Cadweld - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
Old 02-28-2020, 07:05 AM   #21
VELOCI3's Avatar
Rewards Points: 118
Old 02-28-2020, 04:13 PM   #22
Senior Moment
drsparky's Avatar
Rewards Points: 372
Is that insulated wire?
Old 02-28-2020, 05:19 PM   #23
VELOCI3's Avatar
Rewards Points: 118
Yeah. Grounding triad with 3 10’x3/4 copper clad rods.
Old 02-28-2020, 06:16 PM   #24
joe-nwt's Avatar
Rewards Points: 3,602
Why wouldn't you use bare?
Old 02-28-2020, 07:21 PM   #25
VELOCI3's Avatar
Rewards Points: 118
The DWGs didn’t spec bare. I had the #2 in stock. The ground ring that I had to repair was bare 2/0 solid. I couldn’t find the 75’ I needed to repair it (excavator dug it up) so I used 2/0 bare copper.
Old 03-04-2020, 05:08 AM   #26
VELOCI3's Avatar
Rewards Points: 118
While we're on the subject, with the 2 piece clamp together molds, I like to put a blob of duct seal around the protruding cable. I find this helps that prevent that eventual leak that shortens the life of the mold. Once a leak starts it's there forever as it seems to etch its way out of the mold. This trick is particularly useful if you encounter old 7-strand ground wire that doesn't quite fit the hole in the mold.
If the sides are getting worn out wouldn’t the inside area be wearing out too?
Old 03-04-2020, 09:12 AM   #27
joe-nwt's Avatar
The sides seem to wear out faster. The molds are relatively soft, I think every time you clamp a wire or adjust the position of the mold once it is clamped onto the wire, a small bit of abrasion takes place. Once a leak happens, it seems to accelerate the wear many times over. I dunno, I even do it on new molds. Seems like good prevention for a few ¢ worth of duct-seal.
Old 05-23-2020, 05:37 PM   #28
Southeast Power's Avatar
Rewards Points: 9,262
Battery powered igniter. Fire in the hole boys.
Old 05-23-2020, 09:52 PM   #29
Rewards Points: 170
https://youtu.be/u3wMKYsd588
I think you missed your calling as a cameraman.
Mobius87 is offline   Reply With Quote
The Following User Says Thank You to Mobius87 For This Useful Post:
Southeast Power (05-24-2020)
Old 05-23-2020, 10:04 PM   #30
Chief Flunky
Rewards Points: 366
It’s actually the moisture that does it. Once it is up to temperature you will have fewer problems. Heating it up with a torch is not optional.
Old 05-23-2020, 10:28 PM   #31
joe-nwt's Avatar
It is. You have to keep the torch on it for a while. You can actually take what appears to be a dry, cold mold, start heating it with the torch and you can see the moisture start to come out of the mold where you first apply the torch. I then chase the moisture to the far end of the mold and viola, dry mold.
No splattering on the first weld which is the indication of moisture.
The Following User Says Thank You to joe-nwt For This Useful Post:
