What is considered living space? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 2 Post By splatz
  • 2 Post By MikeFL
  • 3 Post By macmikeman
Old 03-06-2019, 06:58 PM   #1
Rewards Points: 153
Default What is considered living space?
Homeowner is enclosing a porch with block and glass windows but will not be under heat/air. Does he need receptacles for living space?
After the block was installed and passed, he calls for window inspection. This day the inspector tells him this will be considered living space and require receptacles to code.
Homeowner calls me, I explain we can add them but they will need to be surface mounted which he does not want.
2 existing GFCIs are present but it's far from the 6 foot rule.
I thought living space was under heat/air, no?
MrsElectric is offline   Reply With Quote
Old 03-06-2019, 07:37 PM   #2
CoolWill's Avatar
Rewards Points: 2,012
This is probably under the jurisdiction of the building code. Find out what code they use for residential buildings and check with that for the definitions of what is considered living space.
I'm With Her! Hillary 2016
Old 03-06-2019, 08:16 PM   #3
Rewards Points: 3,720
If it's a "sunroom" then 210.52(A) lumps it in like most other rooms. If it's a "balcony, deck, or porch" then it only requires one receptacle. I don't know what else you could call it.
Habitable Space. Building space intended for continual human occupancy. Such space generally includes areas used for living, sleeping, dining and cooking, but does not generally include bathrooms, toilets, hallways, storage areas, closets, or utility rooms.
Although without heat / air it might not be suitable for "continual occupancy" year round you could say if it's going to be occupied continuously part of the year, it needs the receptacles.
HackWork and MrsElectric like this.
Old 03-06-2019, 08:35 PM   #4
MikeFL's Avatar
Rewards Points: 2,692
I'd be curious to know what bldg dept is issuing permits without doing plan review. It's a whole lot cheaper to correct it on paper than it is to correct it on the earth.
They need the receptacles.
MrsElectric and Bird dog like this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 03-06-2019, 08:42 PM   #5
Rewards Points: 25,620
You're in FLORIDA. Heating and air is optional.
Any time I see a space that is totally enclosed and at all suitable for furniture -- I'd call it living space... 'cause you know folks will flop there... fur sure.
As for the homeowner: let him have fun with the building department.
You just quote'em and build'em.
If he can stump up for wet cut slots in his CBUs -- flush mounted receptacles can be done.
Coming up from below might be an option. I can't see the joint from my desk.
Old 03-07-2019, 12:37 AM   #6
Rewards Points: 304
Many locations have "3 season rooms"!
Old 03-07-2019, 12:38 AM   #7
Rewards Points: 15,887
You ain't never lived there have you? During winter there are some periods when if you didn't have heat you will die. During summer if you don''t have ac you wish you would die.
Old 03-07-2019, 10:23 AM   #8
canbug's Avatar
Rewards Points: 1,510
OK Mac, I hesitate to believe you would die in a Florida winter without heat. We have homeless people who stay outside all winter in temps that can get to -30, -40 at night.
Tim.
Old 03-07-2019, 10:40 AM   #9
Switched's Avatar
Rewards Points: 8,856
I can get a permit online to rewire a 40k sq ft house without ever submitting a set of plans for review, no load calcs., no nothing.
When the inspector arrives though, you better have your stuff together or they'll rip you a new one.
I like it, I can have a permit in 10 minutes. No stupid useless building department holding up something for "You need one additional receptacle here, you'll have to resubmit the plans tomorrow".
Old 03-07-2019, 06:54 PM   #10
Rewards Points: 153
Thanks
Sounds like we'll have to add them he just would have preferred to not have surface mount had plans or an inspector caught it earlier
Cannot come from below since it's on a slab
Old 03-07-2019, 07:01 PM   #11
Rewards Points: 153
Wow I wish! Our city requires drawings with wire and pipe size for every single electrical permit applied for and if any changes are made in the field I have to submit a revision and pay $ or it will fail. I'm talking small things too like add an additional receptacle or light, what a pain!
Old 03-08-2019, 03:06 PM   #12
Rewards Points: 8
Tim.
In Hawaii we cry when the weather hits 60 and gotta wear long pants/sleeves.
WorksOutOfaVan is offline   Reply With Quote
Ideas for an empty wall space for material NDC Tools, Equipment and New Products 10 09-09-2018 08:01 AM
Crawl space = confined space? Islander Canadian Electrical Forum 25 05-09-2017 04:08 AM
Electrical in hot vent soffit space !Tom Canadian Electrical Forum 3 12-05-2016 07:14 PM
