1 phase vs 3 phase curcuit panel - Electrician Talk - Professional Electrical Contractors Forum
Like Tree92Likes
Old 02-02-2019, 06:57 PM   #1
Eq electric's Avatar
Default 1 phase vs 3 phase curcuit panel
Hey everyone, I simply can't wrap my head around the difference between a single phase and a 3phase curcuit panel, and when it is applied. I have been working in residential for a long time and would like to get some insite if possible, thank you all again in advance
Eq electric is offline   Reply With Quote
Old 02-02-2019, 07:02 PM   #2
Rewards Points: 7,520
Are you an apprentice? Have you been to school yet?
Old 02-02-2019, 07:04 PM   #3
Rewards Points: 16,550
Ahh oui .,,,
very simple the single phase panel typically have two hot conductors with netural while three phase panel do have three hot conductors in the panel.
Be aware the three phase voltage some will not be same as single phase
typicial USA voltage:
208Y120
240D120
480Y277
208Y
240D
480D or Y
Note Y = wye ( useally have netural there)
D = Delta ( most case no netural but some do have 4 wire delta system with netural with oddball line to netural voltage I will cover that later if you need to know )
some super large residentail home do use three phase supply all it depending on POCO specs what they can offer on that.
jelhill likes this.
Old 02-02-2019, 07:07 PM   #4
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 1,960
Where are you from?
Where did you go to school to be an electrician, that didn't teach you about three phase wiring?
We can better help you if you fill out your profile, and tell us more about experience on the introductions thread.
Old 02-02-2019, 07:31 PM   #5
Originally Posted by Signal1 View Post
Where are you from?
I never went to school I started 4 years ago with a master electrician.
micromind likes this.
Old 02-02-2019, 08:28 PM   #6
Rewards Points: 2,480
https://www.electriciantalk.com/f3/a...fields-258186/
Thanks in Advance
The_Modifier likes this.
Old 02-02-2019, 08:30 PM   #7
Where are you from?
Here by your 4th year you have been to school twice and are almost an electrician. Do they have a mandatory school for apprentices where you are?
Old 02-02-2019, 08:33 PM   #8
Signal1's Avatar
Well that's a start.
Are you in the USA? if so what area, there many programs to help you forward your career in this industry, and the jobs will be there if you're qualified.
The long and short of it is you should understand single phase first which you see in a residential panel, the two hots operate 180 deg. out of phase to supply 240 V power to small motor and heating loads. A single phase power supply operating at 60 Hz reaches zero 60 times per second. Not so efficient but ok for smaller applications.
Three phase has a third hot, all three operate at 120 deg overlapping waveform so power remains constant, that is more efficient and is used in primarily commercial and industrial settings for higher power consumption.
This is a brief simplified explanation and as @frenchelectrician stated there are different types of three phase power.
frenchelectrican and jelhill like this.
Old 02-02-2019, 09:38 PM   #9
Thank you so much for the information I certainly appreciate it. I am in Canada and more specifically in Ontario. So when it comes to 1 phase which is seen in residential what a 3phase in a house just be an overkill in that case? If so is that the reason why they use 3 phase in commercial due to heavy usage such as restaurants and larger appliances?
Old 02-02-2019, 09:50 PM   #10
Are you registered as an apprentice in Ontario? Have you been to school yet and what levels have you done so far?
Old 02-02-2019, 10:07 PM   #11
Rewards Points: 25,356
Tesla came up with three-phase power. He loved the number 3 in the first place.
It's also known as poly-phase power.
It is quite more efficient to generate power in a 3-phase alternator.
Indeed, the 'generator' in your car is a 3-phase alternator that uses internal diodes to convert asynchronous 3-phase power into pretty low ripple DC power at 13.8 Volts.
( The connected battery hugely reduces ripple. )
There are a TON of books on the issue. Visit a library or use a search engine.
BTW, 60 Hertz power goes to 0 volts at twice the frequency - so 120 times a second.
Old 02-03-2019, 10:23 AM   #12
Rewards Points: 3,562
Here in Alberta, you would have been to school 3 times.
Old 02-03-2019, 11:13 AM   #13
No I'm not registered, the only chance I got to getting my journeyman papers is if I challenge the exam.
Old 02-03-2019, 11:17 AM   #14
Thanks again for the help, it seems like a very great and supportive platform to be apart of,and I'm glad to be apart of it now.
Old 02-03-2019, 11:32 AM   #15
Find a company to indenture you and get your apprenticeship.. A company might credit you some time, and you can challenge your first year test..
IMO challenging your ticket with no schooling on any of the theory will lead to a disaster.. If you're in doubt, read post #1...
Old 02-03-2019, 11:58 AM   #16
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 354
Try filling out your profile- AS PER THE SIGN UP AGREEMENT.
Bird dog likes this.
The_Modifier is online now   Reply With Quote
Old 02-03-2019, 12:07 PM   #17
[QUOTE=The_Modifier;5156542]
Try filling out your profile- AS PER THE SIGN UP AGREEMENT. [IMG class=inlineimg]https://www.electriciantalk.com/images/smilies/wink.png[/IMG][IMG class=inlineimg]https://www.electriciantalk.com/images/smilies/wink.png[/IMG][/QUOTE
I have filled out everything birthday name Ext.. What am I doing incorrectly? I followed every link provided and fill out everything there is to fill out?!
Old 02-03-2019, 12:14 PM   #18
Bird dog's Avatar
Rewards Points: 1,024
[quote=Eq electric;5156546]
Go to your "User CP" top left of page, then on left look for "Profile Privacy" & choose "Registered Members" from drop down menus (all 7?). Then only registered members will see your details. That may fix it. Also, on the details page there is a button you can click to see what others see from your details. Try that.
The_Modifier (02-03-2019)
Old 02-03-2019, 02:12 PM   #19
Rewards Points: 15,033
If you did all the cables in your user picture, then , I shall consider teaching you about 3 phase wiring. Otherwise.............
Old 02-03-2019, 03:41 PM   #20
You can’t challenge the exam, whoever told you that you can is lying to you. Don’t believe me? Contact the MTCU and ask them. Challenging is for people who have proof of training from other countries, not for guys who work illegally by not being registered. You must be able to provide proof of experience in order to challenge. Where is your proof of hours working with an electrician going to come from?
Single phase subpanel from Three phase panel chavitoracing Canadian Electrical Forum 29 12-23-2018 09:14 AM
3 phase panel unbalance Nomad860 General Electrical Discussion 21 12-17-2018 09:14 AM
Color coding of ungrounded conductors (single phase circuits fed from 3 phase panel) stoive Canadian Electrical Forum 16 05-23-2018 02:51 AM
Converting a 3 wire 3 phase aux panel to 4 wire Elec Trix Commercial Electrical Forum 10 01-13-2018 06:33 AM
3 phase panel (208) used for single phase (240)? CEC09 Canadian Electrical Forum 3 02-10-2016 02:35 AM
