Receptacle tension test - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree45Likes
Old 09-28-2018, 02:07 PM   #21
WronGun's Avatar
Rewards Points: 658
I have a Woodhead receptacle tension tester. It's actually a required test as part of the International Property Maintenance Code (aka "rental code"), which has the force of law in all but 8 states. They might be a little pricey, but they're not too bad when they show up on eBay. They're basically a fish scale connected to two receptacle prongs. When you own one, it makes for easy upsells. For instance, a common resi service call is to replace a receptacle where the plug doesn't stay in tight. This is generally the "vacuum cleaner outlet" or a receptacle on the kitchen countertop most popularly used for interchanged countertop appliances. "You want me to check the others while I'm here", you should say. Sometimes turns a quickie service call into something more worthwhile.
Definitely seems like a great up-sell tool !
I can think of many times I could’ve used this..
Old 09-28-2018, 02:07 PM   #22
Mensa Player
Rewards Points: 645
Originally Posted by WronGun View Post
Sure replacing all makes more money. However , even though I can recommend it, I only do what the facility director asks for.
Of course. But in this instance, you have mutually beneficial reasons to push them towards upgrading all of them.
Old 09-28-2018, 02:10 PM   #23
cuba_pete's Avatar
Rewards Points: 2,813
Default Cletus strikes again...
Cletus installed all of the receptacles upside down… You know… Ground pin up. Now whenever the plug gets loose the ground pin comes out and all those neutral/ground bonds he made down the line energize the chassis of the medical equipment…
Troll in Training
Old 09-28-2018, 02:19 PM   #24
Rewards Points: 1,421
The hospital job can turn into a repeat, because it's required every 12 months. You only have to check the ground pin in patient care areas, unless the specs say otherwise. The actual hot and neutral prongs are not a required test under NFPA 99, but it would be dumb not the check them otherwise. Be advised that if the job specs require that the instrument be calibrated or that the instrument is UL listed, the Woodhead tester will not suffice. If the job specs don't require that, the Woodhead tester is fine.
WronGun (09-28-2018)
Old 09-28-2018, 02:42 PM   #25
Rewards Points: 4,396
Yeah, cause like, why would you want to make money?
If the hospital says that 80% needs to be replaced, why leave 20%?
Between the time it would take to do the testing/reporting and the cost of continued future repair of the remaining 20% on a piecework basis, the savings in replacing all of the outlets can easily be articulated to the hospital.
Actually with a hospital you're probably right, it will be a costly pain in the ass to shut down, so might as well do them all.
Now unlike you, I would not come back in a year and offer to re-test with a greased receptacle tester. That's just wrong.
Incidentally ... I wonder if hospital grade receptacles have slid in quality the way regular receptacles have, or they're still as good as ever?
HackWork likes this.
Old 09-28-2018, 02:57 PM   #26
Mensa Player
Rewards Points: 645
For the price they should give you a bubble bath and whisper sweet nothings in your ear.
telsa and splatz like this.
Old 09-28-2018, 03:01 PM   #27
WronGun's Avatar
Rewards Points: 658
1 of 3 of my only T/M accounts. It always works out well especially after marking up material. We have plenty of time for shutdowns or waiting for patients to clear out of rooms
Old 09-28-2018, 03:52 PM   #28
MikeFL's Avatar
Rewards Points: 2,990
I would only replace the ones that are below the spec or marginal. I wouldn't assume they are all wearing the same amount, there may be receps that get used / abused a lot, others that have never had anything in them.
I might test three times and report the lowest reading, and tell them I do it that way - this is not a super controlled test.
Like those girls I worked with in college.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 09-28-2018, 08:58 PM   #29
Rewards Points: 1,440
Reminds me of the wanting the 'unused' part joke!
MikeFL likes this.
Old 12-02-2018, 11:12 AM   #30
3rdUserName's Avatar
Rewards Points: 8
Never heard of this but makes total sense. I'm sure well used, old recepts cause all kinds of issues. Pretty cool. Well, looks like it just stopped raining... ugghhhh. Time to put down the toys n pick up the tools. As always, Thanks for the info.
3rdUserName is offline   Reply With Quote
Old 12-02-2018, 12:14 PM   #31
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 5,504
Unfamiliar with this type of test.
One of my hospital accounts wants us to tension test every Receptacle and replace ones that don’t meet their criteria, which they claim is close to 80%.
Can anyone recommend a tester ? I looked on amazon and it looks like a plug tester only 10 times more expensive.
Did it all the time when I worked in the hospital. The grounding was what they mostly were concerned about. It had to engage first and release last. It was a yearly requirement. Doing the test was quick and I normally swapped out loose ones on the spot. It's amazing how quickly they wore out.
There in an NFPA manual for hospital facilities. Don't remember the number, (99?)
I would recommend you reading 99 or buying it before doing hospital work. The joint commission will head hunt if things go bad later.. The only excape would be if the hospital had written a specific contract detailing what was to be done and it was signed off by their competent licensed engineer.
Old 12-02-2018, 01:18 PM   #32
Watt Pusher
B-Nabs's Avatar
Rewards Points: 466
Up here, "blade tension" testing is part of the CSA Z32 standard for patient care areas (also covers grounding and voltage drop). When you build a patient care facility you have to hire a 3rd party to test the patient reference grounding, voltage drop, and blade tension, and it all goes in a report to the engineer as part of the close out documents. The company we hire uses a mechanical one, looks similar to the Woodhead posted.
MechanicalDVR and glen1971 like this.
Old 12-03-2018, 10:42 AM   #33
jw0445's Avatar
Rewards Points: 1,702
@WronGun how did you ever make out with this?
Old 12-03-2018, 04:49 PM   #34
Rewards Points: 1,694
Act like you have a special tool and just use the basic 3 light tester. Then replace anything that looks old.
This is for a hospital, right tool for the job this is for a certification of the hospital and papering this job is WRONG. Papering any testing job is wrong.
glen1971 likes this.
Old 12-03-2018, 05:49 PM   #35
Switched's Avatar
Rewards Points: 8,950
Just curious if they have a certified tool. I looked online and the only one I could find was the Ideal one, which has been discontinued. The only other tool I could find was that Woodhead unit, which has no certification.
What do they do when they have a requirement that no tester meets?
Old 12-03-2018, 07:02 PM   #36
$975!
Ouch
I may go with the woodland for $100
Buy cheap get cheap results you want a quality product that will give consistent results
Old 12-03-2018, 07:03 PM   #37
I would submit specifications of the tester and have them approve it.
Old 12-05-2018, 06:23 PM   #38
Yeah, cause like, why would you want to make money? [IMG class=inlineimg]https://www.electriciantalk.com/images/smilies/vs_laugh.gif[/IMG]
Now unlike you, I would not come back in a year and offer to re-test with a greased receptacle tester. That's just wrong. [IMG class=inlineimg]https://www.electriciantalk.com/images/smilies/devil.png[/IMG]
I have a couple of the red Hubbell ones from about 20 years ago, built like a tank. Nicest receptacles I've ever seen, other than being all straight blade screws.
Kawicrash is offline   Reply With Quote
Old 12-06-2018, 09:29 PM   #39
I have some old hospital grade receptacles as well. I've got a double duplex made up in a 4x4 w/ raised cover still going strong after twenty years of hard use
Sent from my SM-S327VL using Tapatalk
wmbettsjr is offline   Reply With Quote
Old 12-07-2018, 02:18 AM   #40
Watt Pusher
B-Nabs's Avatar
Rewards Points: 466
I like using (and reusing) HG receptacles for construction power. They're like Timex, they take a licking and keep on ticking!
CEC vs. NEC Receptacle Spacing rkstjarz Canadian Electrical Forum 35 02-28-2018 10:53 AM
IBEW Local 103 aptitude test Taco9215 General Electrical Discussion 4 02-25-2018 05:33 PM
adding a ground papaotis Residential Electrical Forum 71 05-22-2017 11:54 AM
I passed the Test for the License to be an Electrician Helper! JosiQElectrician General Electrical Discussion 30 12-04-2016 06:23 PM
Melted split receptacle tabs otif Residential Electrical Forum 21 10-26-2016 09:07 PM
