Weird dryer 3-wire/4-wire diagram - Electrician Talk - Professional Electrical Contractors Forum
Like Tree42Likes
Old 07-10-2019, 06:18 PM   #1
Rewards Points: 727
Default Weird dryer 3-wire/4-wire diagram
Went to convert a Samsung (model DV393ETPAWR/A1) dryer from a 3-wire setup to 4-wire today, and found this diagram. It does not compute. Why on earth would a 4-wire configuration require that the dryer's "ground strap" be connected to the neutral? And, oddly, in the 3-wire diagram it shows the "ground strap" connected to the frame. ????
[addl info: the machine's interior wires, H-H-N-groundstrap, come from within through a piece of flex tubing, and with the exception of the controversial "ground strap," terminate on the top of the terminal bar.
Weird dryer 3-wire/4-wire diagram-img_20190710_152736.jpg
mikewillnot is offline   Reply With Quote
Old 07-10-2019, 06:55 PM   #2
Bird dog's Avatar
Rewards Points: 1,958
Do the installation instructions packed with the machine say the same thing? Do they have the blurb saying have a qualified person do this?
Old 07-10-2019, 06:59 PM   #3
Mensa Player
Rewards Points: 705
That ground strap is connected to the neutral behind the terminal bar.
When you’re using a three wire set up, that ground strap is used to connect the neutral to the frame.
When using a four wire set up, they have you terminate the ground strap on the neutral terminal which cancels it out (since the other end is connected to the neutral). I assume that is just so it doesn’t flop around and touch the metal frame.
Old 07-10-2019, 07:15 PM   #4
Rewards Points: 2,776
Obviously, the idiot who made the label is .....well.....an idiot.
This brings up an interesting question, 110.3(B) plainly requires us to install equipment according to manufacturers instructions. Do we follow the instructions even if they're wrong?
Old 07-10-2019, 07:19 PM   #5
Mensa Player
Rewards Points: 705
What is wrong about it?
Old 07-10-2019, 07:36 PM   #6
Mensa Player
Rewards Points: 705
Here's a snip from the manual, different picture but it shows the same thing:
Weird dryer 3-wire/4-wire diagram-screen-shot-2019-07-10-7.30.38-pm.png
Here's another brand of dryer with the same type of connection:
Weird dryer 3-wire/4-wire diagram-screen-shot-2019-07-10-7.32.00-pm.png
And here is just a random Whirlpool dryer that I pulled up, the same:
Weird dryer 3-wire/4-wire diagram-screen-shot-2019-07-10-7.35.14-pm.png
It's just the standard way to do it.
Once that wire is disconnected from the frame, it is no longer the "ground strap", it is the "neutral strap".
Old 07-10-2019, 07:57 PM   #7
Rewards Points: 1,334
The 4 wire connection is incorrect. You would not have a ground strap connected to the neutral. The strap would either get disconnected or connected to the equipment grounding conductor of the 10/3 with ground cable.
I would probably disconnect it because I have seen some that are connected to the neutral internally
I can't help it if I'm lucky
Old 07-10-2019, 08:02 PM   #8
Mensa Player
Rewards Points: 705
It’s only called a ground strap because it used to ground the neutral when it’s attached to the frame. Once you disconnect it from the frame, it’s no longer grounded. It’s attached to the neutral on the other end. Attaching it to the neutral on the terminal strip is just a way to hold it down so it doesn’t flop around and touch the hots or the frame.
Old 07-10-2019, 08:07 PM   #9
Rewards Points: 727
So you're saying the ground strap is connected to the neutral somewhere inside the machine? Because it sure isn't at the terminal bar, where I usually see ground straps.
Old 07-10-2019, 08:09 PM   #10
Mensa Player
Rewards Points: 705
Yes, that’s the entire point of it. It connects the neutral to the frame. When you use a four wire cord, you disconnect that strap and connect the ground from the cord to the frame instead.
MechanicalDVR and circuitman1 like this.
Old 07-10-2019, 08:10 PM   #11
Rewards Points: 727
There seems to be a consensus that the "ground strap" -- which in no way resembles any ground strap I have ever seen -- is in fact connected to neutral somewhere inside the machine. That's the only scenario where the diagrams make any sense. And suggests that my use of quotation marks around the phrase was appropriate, because it's not a ground strap or a jumper in any commonly understood way. Where I come from, a ground strap is actually a strap, and it goes from the ground lug to the neutral terminal on the terminal strip. And that's the kind of thing that is prohibited from being used with a 4-wire setup.
I would argue that this diagram may be technically correct, but it is as clear as mud electrically and in terms of the English language. Where I come from, the only time you put a green ground wire on a neutral terminal is with a 3-wire setup.
Old 07-10-2019, 10:08 PM   #12
Band Member
emtnut's Avatar
Rewards Points: 1,234
There seems to be a consensus that the "ground strap" .......
Doesn't seem to be a consensus, but Hax is right
Old 07-10-2019, 11:51 PM   #13
If it is indeed true that the manufacturer requires the neutral to be bonded to the frame with a 4 wire cord, then it's wrong.
But looking at it deeper, it appears that their drawing is indeed correct, just a bit confusing.
Old 07-11-2019, 05:16 AM   #14
Rewards Points: 4,412
It is not a ground strap, it's a neutral jumper. Call it that and it all makes sense
It would be a lot more normal to have a ground strap and terminal but it's electrically equivalent, normal, safe as shown in the instructions. Three wire, frame is bonded to neutral; four wire, frame is bonded to EGC. The neutral jumper is landed just so it's not flopping around shorting etc.
Old 07-11-2019, 07:21 AM   #15
Mensa Player
Rewards Points: 705
Think of where that "ground strap" is coming from. It has to be coming from the neutral, correct? That is why the loose end gets attached to the frame when using a 3-wire cord. It bonds neutral to the frame. So the end we can't see is attached to the neutral.
Bird dog likes this.
Old 07-11-2019, 07:21 AM   #16
Mensa Player
Rewards Points: 705
Old 07-11-2019, 07:24 AM   #17
I agree but that is not what the picture is showing. It seems to have the ground strap connected to the neutral in the 4 wire install
Old 07-11-2019, 07:27 AM   #18
Mensa Player
Rewards Points: 705
The ground strap is not a ground strap when it is removed from the frame, the other end of it is connected to the neutral. It is a neutral strap. The loose end also connects to the neutral on the front fo the terminal bar so it doesn't flop around. Both ends are now connected to the neutral. No ground.
Just put some thought into it, where is the other end of that wire connected? You are thinking that is is connected to ground, but why would it be? If the other end of that wire was connected to ground, what would be the point of connecting the loose end to the frame when using a 3-wire cord?
Old 07-11-2019, 07:50 AM   #19
CoolWill's Avatar
Rewards Points: 2,676
The picture is correct. That jumper, AKA "ground strap" is permanently connected to the neutral terminal on the back of the block. The free end either connects to the frame, as in the 3-wire pic, or it loops back to the neutral, as in the 4-wire pic.
With the 4-wire cord, it isn't necessary to actually connect it to the neutral since it is already connected on the other end. They show that so you won't just leave it flopping around.
splatz and RRF like this.
I'm With Her! Hillary 2016
Old 07-11-2019, 08:00 AM   #20
Mensa Player
Rewards Points: 705
I have always cut the end off and taped it up. Attaching it to the front neutral terminal is a better idea incase they ever bring the dryer somewhere that has a 3 prong outlet.
