Electrician to Engineer - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > New Member Introductions
Old 08-13-2013, 05:49 PM   #1
Default Electrician to Engineer
Greetings to all here,
I feel a little background is in order to properly discuss my situation and where I would like to go with it. So obviously, i'm new to the forum and also the electrical field. I graduated with an BS in Psychology and was unable to find anything in the field, didnt have enough experience or enough schooling, more the later. My dad thought it would be a good idea to get a trade so I have been attending coyne college for electrical construction and maintenance. What was a good idea turned out into a great one, I love the things I am doing and learning and wish I knew about things like this much much earlier. Here is where my real question(s) come into play. I find myself very interested into why these circuits work the way they do or are made the way they are made and I am always met with the reply "those are engineering questions" so my questions to the community are:
1. Can there be a smooth or suggessted transition that can be made from being an electrician to an engineer? If so, how can this be done?
2. Based on my situation, already having a bachelors, is getting a second bachelors worth it?
I guess we will go with that just to get the ball rolling. Thanks for all your help
bhouse is offline   Reply With Quote
Old 08-13-2013, 06:01 PM   #2
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Welcome to the electrical trade and the forum
If you want to become an electrical engineer then keep going to school while your working as an electrician ,,,good luck.
Old 08-13-2013, 06:18 PM   #3
Rewards Points: 206
If you do become an electrician, don't tell the other sparkies you have a BS in psychology.
newbi is offline   Reply With Quote
Old 08-13-2013, 06:29 PM   #4
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
G....
1. unlikely and improbable, but not completely impossible. it takes roughly 4 years minimum to get an electrical masters/contractors license in most areas. It takes roughly 7 years working under a PE as an engineer to sit for the PE test so you can be a professional engineer. like others said, just switch to EE and get your degree in EE, then go out and work. There are a million areas where you could use an EE degree, and electrical power wiring is only one of them. besides that, you will learn in your first two electronics classes how and why current flows in a circuit (or flunk out)
2. yes
Old 08-13-2013, 06:34 PM   #5
Rewards Points: 1,000
Have you considered traditional business administration-type jobs? I know at least one psych major who went on to a career in business and even got his MBA.
uconduit is offline   Reply With Quote
Old 08-13-2013, 08:58 PM   #6
I think this can sometimes be the answer guys give when they just don't know. I think you as an electrician should try to always be learning. Most of the time the electrician should understand what he is working on at least to the level of an engineer. An electrician should have a better working knowledge of it as well.
One of the best electricians I know has a degree in psychology. Let your work speak for itself.
At least in my area, the transition isn't smooth. It takes at least 4 years of full time school to be an EE, even as a journeyman electrician.
I think if you have the time/money/desire, additional education is always worth it. I doubt anyone who is an EE and a journeyman electrician would be unemployed very long, if ever.
Cujo is offline   Reply With Quote
Old 08-13-2013, 09:14 PM   #7
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
I've worked with a few electrician-engineers and they are often the best of both worlds: Electricians with a very solid understanding of theory and troubleshooting, and engineers who aren't arrogant or needlessly pedantic.
But the training to be an electrician is often very different from the training to be an engineer, so a lot of guys don't readily fit into both.
Always wear your gloves.
Michigan Master (08-13-2013)
Old 08-13-2013, 09:42 PM   #8
Electron Flow Consultant
sparky970's Avatar
Rewards Points: 992
If you have never actually worked in the field, you're not an electrician. You're an engineer.
Old 08-13-2013, 10:01 PM   #9
corn-fused
papaotis's Avatar
Rewards Points: 620
maybe with phsyc. thing you could eventually relate to us better than an engineer! stay the course, id love to see the results!
Old 08-13-2013, 10:24 PM   #10
Rewards Points: 3,566
2. yes
I believe that varies state by state.
http://www.nspe.org/Licensure/HowtoG...sed/index.html
Old 08-13-2013, 11:09 PM   #11
Michigan Master's Avatar
Rewards Points: 1,284
Totally possible! I know several folks who've made that transition.
However, it's a looonng road. Plan on 4-5 years (including school at nights) to become an electrician, and then after that another 8-12 years of school (part-time) while working as an electrician to get an EE degree. Your best bet to make the transition is to work for a company that employs both electricians and engineers.
Edit: Oops, seeing that you already have a bachelor's degree make that 6-10 years part-time for an EE degree.
Michigan Master is offline   Reply With Quote
Old 08-13-2013, 11:16 PM   #12
dronai's Avatar
Rewards Points: 439
A BS in Psychology would be good in dealing with customers. In general people with a lot of BS make a lot of money.
Old 08-14-2013, 05:13 PM   #13
wildleg's Avatar
I believe you are correct
http://community.nspe.org/blogs/lice.../04/table.aspx
Electrician turned Engineer jewilliams General Electrical Discussion 9 01-02-2013 09:00 PM
Need a Job as Electrical Engineer/Electrician? jmleonar General Electrical Discussion 2 11-23-2012 12:21 PM
Field Engineer or Electrician? leventa2 General Electrical Discussion 27 05-24-2012 12:23 PM
Electrical Engineer and Electrician Overlap FCR1988 General Electrical Discussion 7 02-08-2012 09:54 AM
I'm not a engineer! Gamit General Electrical Discussion 27 01-26-2011 12:25 PM
