Questions from across the pond - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > New Member Introductions
Old 06-14-2019, 12:25 PM   #1
Rewards Points: 12
Default Questions from across the pond
Hi there, new member of the forum hoping for some guidance.
I'm trying to alter a UK/EU compliant 'plug & play' style distribution system for use on sites i've got coming up in the US, what forum section would you recommend i post into?
Thanks in advance,
Tom
TommyBoy85 is offline   Reply With Quote
Old 06-14-2019, 12:54 PM   #2
CoolWill's Avatar
Rewards Points: 2,012
General Electrical Discussion
I'm With Her! Hillary 2016
Old 06-14-2019, 12:56 PM   #3
MikeFL's Avatar
Rewards Points: 2,692
General Electrical forum should suffice.
Welcome to the forums.
And if you can provide more info about that "distribution system" that will help.
Edit: @CoolWill types faster than my old crippled fingers.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 06-14-2019, 07:29 PM   #4
Rewards Points: 2,744
Welcome to Electrician Talk Tommy.
Thanks for taking the time to fill out your profile.
Old 06-14-2019, 07:39 PM   #5
Rewards Points: 16,780
Thanks in advance,
Tom
Welcome to the electrician talk fourm
Anyway there one thing you will keep it in your mind most common voltage is typically 120 volts line to neutral not 240 volts like your area due it is a part of Edison circuit set up for both single and three phases.
However speaking of three phase the voltage will varies a bit in North Amercian side depending if you going with delta or wye ( star ) connected system.
If need more info just go ahead and posted it in general electrical discussion that will help you a bit on the info you are looking for.
Old 06-15-2019, 07:47 AM   #6
Rewards Points: 12
Many thanks for your warm welcome all!
Old 06-18-2019, 09:18 AM   #7
Rewards Points: 304
Welcome aboard @TommyBoy85!
Enjoy your ride here.
