Screwdrivers? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
Old 07-26-2015, 02:14 PM   #1
Bob Sisson's Avatar
Rewards Points: 213
Default Screwdrivers?
Ok, Ok you guys have convinced me I need a better screwdriver than my Southwire 9-in-1... (getting tired of bits falling out and soft metal bits)
Wish there were a less expensive Insulated screwdriver.... I would LIKE a ratcheting one, but can live without that feature... the ratcheting or removal blades make some of these EXPENSIVE !
Since I -ONLY- need to open dead fronts for inspections, I am looking for something with a Good flat, a Philips, a Plus/Minus and a Roberston in the middle of a Flat. Would LIKE nut drivers for HVAC cabinets, but I can keep my Southwire for those...
So Far I have looked at Milwaukee, Wiha, Wera and Bahco (Snap on)....
They all look nice, and expensive, but I will accept that for safety...
Any comments on other alternatives, or sales on combo's with less blades.
I would LIKE a ratcheting one, but can live without that feature...especially since that triples the price...
Bob Sisson
Maryland Licensed Home Inspector
Bob Sisson is offline   Reply With Quote
Old 07-26-2015, 02:15 PM   #2
MTW
MTW's Avatar
Rewards Points: 7,550
I thought this forum was for electricians.
Old 07-26-2015, 02:16 PM   #3
NacBooster29's Avatar
Rewards Points: 1,018
Says the guy in favor of no licensing.....
The Following 4 Users Say Thank You to NacBooster29 For This Useful Post:
BababooeyHTJ (07-27-2015), Black Dog (07-27-2015), Dan the electricman (07-26-2015), Jay82304 (07-27-2015)
Old 07-26-2015, 02:18 PM   #4
Bob Sisson's Avatar
Rewards Points: 213
I have posted to this forum many times, and gotten good feedback (and some flames) on descriptions, faults, wording and the like as my reports are often used to hire an electrician and to direct them as to what needs addressing..
In one of my recent posts someone remarked that my 9-in-1 was a possible hazard and suggested I look at better tools... I listen so I am following up on that suggestion.
Bob Sisson
The Following User Says Thank You to Bob Sisson For This Useful Post:
mapmd (07-26-2015)
Old 07-26-2015, 02:25 PM   #5
MTW
MTW's Avatar
Regardless of my personal views, the rules for the forum are pretty clear.
Old 07-26-2015, 02:26 PM   #6
Bob Sisson's Avatar
Rewards Points: 213
Hey, even -I- am in favor of licensing... and continuing education requirements. Too many "professionals" out there have been doing the same thing (wrong) for the past 15 years or more and have no idea of the new rules, guidelines, or new products.
I just went through a certificate class (5 credits) for the 2014 NEC changes, and I don't need them, but want to learn and understand more (Jade Learning) Wonder when I will start seeing the changes in the field as many of my counties are slow to adopt the new codes (Or insist on modifying them)
Bob Sisson
Old 07-26-2015, 02:38 PM   #7
Vintage Sounds's Avatar
Rewards Points: 4,004
The Following 2 Users Say Thank You to Vintage Sounds For This Useful Post:
BT Electric (07-26-2015), triden (07-30-2015)
Old 07-26-2015, 02:52 PM   #8
Rewards Points: 10,977
You don't believe in rules except when they suit you. Interesting.
Old 07-26-2015, 02:53 PM   #9
MTW
MTW's Avatar
I still have to follow the rules even if I don't like them.
Old 07-26-2015, 03:05 PM   #10
Bob, most of us understand why you're here. You take your job seriously and work with us not against us. That's probably why the mods look the other way when you post on this site.
You can't go wrong with the Picquic. Or a Klein 11 in one if you want common nutdrivers. Or get one of these:
Old 07-26-2015, 03:08 PM   #11
You're not an HI so why does this bother you? Why are you sticking your nose in someone else's business? Live and let live, dude.
120/208 (07-26-2015)
Old 07-26-2015, 03:21 PM   #12
ponyboy's Avatar
Rewards Points: 709
IMO home inspectors aren't electrical professions or part of the electrical industry. That being said I don't care what he posts since I don't read his silly threads about what ppe and screwdrivers are best for taking off loadcenter covers.
Old 07-26-2015, 03:24 PM   #13
Bob Sisson's Avatar
Rewards Points: 213
Is the Picquic an insulated screwdriver? I am pretty sure the Klien 11-in-1 isn't. I have several X-in-1's and they all have the same issues, non-insulated (yea I know 33-tape) and bits that can fall out at inopportune times. Also, most of the bits are cheap metal. The klien might be a bit better.
My "concern" is that the panel box becomes hot as I am removing the dead front... considering some of the panels I have seen, I am surprised I haven't been bitten already (knock wood fast) I am hoping to limit that to a buzz, a minor ouch, or a warning bite, nothing more. But not a Flash caused by a bit falling out and onto something interesting at the wrong time..
So far, the only thing that has tried to bite me was a GFCI outlet that blew up as I pressed the test button...nice burn on the tip of my finger right where I type... not bad for 14 years...Oh yea...and "Hot" wet drywall for a DW screw into NM that didn't pull enough to trip the breaker but gave a nice buzz when you brushed against the wall...
Bob Sisson
Old 07-26-2015, 03:31 PM   #14
If you want an insulated shaft, buy yourself a nice set of insulated Wera drivers.
Old 07-26-2015, 03:34 PM   #15
how about a Dewalt cordless driver or screwdriver.
120/208 is offline   Reply With Quote
Old 07-26-2015, 03:59 PM   #16
RGH
RGH's Avatar
Rewards Points: 2,044
I have a few basic rules I live buy my dad passed this gem on years ago and I didn't always follow it only to wish I had : never buy cheap paint, cheap tires or cheap booze..... There now you have three gems 😏
I rather be fishing......
RGH is offline   Reply With Quote
Old 07-26-2015, 04:20 PM   #17
Bad Electrician's Avatar
Rewards Points: 4,969
I do not use a all in one anything. I carry Pelican gag with a selection of screw drivers.
A lot of my work is inspections, all commercials but the intent is the same, I should carry a battery drill (and sometimes do.
http://www.opentip.com/Tools-Home-Im...mpaign=BingAds
I was born with a plastic spoon in my mouth.
Old 07-26-2015, 06:01 PM   #18
mapmd's Avatar
Rewards Points: 162
Hey, even -I- am in favor of licensing... and continuing education requirements. Too many "professionals" out there have been doing the same thing (wrong) for the past 15 years or more and have no idea of....
So what's your opinion of real estate agents?
They're pretty low in my book: right below those pesky personal trainers at the gym always harassing you to build up their client base, but still above people who work at mall kiosks.
mapmd is offline   Reply With Quote
Old 07-27-2015, 03:00 AM   #19
Rewards Points: 18
If it ain't Kline it ain't mine.
Mclaren likes this.
twistwire is offline   Reply With Quote
Old 07-27-2015, 07:52 AM   #20
daveEM's Avatar
Rewards Points: 2,382
You should go shopping for a truck.
Well if you do don't give them your phone number. They are for sure the bottom feeders of the world. Well maybe lawyers and politicians are.
Bob... go to a tool store and buy a few drivers...
Toss the multi in one stuff. Myself if I was taking covers off all day I'd be using a power screwdriver.
I like perfect.
Best Screwdrivers ZONE Tools, Equipment and New Products 143 02-29-2016 12:29 PM
Southwire screwdrivers Stickshaker General Electrical Discussion 24 12-04-2014 10:07 PM
Screwdrivers nick.sek Tools, Equipment and New Products 55 12-16-2013 10:42 PM
insulated screwdrivers JoeKP Tools, Equipment and New Products 22 07-24-2013 01:34 PM
Best screwdrivers Niven8 Tools, Equipment and New Products 71 08-01-2010 08:36 AM
