Mobile Office 50+30amp - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 2 Post By HackWork
  • 1 Post By Kevin_Essiambre
  • 1 Post By electricguy
Old 08-27-2019, 04:27 PM   #1
Rewards Points: 6
Default Mobile Office 50+30amp
I’m in process of building a mobile workshop/office (shipping container). I need a/c, reefer, dryer, lighting & outlets. I need it to be able plug into service. A lot of the places I set up have 30&50 amp plugs. And the minimal amount of onsite electrical work is best. Any thoughts on dual panels; one 30amp and one 50amp service panel with plug hookups; divide the loan appropriately.. Is there a better way or a big downfall to doing it this way? Thanks
-Nick
Pasture714 is offline   Reply With Quote
Old 08-27-2019, 04:47 PM   #2
Rewards Points: 1,477
-Nick
Why not just setup your system for 30A and use a cord adapter when you only have a 50A receptacle to plug into?
Old 08-27-2019, 05:01 PM   #3
Rewards Points: 6
I worry 50amps won’t slways be enough. 30+50=80amps. I understand it’s not 80amps total but I would divid the load between each separate service.
-Each service would look like-
30amp panel: lights, outlets, reefer
50amp panel: A\C, 220 outlet, washer/dryer
Old 08-27-2019, 05:06 PM   #4
So if you only had a 30A outlet at that location, you wouldn't be able to use the AC or the washer/dryer? That's silly.
If you think that you will need more than 30A, then set the system up for 50A and use an adapter when there is only a 30A receptacle.
Old 08-27-2019, 07:13 PM   #5
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 284
-Nick
You're over thinking this, do as hackwork has said, one panel for 50 amps and use a cord that will allow you to plug into a 30 amp.
Also, please fill out your profile.
Old 08-27-2019, 07:15 PM   #6
Beam Me Up Scotty
Rewards Points: 284
30+50 does in fact equal 80 amps... at 240 volt. You'd have 160 amps if it's 120 volts... assuming you're using single phase gear. You could always go three phase...
electricguy likes this.
Old 08-27-2019, 07:41 PM   #7
Rewards Points: 6
Ya your right; I’m over thinking it. I’ll just put a 50amp plug and work with that! & yes It will be 3 phase. Almost every place Iv been has both a 30&50 plug on panel; that’s why I was thinking of taking advantage of both. I just meant I would not have the full 80amps on one panel; so I would have to use accordingly so breakers aren’t tripping all the time.
Thanks
Old 08-27-2019, 08:19 PM   #8
Rewards Points: 3,012
Thanks
Here that is a relocatable building and would need a silver lable applied by the Safety officer so a permit is needed.
Kevin_Essiambre likes this.
