Heat Trace installed in drain line - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 1 Post By Kunolop
  • 4 Post By MDShunk
  • 1 Post By Kunolop
  • 1 Post By 99cents
  • 1 Post By MikeFL
  • 1 Post By MechanicalDVR
Old 03-22-2018, 05:29 PM   #1
Kunolop's Avatar
Rewards Points: 83
Default Heat Trace installed in drain line
I have installed heat trace in roof drain lines before and have a customer which we wired their building request heat trace be installed the entire drain line because it’s freezing up all winter. The line is 4” PVC and is 150’ long (mostly underground) until it hits the catch basin-man hole. In looking on the web nothing really states that this can be installed like this, anybody else come across this?
Kunolop is offline   Reply With Quote
Old 03-22-2018, 05:33 PM   #2
Rewards Points: 14,119
Sewer gas is explosive. Needs to be traced on the outside.
Old 03-22-2018, 05:39 PM   #3
Kunolop's Avatar
Rewards Points: 83
No, rain water only. Is not connected at all to the sewage system.
Old 03-22-2018, 06:32 PM   #4
canbug's Avatar
Rewards Points: 1,874
I know they build a kit that can be installed in the drain. I think it was at a farm supply house.
https://www.heatersplus.com/ilh.html
Tim.
Old 03-22-2018, 06:39 PM   #5
Rewards Points: 21,896
Run the heat trace outside of the PVC pipe.,
second thing .,
How deep this pvc drain pipe is in and pitched correct ?
Old 03-22-2018, 06:43 PM   #6
Rewards Points: 6,421
Raychem. Any other brand and you're already screwing up.
Old 03-22-2018, 06:51 PM   #7
Kunolop's Avatar
Rewards Points: 83
second thing .,
Pipe is 5’ under a lumber yard asphalt slab, is 4” and draining properly when it’s not frozen. Raychem rep says to go ahead and use GM-2X line? Guess I will
Old 03-22-2018, 07:47 PM   #8
Rewards Points: 3,006
In the US roof drains don't typically go into sewer lines, they go into storm drains.
Old 03-22-2018, 07:56 PM   #9
If the drain is 5' under ground, what is your frost line?
Sent from my XT1254 using Tapatalk
cl2sparky is offline   Reply With Quote
Old 03-22-2018, 08:00 PM   #10
Kunolop's Avatar
Rewards Points: 83
Normally 3-4’ here under regular conditions, but in a high traffic area it can get to 8’!
Old 03-22-2018, 08:12 PM   #11
Wow!!
Old 03-22-2018, 08:35 PM   #12
Pffft. Raychem, Thermon, EasyHeat, Nelson, same chit.
cl2sparky likes this.
Old 03-22-2018, 08:40 PM   #13
Put self reg inside the pipe but go to a manufacturer's website to check out maximum run length and circuit breaker size. 240V cable most likely.
Old 03-22-2018, 08:45 PM   #14
Phone EasyHeat in Elmira. Good guys.
Old 03-22-2018, 09:06 PM   #15
MikeFL's Avatar
Rewards Points: 608
We have storm sewers and we have sanitary sewers.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 03-22-2018, 09:10 PM   #16
Chief Flunky
Rewards Points: 338
Sewage plants call it I&I. Rain can easily overload and overflow a wastewater plant. Older systems in the US ran them together. Newer systems separate them.
Old 03-22-2018, 09:20 PM   #17
Exactly, this isn't some third world country.
MikeFL likes this.
Old 03-22-2018, 10:09 PM   #18
MikeFL's Avatar
Rewards Points: 608
It took a while to digest why we call the **** sewer a "sanitary" sewer. It creates sanitary conditions in the buildings which they are connected to.
And storm sewer doesn't sound as clean as it is, because of the word sewer. But that's what we call it in the code books.
Our city has a marina. They call it the City Yacht Basin. To me a basin is something my mother handed me when I was sick so I could vomit in it. I'd much rather see the city marina called the "City Marina". But I'm not on city council.
GPS Timers
(833) GPS-TIME
Heat Pump & Zone System A Little Short General Electrical Discussion 35 10-31-2017 09:22 AM
Heat trace WronGun Residential Electrical Forum 25 10-02-2017 07:02 AM
what is the hot and neutral of this kind of heat trace cable ? mike883 General Electrical Discussion 15 07-18-2017 02:02 AM
Buried Residential Service along Property Line Ceuls Canadian Electrical Forum 22 03-27-2017 04:39 PM
MI Heat Trace glen1971 Industrial Electrical Forum 8 01-21-2017 07:14 PM
