Opinions from highly trained individuals needed - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > New Member Introductions
Like Tree34Likes
Old 06-12-2019, 12:33 AM   #1
Rewards Points: 6
Default Opinions from highly trained individuals needed
Hi! I have training in electronics with an Associates Degree. I don't use it much, so I might be kind of rusty. I'm here to get opinions from people who are more highly trained and more knowledgeable.
Bret9971 is offline   Reply With Quote
Old 06-12-2019, 05:44 AM   #2
Rewards Points: 1,963
Nobody has opinions here.
The_Modifier (06-12-2019)
Old 06-12-2019, 06:52 AM   #3
Rewards Points: 1,684
Being an Electronics Technician is quite different than being an electrician. You may get some blowback from the moderators about that.
But welcome, and ask away.
Bret9971 likes this.
bill39 is online now   Reply With Quote
The Following User Says Thank You to bill39 For This Useful Post:
Bret9971 (06-12-2019)
Old 06-12-2019, 08:12 AM   #4
Lax Luthier's Avatar
Rewards Points: 84
Default The trades overlap
More and more the field of electrical work and electronics are merging.
You could choose to avoid the electronic aspects of modern electrical systems and equipment, but it certainly doesn't hurt to have a background in basic electronics, which will enable you to learn and work on the advanced control and data systems (Scada, PLC, technical power requirements, etc.)
For a basic look at what's happening on the electronics side of the electrical industry, check out some of the subject matter in the publication EC&M (Electrical Construction and Maintenance) which Is easy to find on the web.
On a personal note, back in 2002 or so I worked at a major power plant rebuild and new plant project at Duke Energy's Moss Landing, Ca. power plant. I was an inside wireman "Take-In" electrician in Local 413, Santa Barbara County Ca. with a BA-BA arrangement to work out of the Castroville local.
There were eleven IBEW contractors on the job, each with its own area of expertise, with controls & instrumentation being large "slices of the pie".
I went to work for a San Francisco area C-10 that was a subcontractor to Foxboro, one of the biggest control outfits in the world. Having a background in electronics helped me a lot on that job, which was installing state of the art control & instrumentation systems & equipment.
As they say in the field, "Do It All".
Lax Luthier is offline   Reply With Quote
The Following User Says Thank You to Lax Luthier For This Useful Post:
Old 06-12-2019, 08:17 AM   #5
Rewards Points: 1,605
I am not highly trained, but I am extremely handsome so I think my opinion should matter more than most.
The_Modifier, Signal1 and MikeFL like this.
Old 06-12-2019, 09:08 AM   #6
canbug's Avatar
Rewards Points: 2,032
When you want to know how cold it is outside, ask us Canadians.
Tim.
Old 06-12-2019, 10:38 AM   #7
Small Potatoes
flyboy's Avatar
Rewards Points: 4,265
In my opinion your opinion does not matter more, because I am no doubt more handsome. Therefore, my opinion matters more and thus I am right and you are wrong.
...and everyone knows it.
Old 06-12-2019, 12:26 PM   #8
Rewards Points: 23,896
Hmm, two of them puffing on the same crack pipe......you know that crap is rough on your teeth and complexion?
MikeFL likes this.
Old 06-12-2019, 12:50 PM   #9
joe-nwt's Avatar
Rewards Points: 1,898
Would you like a second opinion?
Old 06-12-2019, 12:51 PM   #10
I've been getting them my entire life.
Don't hate me because I am beautiful.
Old 06-12-2019, 01:21 PM   #11
Band Member
emtnut's Avatar
Rewards Points: 2,514
I like you Hax
I'm not beautiful though, I'm just ruggedly handsome
Oh, and per the OP ... I'm not highly trained, in fact, I've been told I'm not even trainable
I thought that was a good thing
HackWork (06-12-2019)
Old 06-12-2019, 02:32 PM   #12
I’m house trained. One time, though,...
Never mind.
MechanicalDVR, MikeFL and gpop like this.
Old 06-12-2019, 03:57 PM   #13
Wardenclyffe's Avatar
Rewards Points: 626
I had some Trained Electricity I didn't use much either,...
Wardenclyffe is online now   Reply With Quote
Old 06-12-2019, 04:41 PM   #14
Rewards Points: 2,468
Don't feel bad, I have been telling people I am "certified" for years, turns out they said "certifiable" and apparently it's not the same
MechanicalDVR, Bird dog and MikeFL like this.
This too shall pass.
Old 06-12-2019, 05:36 PM   #15
stiffneck's Avatar
Rewards Points: 1,302
I work for the government, I'm neither qualified or qualifiable.
Wirenuting likes this.
In Bred Electrical Worker
Old 06-12-2019, 05:39 PM   #16
stiffneck's Avatar
Never mind.
Is that the same as potty trained?
Old 06-13-2019, 04:24 PM   #17
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,412
Best answer
Old 06-13-2019, 04:31 PM   #18
Bird dog's Avatar
Rewards Points: 2,160
Originally Posted by Wirenuting View Post
Best answer
He's qualified to do anything with nothing.
“We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
http://www.jonathanfields.com/we-the-willing/
stiffneck (06-13-2019)
Old 06-14-2019, 12:03 AM   #19
Rewards Points: 938
And apparently their eyesight when they look in the mirror.
Old 06-14-2019, 05:16 AM   #20
You're the guy who tried to tell us how science is correct and global warming is true by posting a Bill Nye (not a scientist) video, right?
Don't ever question my rugged good looks again.
