Tapping into a meter base to feed a subpanel - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 2 Post By tmessner
  • 3 Post By Cow
Old 04-22-2019, 09:13 PM   #1
Rewards Points: 12
Default Tapping into a meter base to feed a subpanel
A customer wants me to run power to his shed, which is about 40 feet away from the meter base. The meter has a 150 A main disconnect in it, which is the only space. In the past, I have spliced into the feeder wire after the breaker with polaris lugs and ran a feeder wire to a new panel, which was within 10' of the meter, and landed it in a breaker, which serves as the main disconnect for that panel. From there, I would run new feeder wires to the out building. Am I interpreting the tap rule correctly? Can I use the same method and run the feeders to the shed and install the panel in the shed? I just want to make sure I am interpreting the code correctly.
Thanks
spark25 is offline   Reply With Quote
Old 04-22-2019, 10:05 PM   #2
Rewards Points: 768
I think the outside feeder tap rule applies here. Unlimited distance as long as it originates and terminates outside with proper overcurrent at the load end.
John Valdes and Cow like this.
Old 04-22-2019, 10:19 PM   #3
Cow
Rewards Points: 4,542
https://commerce.ilsco.com/e2wShoppi...541:3100012542
Tapping into a meter base to feed a subpanel-ipc-20insulation-20piercing-20-dual-20rated-.jpg
jw0445, tmessner and telsa like this.
Height of meter base on deck zomarconi Canadian Electrical Forum 11 09-25-2018 11:32 AM
230.40 exception 3, load calcs, and meter base ampacity matt1124 Residential Electrical Forum 2 09-04-2018 09:39 AM
3gang meter base for 3 units. Londondude Residential Electrical Forum 11 06-10-2018 02:30 PM
Meter Base Horn Bypass AmishCountrySparky Services and Service Equipment 7 03-26-2016 11:11 PM
teck cable from meter base high_on_volts Canadian Electrical Forum 18 02-29-2016 05:02 PM
