Why am I getting voltage where I didn’t expect it? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
  • 2 Post By 460 Delta
  • 6 Post By B-Nabs
  • 2 Post By Morty88
  • 6 Post By macmikeman
  • 3 Post By just the cowboy
  • 2 Post By LawnGuyLandSparky
Old 03-25-2019, 08:31 PM   #1
Rewards Points: 12
Default Why am I getting voltage where I didn’t expect it?
So I just wired up a ceiling fan/light, I ran 12-3 wire to put the fan on a separate switch than the light. I ran 12-2 wire for incoming power and pigtailed the hot wire to both the bottom side of the switches and then the 12-3 black to the light and red to the fan. I haven’t actually mounted the fan yet to see if it worked, but I wanted to test it first and my induction tester sensed both wires hot with only one switch on. So I put my multi meter on the wires and when I have only one switch on one wire reads 120V like expected and the other wire reads around 70V which is totally unexpected to me. Any ideas? What am I missing? I’m a first year apprentice.
Kmurd is offline   Reply With Quote
Old 03-25-2019, 08:46 PM   #2
460 Delta's Avatar
Rewards Points: 674
Sounds like a ghost voltage to me, use a wiggy or a lncandescent bulb and a weatherproof socket to test it out. A DMM has to high of an impedance to be reliable.
MechanicalDVR and Rodger like this.
Old 03-25-2019, 08:58 PM   #3
Rewards Points: 12
It is my cheapo DMM from harbor freight.
Old 03-25-2019, 09:05 PM   #4
Watt Pusher
B-Nabs's Avatar
Rewards Points: 466
There's your sign.
Old 03-25-2019, 09:20 PM   #5
Rewards Points: 32
Could just be an induced voltage from the switch leg being on. When both switches are off you have 0v? I’m sure it would disappear if you attached a load to the one switch leg.
zac and Florida like this.
Morty88 is offline   Reply With Quote
Old 03-25-2019, 09:35 PM   #6
Rewards Points: 15,887
The ultimate test: Cut the cable with your brand new strippers. That'l tell you if you got's real volts or not.............
Old 03-25-2019, 11:11 PM   #7
Rewards Points: 1,173
Old 03-26-2019, 06:31 AM   #8
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,046
Do PUCO's high voltage lines go over your house?
Old 03-26-2019, 08:39 AM   #9
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,082
Where's your wiggys?
Signal1 is online now   Reply With Quote
Old 03-26-2019, 09:07 AM   #10
just the cowboy's Avatar
Rewards Points: 372
What your seeing is called ghost voltage. That is why everyone is telling you to use a wiggy (solenoid type that puts a load on) or load it with a light bulb. A low z setting on a meter is the same thing. This I a good learning experience, don't trust just a voltage reading when troubleshooting.
Old 03-26-2019, 11:04 AM   #11
Rewards Points: 12
Thanks for explanation!
Old 03-26-2019, 12:00 PM   #12
Rewards Points: 304
Old 03-26-2019, 12:02 PM   #13
Rewards Points: 304
Whenever your safety is involved use a tester that provides a load on the circuit.
Old 03-26-2019, 12:49 PM   #14
trentonmakes's Avatar
Rewards Points: 138
Turn it off and switch the other one on...what reading do you get?
Old 03-26-2019, 03:08 PM   #15
Rewards Points: 12
It’s definitely a ghost voltage, I just never thought that I would see that high of a ghost voltage on 120V. What is the highest ghost voltage you all have seen on a 120V circuit?
Old 03-26-2019, 04:59 PM   #16
Rewards Points: 4,242
600 volts. To be fair, it was right next to a cemetery.
glen1971 and Kevin_Essiambre like this.
LawnGuyLandSparky is online now   Reply With Quote
Old 03-27-2019, 09:00 AM   #17
Rewards Points: 8
Itís definitely a ghost voltage, I just never thought that I would see that high of a ghost voltage on 120V. What is the highest ghost voltage you all have seen on a 120V circuit?
Up to 70v on some older homes
WorksOutOfaVan is offline   Reply With Quote
Old 03-27-2019, 11:17 AM   #18
canbug's Avatar
Rewards Points: 1,510
If you know you wired it correctly just put up the damn fan and turn it on. Guess what, it works...
Tim.
Old 03-27-2019, 12:15 PM   #19
Rewards Points: 12
Thanks, I will when I’m good and ready to.
So at first it surprised me enough to second guess myself, and then I was curious enough to ask more about it.
Old 03-27-2019, 06:51 PM   #20
Rewards Points: 32
Default Ghost Voltages
I am in an area with a LOT of 50-60 yo homes. It is easier to count the number of homes without ghost voltage. The real issue is that we can NOT TRUST our wands to tell us anything, they flash and ring constantly even when there is no actual voltage.
The WORST part is finding the right breaker to turn off. Pretty hard when a "dead" circuit rings your wand or shows 90 volts with a meter, my wiggy is not meant to hold a circuit for long (I don't want to destroy it) Yep, happens all the time here.
This week we had a remodel that was driving me crazy, found out that there are at least 6 circuits abandoned in the ceiling when we tore out the rock and soffits. Each of those circuits were abandoned from the breaker but stayed on the neutral and ground. Yup, I get voltages on my wand at each of them. I see voltage with my meter (sometimes surprising voltages) but nothing with my wiggy, not even a click.
The real issue is that it takes my time no matter what.
Djea3 is offline   Reply With Quote
Y Delta woes chicken steve NEC Code Forum 58 04-03-2018 05:52 PM
3-Phase motor (voltage issue) mlanglois General Electrical Discussion 24 10-01-2016 11:14 AM
Southwire Non Contact Voltage Tester Recall MechanicalDVR Tools, Equipment and New Products 3 07-03-2016 08:17 AM
Phantom Voltage? touchtester Residential Electrical Forum 9 04-25-2016 09:20 PM
