2'' 3'' and 4'' aluminum rigid conduit - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > New Member Introductions
Like Tree5Likes
  • 2 Post By frenchelectrican
  • 1 Post By joebanana
  • 2 Post By sbrn33
Old 01-05-2018, 06:53 PM   #1
Cool 2'' 3'' and 4'' aluminum rigid conduit
Hello from snowy upstate New York,
Im looking at a job that requires Large rigid conduit installed and as a lot of you know Aluminum is cheaper and lighter. Im getting a little older and have forgotten if standard shoes for Rigid bending (Greenlee 777) will work ok without kinks and damage ? Greenlee did not give me a clear answer and wants to sell upsell me to a do-all $$$
Thanks
richewill is offline   Reply With Quote
Old 01-05-2018, 07:52 PM   #2
Rewards Points: 21,898
Thanks
The ridge alum conduit or the intermate alum conduit ?
Really the alum ridge conduit is the same size as steel ridge conduit so you should able bend it without much issue but make sure your bending shoe is clean and no debries on it. that will bite ya if you do not do this step first before you start bending it. sometime I spray little WD40 on shoe to make it bend more smoother.
MechanicalDVR and PokeySmokey like this.
Old 01-05-2018, 08:28 PM   #3
Rewards Points: 920
Welcome to Electrician Talk.
I'm not sure about IMC as far as direct cross size to ridged. OD. My memory says its the exact same as far as bender shoes.
Besides I have never heard of IMC shoes. I think you are fine with the same bending shoes and measurements?
There are guys here that use IMC a lot and will be a better source for the information you seek.
Old 01-05-2018, 08:43 PM   #4
Yes. Rigid Al and Rigid Steel use the same shoes. Sidewinder style bender on the rigid shoe for 2" and hydraulic bender like the greenlee 881 table bender for the 3" and 4".
RigidRack is offline   Reply With Quote
Old 01-05-2018, 08:47 PM   #5
Also down here in NYC I use Gal Steel Elbows on my bigger Aluminum runs because pulling through Aluminum sucks even with the Simpull and the WireEase! The steel elbow makes a world of difference! I always bend my own. I personally am not a prefab fan at all except for this one situation...lol!
Old 01-05-2018, 08:47 PM   #6
Thanks John, I compared allied site for aluminum rigid 4 inch has 4.5 inch od .225 nominal wall thickness to wheatland rigid steel galv. dip and its the exact same measurements.
I do not understand why they would make a special shoe setup for aluminum rigid?
maybe because its softer?
Old 01-05-2018, 08:59 PM   #7
Rewards Points: 920
My point. Same measurement. Same OD.
But lets wait and see what some of the other guys have to say.
I know Southeast Power uses IMC a lot!
Old 01-05-2018, 09:30 PM   #8
Rewards Points: 7,915
Use standard rigid bending shoes. Aluminum and GRS are the same dimensions.
cabletie likes this.
Old 01-05-2018, 10:22 PM   #9
cabletie's Avatar
Rewards Points: 1,274
Like Joe says, there're all the same shoe.
Do you have one shot shoes for the 777 in 3" and 4"? I thought that bender only does one shot to 2" and segment shoes up to 4".
The only thing to keep in mind is that aluminum seems to straighten out after a while. So if you bend the perfect 10" offset and install it, the next day it may look open. Same with 90's. Just thought I'd mention it so you don't think your going crazy.
Otherwise threaded aluminum is a dream compared to RGS.
Old 01-05-2018, 10:40 PM   #10
sbrn33's Avatar
Rewards Points: 3,578
AL is cheaper than steel or IMC? Would have never guessed that. My only trouble ever with AL is threading. If you go to fast it can gall.
Old 01-07-2018, 10:56 AM   #11
Good morning, site had me shut out but ok now?
Thanks for the help guys, you are right cabletie segment bending on the 777 (2.5''-4'')
sbrn33 Alum. is cheaper & lighter checked 2-3 sites for $ comparison.
Hay rigidrak great tip forgot all about steel 90's for pulling.
Thumbs up to the mods many thanks for what you do and comments
Old 01-09-2018, 01:14 AM   #12
Rewards Points: 1,230
Bending: Standard EMT benders, one size larger than the size of the conduit, should be used on conduit trade sizes 1 and smaller. For sizes over trade size 1, conventional equipment is recommended.
Copied and pasted from the Allied Tubing site
bostonPedro is offline   Reply With Quote
Old 01-09-2018, 11:00 AM   #13
Agreed although after calling Allied & bender mfg. companies to test them out I found that their bending knowledge is minimal, bender company wanted to sell me equipment to bend emt imc and rigid to cover me for aluminum for moey bueno$ cheers
Rigid Conduit - Thread Paste 847Videos General Electrical Discussion 9 09-05-2017 10:48 AM
Suspending security camera from conduit ElectMe NEC Code Forum 8 02-19-2017 04:20 PM
Why are threads on rigid conduit tapered? alan121457 General Electrical Discussion 64 02-15-2017 12:38 PM
Connecting rigid pvc conduit to flex pvc conduit heldon99 General Electrical Discussion 18 08-24-2016 09:12 AM
Using rigid conduit with werma stack lights? Breakfasteatre PLCs, VFDs, Motors and Controls 2 02-08-2016 04:33 PM
