What do you look like? - Page 10 - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > New Member Introductions
Closed Thread
Old 04-06-2011, 08:40 PM   #181
Davidg408's Avatar
Rewards Points: 252
Originally Posted by Josue View Post
OK here is part of my arm.
Alright, I believe you...your arms look silky smooth! Do you shave or do you use Nair??
(Not that I'm a [email protected] - just curious)
Not that there's anything wrong with that!!
The sword is only as powerful as its master
Davidg408 is offline
Old 04-06-2011, 08:42 PM   #182
Davidg408's Avatar
Rewards Points: 252
Originally Posted by Frasbee View Post
Is that pink scar from a run in with a cartel?
Looks like they tortured him...but he still managed to get away!!!
The Following User Says Thank You to Davidg408 For This Useful Post:
Josue (04-06-2011)
Old 04-06-2011, 08:44 PM   #183
√-1 2 Σ π
Josue's Avatar
Rewards Points: 18
NOOO!!
I would not be in the forum if that were the case.
I don't know what that scar if from
Do you want a good job or a fast job?
Josue is offline
Old 04-06-2011, 08:44 PM   #184
sparky105's Avatar
this is the back of me
how does this thing work
sparky105 is offline
The Following User Says Thank You to sparky105 For This Useful Post:
jhall.sparky (09-01-2011)
Old 04-06-2011, 09:27 PM   #185
Davidg408's Avatar
Rewards Points: 252
Great picture!
Old 04-06-2011, 09:41 PM   #186
sparky105's Avatar
We had to lift a tranny sitting under this tower .
Old 04-07-2011, 06:41 PM   #187
Buzzy304E
ibuzzard's Avatar
I believe in keeping myself humble,but I'd not like to mock and humiliate myself.I'll leave that task to others.
Welcome to ET., where the clowns....
should of......could of....would of.....might of?
ibuzzard is offline
Old 04-07-2011, 09:04 PM   #188
Rewards Points: 20
What was he doing there?
brian john is offline
The Following 5 Users Say Thank You to brian john For This Useful Post:
BBQ (04-08-2011), ibuzzard (04-16-2011), Mike in Canada (04-08-2011), oldschool (04-07-2011), randas (09-01-2011)
Old 04-07-2011, 09:35 PM   #189
sparky105's Avatar
the transformer was sitting on the ground. I never did get why it was put on the ground. So we had to lift it up onto a steel frame. I was just guiding the spreader down through the rack and than we put in all new secondary cabling and new mains. It was a hospital we had them on a generator for 2 days.
Old 04-07-2011, 09:41 PM   #190
This is what I look like:
NEC Genius is offline
The Following 4 Users Say Thank You to NEC Genius For This Useful Post:
ce2two (09-02-2011), electricalperson (04-16-2011), jhall.sparky (09-01-2011), thegoldenboy (04-07-2011)
Old 04-08-2011, 12:25 AM   #191
Rewards Points: 2,036
HAX aka Interlock aka RobTownfold, is that you??
miller_elex is offline
Old 04-08-2011, 03:56 AM   #192
So how is life on the wild side
willy roux is offline
Old 04-08-2011, 05:35 AM   #193
Rewards Points: 2,000
Maybe you mean she????
doubleoh7 is offline
Old 04-08-2011, 11:07 AM   #194
When you going to put up your pic there Al Roker?
Old 04-08-2011, 12:01 PM   #195
Totally agree. Hey Nathan, after yesterdays eighteen month "new member" intro thread fiasco, how about a no pic/no post policy for the non-paying members. It's kind of funny how the thread ho's with thousands of posts somehow did not bother with this thread. Makes you wonder, who is the pimple faced 7-11 clerk with an NEC PDF posing as an expert.
The Lightman is offline
Old 04-08-2011, 12:27 PM   #196
No, that was Peter, not me.
WorkHacker is offline
Old 04-16-2011, 07:27 PM   #197
Buzzy304E
ibuzzard's Avatar
This is a toilet in an Asian-type lavatory trailer that I was tasked to rewire a couple years ago while in Iraq.It was in a staging yard for trucks,and the mostly-Indian truck drivers often slept there.They use what amounts to a hole,they squat,and they do not use toilet paper.In this case,the hose on the left is used to clean yourself.Worst case,you use your hand and bottled water.Often,these will have a secondary use as a shower.Yummy!
Me,mugging for the camera,you can see the intense constipation on my face:
ibuzzard is offline
Old 04-16-2011, 07:31 PM   #198
Rewards Points: 5,198
Originally Posted by ibuzzard View Post
This is a toilet in an Asian-type lavatory trailer that I was tasked to rewire a couple years ago while in Iraq.They use what amounts to a hole,they squat,and they do not use toilet paper.In this case,the hose on the left is used to clean yourself.Worst case,you use your hand and bottled water.Often,these will have a secondary use as a shower.Yummy!
That does not make a bit of sense to me. What if you had a pair of new socks on...That's just stupid.
P.S. Sorry about your socks.
RIVETER is offline
Old 04-16-2011, 07:40 PM   #199
√-1 2 Σ π
Josue's Avatar
Rewards Points: 18
My dad had to go to those when he went to Hong Knong
Ewww!!
We'd say in Mexico, "fuchila"
Hey, I see an advantage in those toilets, people don't spend a lot of time there, because their legs get tired of ducking like that.
BTW. What did you have to rewire in that toilet?
Josue is offline
Old 04-16-2011, 08:04 PM   #200
Buzzy304E
ibuzzard's Avatar
New panel, lights, receptacles, got rid of individual (ungrounded) exhaust fans in each stall and added large properly-grounded ones at each end of trailer.The panel was change to one which had RCD protection.Water heater /disconnect, main disconnect,and wiring to the sub-panel, set a generator,bonding of everything together,including the metal containment box for the fuel tank, added a fuel-truck bonding point.The soldiers based in this little camp kept stealing the 4' tubes from the exterior lights.I was accused of not completing my project,but another soldier let me in on the scam after I had to return three days running to re-lamp.Can't really blame the soldiers,after placing a work-order,it might take weeks for anyone to look at the problem.Changing defective lamps is way down the priority list in a war zone.I simply eliminated the exterior light fixture.That layer of dust is ever-present.
ibuzzard is offline
Closed Thread
