Please help! - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > New Member Introductions
Like Tree1Likes
  • 1 Post By HackWork
Closed Thread
Old 03-01-2019, 01:47 PM   #1
Default Please help!
I'm not sure if this is the right place to post this, my apologies if not.
A 6/3 wire got damaged in my garage. I am going to consult with my brother (a senior tech for the power company), but would like to attempt to wrap my head around the situation first.
The wire/circuit feeds the stove on the other side of a split level home. The breaker is now off. The old cloth covered 6/3 wire has no ground. The plan (?....): The length of the wire coming from the panel is just too short to tie into. Run a new length of 6/3 romex (w/ ground wire) to an exposed 4-11/16 x 2-1/8 junction box mounted in the ceiling (joist). Use 3 appropriate Polaris connectors to tie in the new Romex with the old existing wire. My question, what to do with the ground wire from the Romex? I should ground the metal box, yes? Can I? Is there a solution other than the impossible task of running a complete run from the panel to the kitchen in a split level home?
Any advice would be much appreciated. Thanks.
bwt6ct is offline
Old 03-01-2019, 01:49 PM   #2
Rewards Points: 449
You should not consult with your brother. You should consult with a licensed electrician with a lot of experience doing residential work.
HackWork is online now
bwt6ct (03-01-2019)
Old 03-01-2019, 01:56 PM   #3
I appreciate your good advice. I am not going to do this myself, for certain. I'm just trying to wrap my head around the grounding situation before I call in the troops and empty the back account. Will it require an entire new run to the stove?
bwt6ct is offline
Old 03-01-2019, 02:08 PM   #4
Rewards Points: 449
Sure, you are not going to do it yourself... Yet you already picked out the exact material you are going to use and are asking how you should do it.
CoolWill likes this.
Old 03-01-2019, 02:10 PM   #5
Rewards Points: 2,754
Thanks for posting on ElectricianTalk.com.
However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
John Valdes is online now
Old 03-01-2019, 02:11 PM   #6
Timed out double post deleted.
Closed Thread
