20’ light pole - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
Old 05-10-2019, 07:17 PM   #1
WronGun's Avatar
Rewards Points: 678
Default 20’ light pole
I need to replace a 20’ light pole in a parking lot, it will weight about 200 lbs. I’ve seen videos of people taking these up with buckets, small crane looks safer. Any suggestions ?
WronGun is online now   Reply With Quote
Old 05-10-2019, 07:32 PM   #2
Cow
Rewards Points: 4,860
rent a 19' scissor lift, they're cheap.
telsa likes this.
Old 05-10-2019, 08:10 PM   #3
WronGun's Avatar
Rewards Points: 678
The ground is a little rough where this is going as the pole is on grass about 8’ away from the uneven roadway.
Old 05-10-2019, 08:21 PM   #4
Rewards Points: 225
They make bucket trucks with booms that are rated for a lot of weight. The type on a flatbed truck. They have outriggers so they will work on the uneven ground. Many have 60' booms so you can stay far back on the pavement.
WronGun, Forge Boyz and stiffneck like this.
WronGun (05-11-2019)
Old 05-10-2019, 08:29 PM   #5
Rewards Points: 908
You won't need a very big truck to go over 8 and up 20. They have a lift rating, 200 pounds is nothing. I think the ones built on an F450 with 35' boom will probably handle this but check with the rental people.
WronGun likes this.
Old 05-10-2019, 09:25 PM   #6
Jlarson's Avatar
Rewards Points: 4,056
Call a crane company, if you have the pole sitting there and the base all ready to pick it shouldn't cost too much. At least here it wouldn't.
Old 05-10-2019, 10:07 PM   #7
MikeFL's Avatar
Rewards Points: 490
Heave that mother.
stiffneck and Southeast Power like this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 05-10-2019, 10:48 PM   #8
Southeast Power's Avatar
Rewards Points: 8,644
Rent a towable. Send the skinny kid up to hold on to it.
Old 05-11-2019, 01:29 AM   #9
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,324
These are commonly referred to here as a Materials Handling unit.
@WronGun- they have them for rent at Colvin's
http://www.colvins.com/truck-for-sale/392/43'-Material-Handler
The Following User Says Thank You to Signal1 For This Useful Post:
Old 05-11-2019, 06:16 PM   #10
Rewards Points: 1,611
Put the heads on it wire it up then toss it on the rack on the truck . Back the truck up to the base about 2 feet away . Slide pole onto base with bolt holes over the back 2 bolts . Take a rope make a loop so the pole can't fall over and tie it to truck . Tie another rope to pole and set it up and slap washers and nuts on as fast as you can .
See that was easy . Now go get that check .
kb1jb1 likes this.
catsparky1 is online now   Reply With Quote
Old 05-11-2019, 06:57 PM   #11
Rewards Points: 908
If you're a boy scout, you can raise this easily with three sticks of 1" EMT and a knot called the "icicle hitch" but @WronGun is no damned boy scout.
Old 05-11-2019, 08:04 PM   #12
Rewards Points: 496
I have set dozens of 24 foot steel poles off the roof of my truck. It might not be a recognized safe way to do it but it is quick and easy. Then again I have a 11 foot high box truck. I built a platform with safety rails.
MikeFL and Kevin_Essiambre like this.
Old 05-11-2019, 10:34 PM   #13
WronGun's Avatar
Rewards Points: 678
I would actually pay to see this done. Especially, on this 20’ light pole I have....
Old 05-12-2019, 08:46 AM   #14
trentonmakes's Avatar
Rewards Points: 138
4 head, 30ft pole
Put the head on and strapped it and up it went.
Difficult part was rotating it so the base lined up on the bolts.
Heads kept hitting the boom when trying to turn the pole
Old 05-12-2019, 09:00 AM   #15
Originally Posted by trentonmakes View Post
4 head, 30ft pole
Nice job but, If you setup a little different...
Old 05-12-2019, 09:04 AM   #16
Rewards Points: 138
Theres only set screws holding the heads on.
I was nervous as hell the strap would slide up and take the heads off!
Strapped the pole and it never did move, it tightened a bunch, but didn't move. Lol
Old 05-12-2019, 09:21 AM   #17
I see now.
I like to try to bind the sling just above the tipping point if possible but, it looks like that pole could be too smooth for that.
We dont see many steel poles here, usually direct bury concrete.
One exception coming up for us are some short poles on concrete bases.
segue into another topic..
Old 05-12-2019, 09:46 AM   #18
Rewards Points: 225
Use a hook on the end of your rope or strap. Put a piece of cardboard into the access hole and hook the hook there. Then put a couple half inches around the pole and make the last one right above the center of gravity. It will never slide that way.
Old 05-12-2019, 10:04 AM   #19
Rewards Points: 908
This is the idea but like @HackWork says you don't need the big knot at the end, you can just hook it to the access hole.
trentonmakes likes this.
Southeast Power (05-12-2019)
Old 05-12-2019, 10:11 AM   #20
Rewards Points: 908
I think the American Electrician Handbook has this method illustrated - the book is 100 years old now - they still show the old Amish style pre-equipment methods.
It looks something like this
In 2019, the bucket truck makes more sense.
bostonPedro likes this.
New bluetooth programmable smart switch to Replace an old 2 Pole Sw David Osinga Electrician Apprentice Forum 7 05-02-2019 11:11 AM
Pole light bolt patterns WronGun Commercial Electrical Forum 15 01-26-2019 09:59 PM
Looking for the cover for this pole light eedf3367 Commercial Electrical Forum 6 09-05-2016 01:40 PM
To get feedback on my prices? Angel Advanced Tech Business, Marketing, and Sales 50 09-02-2016 10:38 PM
