45 degree seal tite fittings - Electrician Talk - Professional Electrical Contractors Forum
Old 05-16-2015, 06:06 PM   #1
Rewards Points: 672
Default 45 degree seal tite fittings
Why is it so hard to get 45 degree seal tite fittings ????????????????????????
No one local has them; not the supply house, not the home depot. I had to order them from Amazon. The next best choice was MSC for $25 each !!!!
Spark Master is offline   Reply With Quote
Old 05-16-2015, 06:14 PM   #2
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Just like its hard to get 90DEGREE duplex BX connectors. It seems in decades past these items were on shelves in supply houses and stocked in shops and trucks.
Old 05-16-2015, 07:08 PM   #3
Rewards Points: 1,224
Most of my work was industrial and I used a lot of 1/2 and 3/4" 45° sealtight connectors and never had any problem getting them.
I checked the online stock for the local Gexpro and they have 1/2. 3/4, 1, and 1 1/2 on the shelf.
pjholguin (07-14-2015)
Old 05-17-2015, 06:10 PM   #4
Watt Pusher
B-Nabs's Avatar
Rewards Points: 480
I can usually get duplex BX 90s next day around here, they are made by Arlington. As for sealtite 45s, I have never seen one in person, only in pictures.
Old 07-10-2015, 08:27 AM   #5
blueheels2's Avatar
Rewards Points: 332
Learned something. I didn't know they made a Bx duplex 90.
blueheels2 is offline   Reply With Quote
The Following 4 Users Say Thank You to blueheels2 For This Useful Post:
Cow (07-10-2015), JW Splicer (07-14-2015), MDShunk (07-10-2015), SdCountySparky (07-10-2015)
Old 07-10-2015, 10:19 AM   #6
Rewards Points: 6,421
Same here. I can get 45 degree sealtite fittings all day long at a number of places, but I don't think I've ever even seen a duplex BX 90 degree fitting. I imagine it would be handy for cut-in boxes.
Old 07-10-2015, 10:57 AM   #7
Going_Commando's Avatar
Rewards Points: 1,620
Ditto.
Old 07-10-2015, 12:36 PM   #8
Rewards Points: 672
Post a picture of a duplex 90 BX. I never seen those either. But I brought a stash of 45 seal tight fittings!
Old 07-10-2015, 01:18 PM   #9
Rewards Points: 74
Arlington version
AU Facilities is offline   Reply With Quote
Old 07-10-2015, 07:37 PM   #10
corn-fused
papaotis's Avatar
Rewards Points: 620
thats definetly a newer style than the last one i saw
The Following User Says Thank You to papaotis For This Useful Post:
Old 07-10-2015, 07:44 PM   #11
Rewards Points: 672
That looks like a romex connector.
Old 07-10-2015, 07:46 PM   #12
corn-fused
papaotis's Avatar
Rewards Points: 620
believe youre right. those shuold be round holes!
Old 07-14-2015, 12:54 AM   #13
More than lead and elbows
JW Splicer's Avatar
Rewards Points: 1,130
well I'll be darned, they do exist... If that's a romex duplex... I didn't even know they made those either... Huh, learn something new here every day.
Every once in a while I get to hang a pothead!
JW Splicer is offline   Reply With Quote
Old 07-15-2015, 10:19 AM   #14
Rewards Points: 74
Yes it does but the spec say Zinc die-cast. Twin screw for Flex • NM • AC • MCI steel and aluminum jacketed cables • MCI-A cable.
I have used them for MC with no problem, We actually use the snap in version of the Arlington connectors for MC and they work great.
Gary
proper seal tite connector installation butcher733 General Electrical Discussion 32 01-31-2015 05:58 PM
Seal-off fittings electric_mayhem General Electrical Discussion 4 08-18-2014 09:37 PM
Fishing through 1/2" non metallic seal tite Incubus311 General Electrical Discussion 23 03-13-2014 10:57 AM
seal tite without compression fittings noarcflash Commercial Electrical Forum 24 04-17-2012 03:26 PM
seal tite grounding dogg Commercial Electrical Forum 4 06-11-2011 05:08 PM
