuses. That's for us old fart electricians lol.
circuitman1 and MrDmitrij like this.
Welcome to Amish Country!
DesignerMan is offline   Reply With Quote
Old 11-07-2017, 08:22 AM   #12
Southeast Power's Avatar
Rewards Points: 8,612
Lol, I remember working around the outside of those with a pocket knife then pulling out the threaded part with the fuse.
Then you have to put your knife under the that straight spring while backing it out.
All of that only to stick a screwdriver in the socket to tighten the screw connecting it to the bus.
Then screwing in an Edison base fuse.
$36 for the service call, $2.50 for the fuse.
I remember going from $36 to 37.50, then 39. Once we jumped to $42 per hour and thought we would lose all of our customers.
Those were good days.
circuitman1 likes this.
Mystery Fuse Blow Aegis General Electrical Discussion 16 08-17-2017 06:07 AM
three phase motor disconnect switch fuse: overload or overcurrent? mike883 General Electrical Discussion 5 05-01-2016 12:51 AM
how do we know what kind of class for the transfomer fuse or switch gear DS fuse ? mike883 General Electrical Discussion 1 04-30-2016 04:44 PM
Harmonic Filter Fuse glen1971 PLCs, VFDs, Motors and Controls 2 04-06-2016 08:14 PM
Upgrading and outdoor screw-in fuse box to a circuit breaker type box Jimmi328 Residential Electrical Forum 2 03-26-2016 09:09 PM
