New 400 amp service with Generator and distribution - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
  • 9 Post By Southeast Power
  • 6 Post By Southeast Power
Old 01-12-2020, 05:23 AM   #1
Southeast Power's Avatar
Rewards Points: 9,368
Default New 400 amp service with Generator and distribution
This is one of many of our generator design-build projects.
Typically we find a way to intercept the underground from the utility transformer, route it through a new meter, install a main and an ATS.
The load side of the ATS then feeds the building.
Each one of those 12 splices took almost 2 minutes.
This job was a bit different as the one transformer fed multiple buildings.
We installed a splice box in front of the utility transformer and had the line crew determinate the building laterals and pass them under the transformer pad into our hand hole.
At the same time, they terminated our new parallel 4/0 from our meter onto the transformer.
This is the second phase of this project.
This trip we installed the panelboard guts and pulled and terminated the wire the first day, the second day we had our utility side work and splices completed.
We finished up some control work the third day and anchored the tank to the slab.
All of the work was exterior so we used "Earlham" quadplex which is 4- 4/0s we added a ground wire in between the enclosures and the generator. It's rated as XHHW and can be used DB or in conduit.
https://www.nassaunationalcable.com/...ogle_shopping#
micromind, zac, glen1971 and 6 others like this.
Old 01-12-2020, 05:33 AM   #2
I want to add that that job would have been near impossible without a mechanical stripper like this one:
The insulation was very hard to cut into and strip on that cable.
I left my Dewalt stripper at home not thinking it would be needed with such small cables. Big mistake!!
micromind, zac, glen1971 and 3 others like this.
Old 01-12-2020, 09:30 PM   #3
Rewards Points: 3,564
Nice looking installation!
Southeast Power (01-13-2020)
Old 01-13-2020, 07:22 AM   #4
VELOCI3's Avatar
Rewards Points: 122
Is this in Canada?
Old 01-14-2020, 02:18 AM   #5
Originally Posted by VELOCI3 View Post
Is this in Canada?
No. It's in rural northern Florida.
Old 01-14-2020, 05:58 AM   #6
VELOCI3's Avatar
Rewards Points: 122
We max out at 200 amps before we change to CT’s in NY
Old 01-14-2020, 06:01 PM   #7
It’s 600amps here.
Old 01-14-2020, 06:46 PM   #8
VELOCI3's Avatar
Rewards Points: 122
Originally Posted by Southeast Power View Post
It’s 600amps here.
Are the tabs on the meter the same dimensions as the 200 amp meters? Are the jaws on the meter socket made differently or are they the same as the 200 amp bypass jaws. I see there is more lug space but curious if the meter connection points are different.
Old 01-14-2020, 11:39 PM   #9
A 200 amp meter will fit in the jaws perfectly but, they look the same to me but, the meter crew that came out said they were different. The 600 amp and 800 amp bolt in place.
