Concrete pole bases. Precast or pour in place?? - Electrician Talk - Professional Electrical Contractors Forum
View Poll Results: Precast or pour 7' pole bases with 4' above grade
Precast for me 3 33.33%
I pour mine 6 66.67%
It depends on the time allowed for installation 0 0%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
Like Tree15Likes
Old 05-12-2019, 08:25 AM   #1
Southeast Power's Avatar
Rewards Points: 9,058
Default Concrete pole bases. Precast or pour in place??
We have 10 - 7' pole bases for an upcoming job. Our estimator put in a $750 allowance for them thinking we would tie steel and pour using sonotube. I prefer to buy them precast.
Is there a diminishing point somewhere considering the number of poles where pouring or precast has an advantage over the other??
Old 05-12-2019, 12:28 PM   #2
Rewards Points: 20,695
This whole story is biased due to the fact that you are digging in sand , which means you can hire one apprentice to dig the whole job up in an afternoon, saving yourselves the tens of thousands that it costs the rest of the country to excavate that job, resulting in enough saved cash to be able to easily purchase the pre cast poles........
Nationalize all foreign owned farmland now. Now.
Old 05-12-2019, 01:09 PM   #3
This site was de-mucked down to limestone and then filled in with 10' of compacted fill.
This one isn't a shoveling job.
Old 05-12-2019, 11:41 PM   #4
Rewards Points: 748
Depending on the soil type and conditions, round pole bases have to be deeper in the ground. The poles that I used required a minimum 24 inch round with six feet in the ground or 24 inch square 4 feet deep. Make the form a pyramid shape and you can down size a bit. 24 X 24 at the bottom and 18 X 18 at the top. Sono tube $100. vs a sheet of plywood $12.00.
Precast you need a crane or other means to lift them to set in place. Pouring them you can work at your own pace.
kb1jb1 is online now   Reply With Quote
Old 05-13-2019, 03:03 AM   #5
Rewards Points: 7,869
Precast needs a uniform hole, level bottom, same depth, and a crane, and it might lean over time. Pour in place is easier to plumb up. What does the job scope say?
sbrn33 likes this.
Old 05-13-2019, 08:12 AM   #6
The plans show a pole base and a bolt pattern with the steel requirements. I like having the luxury of pacing ourselves and pouring our own but, I might not have the time.
Old 05-13-2019, 08:49 AM   #7
MikeFL's Avatar
Rewards Points: 840
You can always sub it out to a concrete crew, preferably one you've worked with in the past.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 05-13-2019, 09:15 AM   #8
Cow
Rewards Points: 5,104
We ALWAYS pour our own bases.
Now I'm working with a GC we haven't done business with before, and it sounds like all they've ever seen is precast used.
So we'll see, I'm not opposed to precast if the GC is willing to have the dirt sub unload and place them with our assistance.
micromind likes this.
Old 05-13-2019, 10:34 AM   #9
sbrn33's Avatar
Rewards Points: 3,564
$750 per pole base? We have good dirt here and no rock, I figure at least $1,500 and still feel like I lose my ass.
Cheapest is to sub it out to the concrete guy but then you have to watch them like a hawk or they will **** you.
10 I would do that a few more I may think about precast, especially if it is a spec type of job. How much is a precast?
Old 05-13-2019, 10:34 PM   #10
Rewards Points: 256
I can hire the same guy with an auger truck to dig a hole for a pour in place or dig and set a precast base for the same price. I haven't done a bigger site job in a while, but I seem to remember somewhere between 15-20 being the break even point that precast begins taking over poured in place. Time also being a factor. Precast bases are always at minimum 4-6 weeks out, after you receive anchor bolts from supplier.
Obviously getting the GC to be responsible for the bases being the best way, subbing to a reliable concrete guy 2nd, pouring your own 3rd, then precast, unless the numbers make sense.
Techy is offline   Reply With Quote
Old 05-14-2019, 06:45 AM   #11
Rewards Points: 2,392
In that respect it's like anything else, are you looking to fill more hours and do more work or are you already stretched?
As @sbrn33 said $750 sounds way low based on some of the other pricing you've mentioned. Digging the hole, the rebar, the form, the bolts ... but also, waiting for the concrete truck, the liability you assume, the chance of making an expensive mistake, I can't see $750.
sbrn33 and Kevin_Essiambre like this.
This too shall pass.
Southeast Power (05-15-2019)
Old 05-15-2019, 07:44 PM   #12
They put it off long enough that we are just going to hire a CW out of the hall and make this his baby for a couple of weeks.
MikeFL likes this.
Old 05-16-2019, 09:28 AM   #13
canbug's Avatar
Rewards Points: 2,028
Both, precast for streetlights and pour in place for our high mast lighting. The pour in place are generally 48" wide and up to 30' deep. I don't want a precast for that.
Tim.
Kevin_Essiambre likes this.
Old 07-16-2019, 08:26 PM   #14
We ended up pouring them.
Every one of them came out nice.
The poles arrived, the guys put a couple of heads on.
All was going well until we noticed something didn’t look right.
It looks like a change order to me.
Old 07-16-2019, 08:33 PM   #15
Small Potatoes
flyboy's Avatar
Rewards Points: 4,249
The change order should augment the original $750 you got. $75 a pour sounded cheap to me.
Southeast Power likes this.
A Faith Not Tested Cannot Be Trusted
Old 07-16-2019, 08:35 PM   #16
Band Member
emtnut's Avatar
Rewards Points: 2,504
Adaptor plate ... charge large for the extra ... and yer done !
Old 07-16-2019, 08:58 PM   #17
Our line item was $7,500 for 10 bases. We paid $1,200 for the sonotube, $300 for the steel, $750 for the auger attachment, $1,200 for the concrete, the bad part. 100 man hours.
Now we will have to cut off the existing bolts, 40 of them, core drill out and install some fancy ass Hilti product and hardware.
We will have to patch over the cut off bolts so they don’t bleed rust.
We did hear a sister project in another state had the same problem.
The complication for us is the 150mph wind load requirement We have in Miami.
The first thing I thought was an adaptor plate. It will have to have the blessing of a PE.
flyboy likes this.
Old 07-16-2019, 09:19 PM   #18
460 Delta's Avatar
Rewards Points: 1,722
Just curious, but I assume you used a 3500 psi no air mix? What does a yard of concrete run down there?
micromind for moderator- make ET more industrial
Old 07-16-2019, 09:39 PM   #19
They made us use an air mix.
The specs call for 4000 PSI, 150 PCF with 5-7% Air Entrainment. We will need a mix design specifically for this, you can use the mix number you have for Axtell #1579354 for reference.
This was almost impossible to find in our region.
All of the exterior pours require it. We were the first to call out that spec. We had to find a vendor that could provide documentation.
It was just under $1,700 for two six yard deliveries a week apart. They poured 5 at a time.
Old 07-16-2019, 10:22 PM   #20
stiffneck's Avatar
Rewards Points: 1,298
We've used the Hilti products but only exactly what you need. Shelf life of this stuff is minimal. We ended up throwing away what we had the next time we needed it.
In Bred Electrical Worker
The Following User Says Thank You to stiffneck For This Useful Post:
Southeast Power (07-16-2019)
EC install forms, rebar and pour concrete Southeast Power Commercial Electrical Forum 24 01-15-2019 09:00 AM
Strut to hollow precast concrete ceiling? Gnome General Electrical Discussion 29 11-04-2017 09:14 PM
Creating a "service call kit" for your second truck HackWork Business, Marketing, and Sales 41 04-07-2017 12:12 PM
