3 Phase / 1 Phase question - Electrician Talk - Professional Electrical Contractors Forum
Like Tree19Likes
  • 1 Post By emtnut
  • 4 Post By telsa
  • 3 Post By A Little Short
  • 1 Post By emtnut
  • 2 Post By PlugsAndLights
  • 1 Post By emtnut
  • 1 Post By Ultrafault
  • 1 Post By emtnut
  • 1 Post By macmikeman
  • 2 Post By macmikeman
  • 1 Post By emtnut
  • 1 Post By MechanicalDVR
Closed Thread
Old 10-22-2016, 08:51 PM   #1
J91
Default 3 Phase / 1 Phase question
Hi guys,
Im told an office runs 120v, 3 phase with a hi leg. However the wall sockets are for single phase (they look like the residential ones). 3 phase type equipment is being made for that office, however since the wall sockets look like the single phase ones, the machiney cant be plugged in. Since im told the office runs 3 phase, can the wall sockets just be changed so a 3 phase machine can be plugged in or is it more complex than that?
Thank you.
J91 is offline
Old 10-22-2016, 08:55 PM   #2
Band Member
emtnut's Avatar
Rewards Points: 2,500
Originally Posted by J91 View Post
Hi guys,
Thank you.
I hate it when I'm told
readydave8 likes this.
emtnut is offline
Old 10-22-2016, 08:59 PM   #3
Rewards Points: 26,836
Hi guys,
Thank you.
Basically, NO.
Basically, YES.
telsa is offline
Old 10-22-2016, 09:14 PM   #4
A Little Short's Avatar
Rewards Points: 1,146
Hi guys,
Thank you.
TRANSLATION.....
This is my office space, the electrician said I need 3 phase run to the wall receptacles. Can't I get by with just changing receptacles and not spend all that money?
readydave8, glen1971 and emtnut like this.
A Little Short is offline
The Following User Says Thank You to A Little Short For This Useful Post:
MechanicalDVR (10-22-2016)
Old 10-22-2016, 09:18 PM   #5
Band Member
emtnut's Avatar
Originally Posted by A Little Short View Post
TRANSLATION.....
emtnut is offline
Old 10-22-2016, 09:21 PM   #6
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
Swap out your single phase receptacles for the VFD type. Done.
P&L
readydave8 and emtnut like this.
PlugsAndLights is offline
Old 10-22-2016, 09:23 PM   #7
J91
Hi guys,
Thank you.
Basically, NO.
Basically, YES.
Thanks for the reply.
Hi guys,
Thank you.
TRANSLATION.....
Not really. I dont mind spending some money to get it right (though obviously the less i have to spend the better). The equipment manufacturer said the machines require 3 phase receptacles, and that the machinery can't be plugged in a single phase type socket. The plant electrician is away for a while so i just wanted to get some opinions/options as i need to see if there's a way to do it as soon as possible preferrably.
J91 is offline
Old 10-22-2016, 09:31 PM   #8
Band Member
emtnut's Avatar
Wher'd he go
emtnut is offline
Old 10-22-2016, 09:45 PM   #9
fertilizer distrubuter
Ultrafault's Avatar
Rewards Points: 554
Who would do it if your electrician is gone?
emtnut likes this.
Ultrafault is offline
Old 10-22-2016, 10:00 PM   #10
Safety Pin Member
None of us will be in a position to give you what you need. You need
to wait for your plant electrician to return, or get another another
electrician in, to find out what it'll take to run 3-phase, at the required
voltage and current, to the locations required.
P&L
Old 10-22-2016, 10:03 PM   #11
Band Member
emtnut's Avatar
Hi guys,
Thank you.
Honestly, given if I was TOLD that the office was 120V 3phase, with a bitch leg, that gives you 60Vac , and 104V on the bitch leg.
You would have to talk with the mfr to ensure that their equipment was either compatible with 60Vac 3 ph, and/or that they could work on the high leg at 104 Vac.
Most mfr's will work with you on these types of things.
either that, or wait till your plant sparky comes back
emtnut is offline
Old 10-22-2016, 10:13 PM   #12
Rewards Points: 20,637
About J91
What is your electrical related field/trade:
General Location
Florida
Another illegal alien swam across the Rio Grande again.
emtnut likes this.
Nationalize all foreign owned farmland now. Now.
macmikeman is online now
Old 10-22-2016, 10:16 PM   #13
Band Member
emtnut's Avatar
Like this !
emtnut is offline
Old 10-22-2016, 10:23 PM   #14
To J91 the original poster: These other guys are jerking you around. Here is a picture of a three phase receptacle outlet. Open up your outlets and you will see there is three wires sticking out connected to the old 120 volt ones. Simple to fix when you use this three phase style one. Three terminals for three wires. Easy peasy! Good luck! You should be able to find lots of those outlets down at ACE Hardware stores.
glen1971 and Jamato like this.
Old 10-22-2016, 10:26 PM   #15
Band Member
emtnut's Avatar
You're giving all our trade secrets away MacMike ...
emtnut is offline
Old 10-23-2016, 12:05 AM   #16
Rewards Points: 23,882
Guys that come here and lie on the 'about me' section really tick me off. Especially when they ask ridiculously ignorant questions.
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
We apologize for any inconvenience that this may have caused. This thread should be closed.
MechanicalDVR is offline
The Following 2 Users Say Thank You to MechanicalDVR For This Useful Post:
glen1971 (10-23-2016), telsa (10-23-2016)
Old 10-23-2016, 04:25 AM   #17
Rewards Points: 21,898
The best answer is get a electrician to come in and deal with it or your plant electrician come back.
this is very compacited item and it not that easy to convert from single to three phase unseen.
sorry.,,
<!-- / message --><!-- sig -->
frenchelectrican is offline
Closed Thread
3 Phase Question re same phase in conduit...... conclavicus General Electrical Discussion 21 07-31-2016 08:22 AM
interesting question: what happen to same phase hot touching each other? mike883 General Electrical Discussion 26 06-13-2016 09:11 PM
3 phase to single phase te12co2w PLCs, VFDs, Motors and Controls 62 03-14-2016 10:47 AM
Three Phase Transformers - Primary/Secondary Calculations JasonCo General Electrical Discussion 33 03-08-2016 09:55 PM
Can be both a three or single phase motor just the cowboy General Electrical Discussion 2 01-21-2016 10:36 AM
