Replacement Bath fans ...no patching? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
Old 10-01-2016, 10:06 AM   #1
Rewards Points: 321
Default Replacement Bath fans ...no patching?
Hi,
I usually let customers buy parts like lights, ceiling fans, and bath fans. however, I've had to install some awful bathroom fans when doing replacements in a finished ceiling.
Often I have to cut metal brackets with a sawzall because the mounting screws to the joist aren't available without making a bigger hole (so I've drilled and screwed through the side of the casing).
There have been a few times when I felt that the mounting system was not secure (in an old plaster ceiling for instance).
More than once, I've had to move a fan to a joist because the old one was attached to a crappy "frame" that someone made in the ceiling, but if there were a secure mounting system, maybe I wouldn't have to?
So, I'm at the point where I'd like to call the shots on products, but I haven't done enough of these jobs (or often enough to remember) to have a favorite brand or anything...
*Are there any rehab fans that don't need to be attached to a joist (that you feel are secure -I don't want a call back!!!)?
*Are there rehab fans that you feel are easier to install and do minimal damage to the ceiling?
I don't care that much about money ($100-$250 depending on CFMs/Sones) because I have enough work to be able to tell a potential customer "my way or no way".
Thoughts? Suggestions? Recommendations?
Thanks!
adamthebman likes this.
Greg Sparkovich is offline   Reply With Quote
Old 10-01-2016, 10:10 AM   #2
Rewards Points: 2,222
We pretty much use Panasonic fans however I am not sure if you can use them in the middle of the joist.
Greg Sparkovich (10-01-2016)
Old 10-01-2016, 10:13 AM   #3
Here is some info on it http://business.panasonic.com/FV-08-11VF5.html
Majewski likes this.
Old 10-01-2016, 10:41 AM   #4
Rewards Points: 1,713
What about replacement parts? We have a parts bandit here who carries good stock for Broan/Nutone and Softaire. All the guts come in a package if that's what you want.
Old 10-01-2016, 10:52 AM   #5
Rewards Points: 321
Thanks for the suggestion and Yep, sometimes I do that.
...Although I have only done this with low-end innards.
In this case, I am going to be replacing 3 smaller fans with bigger ones, so I know I will have to remove the old ones and cut some of the ceiling to fit the larger casing.
So, for this job, I want to find a fan that is easy to mount in an existing ceiling.
Old 10-01-2016, 10:53 AM   #6
Rewards Points: 26,836
Why re-rough ANYTHING ?
These puppies aren't exactly turbo-jets.
The industry has settled on to various 'frame sizes' -- same as NEMA.
Get new guts to replace the old guts, DONE.
You wouldn't happen to suffer from electrician's OCD ?
Jmcstevenson and Majewski like this.
Old 10-01-2016, 11:06 AM   #7
The hole for a fan should be big enough to scab some extra lumber up there. Some 2 X 4 and framing screws should work. Even if you fasten the 2 X 4 to the drywall, that's only a few screw holes to fill.
I like the Softaire fans. They have the flange. I wonder if you could screw a couple of 2 X 4's to the drywall and then attach the fan through the flange holes from below? Never tried it. I'm thinking lay the 2 X 4 flat on the drywall.
Old 10-01-2016, 11:14 AM   #8
Rewards Points: 321
I have seen lots of rehabs where contractors cut every corner to make a dime. Having a small fan in a powder room is fine, but what about the master suite? Should I just replace their dinky 80 CFM fan parts? That is not my business model!
*I* don't live there -so I don't know what it's like to take a shower there -*they* do. And my customers don't have to live to my standards anyhow.
I have no objection to saving customers money or telling them that they don't need something (I've certainly talked enough people out of a 200amp service), but unless there is a reason, I do what my customer wants. It's one reason they like me and I'd guess why I'm booking into December.
Old 10-01-2016, 11:20 AM   #9
Rewards Points: 321
Thanks; I don't know the softaire fans. Do you like them better than Panasonics (I've heard good things but I don't remember ever installing one)?
I want to avoid adding lumber if I can though. I wish there was a frame like a fan-fast (Those threaded braces that fit between joists so you can hang a ceiling fan)...
Old 10-01-2016, 11:32 AM   #10
Softaire/Reversomatic is the best bang for the buck. Panasonic is overpriced. Check your dimensions, though. SA-90S is my go-to upgrade fan. It's 8" high. Super quiet, quieter than Panasonic (with apologies to Dennis).
http://www.reversomatic.com/wp-conte...A-90S-new1.pdf
Greg Sparkovich likes this.
Old 10-01-2016, 11:34 AM   #11
drspec's Avatar
Rewards Points: 1,120
what do you do about the undersized ducting? Im noticing a lot of the newer fans are calling for 6" duct, while most of the existing fans are 4" and some are only 3".
The Following User Says Thank You to drspec For This Useful Post:
telsa (10-01-2016)
Old 10-01-2016, 11:41 AM   #12
Ya think ?
Old 10-01-2016, 11:43 AM   #13
Rewards Points: 1,435
It doesn't work like that. Last week my customer bought the same exact exhaust fan that they had and wanted me to install it. But when I opened the old one, it was a different motor and completely different method of mounting it. To make things worse, the box of the new one was about 1/2" larger and I had to open up the hole that had wood framing around it.
There are no standards.
B-Nabs likes this.
Old 10-01-2016, 12:02 PM   #14
Ya think ?
Even the Broan garbage is overpriced in comparison.
Old 10-01-2016, 01:11 PM   #15
Rewards Points: 321
If I don't go to do an on-site estimate (and I avoid that like bad beer), then I ask the customer to find out by taking a picture at least. If the person feels comfortable taking the cover off, then I get a pic of the label. If I can match the model, I'll know what to expect and buy accordingly. I have had customers who bought the wrong fan before contacting me and I just tell them what to get after I've looked inside (Or I can get it myself). I charge extra for that visit according to how much of a pain it was to get there. I'm sympathetic that they tried, but that's the downside of them choosing without paying or just asking for my expertise.
I don't mind doing some planning for my customers while I watch Walking Dead. I'd rather save time by getting info than make money when they make a mistake -nobody ever feels good about that and I never want a customer to feel like I'm not doing enough for them.
That's kind of why I'm posting about this...
I don't do enough fans to feel like I'm 100% on game with this, so I'd like to eliminate some of the guess work on installations. I figured since it's 3 fans at the same property, I'd get a little education.
Old 10-01-2016, 02:20 PM   #16
drspec's Avatar
You still didn't answer my question. Do you use reducers for 4" fans when 3" duct is existing or replace the ducting?
If you don't upsize the ducting then upgrading the fan is pointless imo.
telsa likes this.
Old 10-01-2016, 05:07 PM   #17
Can't Remember
Rewards Points: 1,434
Some the panasonics come a with a nice old work bracket that works well between joists. At least in drywall, I rarely end up with any patching. These often come with a 3 to 4 reducer. Broan/Nutone has the same bracket with some of their higher end units. The panasonic I prefer is the shallow model without the normal 4 inch end, not the oval exhaust. Before these retrofit brackets, I would cut the opening a little larger than needed, test fit, then screw some strapping or plywood strips to the drywall. Put the fan up and and screw through the holes in the flange through the drywall and into the wood strips.
Old 10-01-2016, 08:01 PM   #18
Rewards Points: 386
I love the nutone old work/new work fan at HD it is listed for a 4 or 6 inch duct and comes with either wings or stud mounting. runs around $120. As far as duct size goes I've been told repeatedly to not install a fan on a duct that is too small it leads to fan noise and reduces the lifespan and voids the warranty. The only thing I'm terribly concerned about is the noise it makes when it comes to a customer's home.
Anathera is offline   Reply With Quote
The Following User Says Thank You to Anathera For This Useful Post:
splatz (10-02-2016)
Old 10-01-2016, 08:09 PM   #19
Can't Remember
Have a link to those? I looked and I see the Ultragreen ones with the bracket, but haven't seen anything with old work wings.
Old 10-02-2016, 07:31 AM   #20
Rewards Points: 386
InVent Series 80 CFM Ceiling Exhaust Bath Fan
http://thd.co/1MPkgt8
I think this is the one I have been using but I'd have to put my hands on it to be sure
Tags
bathroom fans, bathroom vent, fan vent, old work fan, rehab fan
surface mount fans WronGun General Electrical Discussion 20 07-30-2016 04:44 AM
Powerful ceiling fans ? tomatina General Electrical Discussion 12 05-19-2016 11:27 PM
Wiggy replacement leads varmit Tools, Equipment and New Products 8 05-15-2016 04:36 PM
bath exhaust papaotis Residential Electrical Forum 2 03-31-2016 06:25 AM
