Roof conduit supports - Electrician Talk - Professional Electrical Contractors Forum
Old 11-30-2010, 03:58 PM   #1
Default Roof conduit supports
Who else besides Caddy sells the foam roof blocks with the strut inserted?
Cheers.
10492 is offline   Reply With Quote
Old 11-30-2010, 04:29 PM   #2
DHC
B-Line; Dura-Blok is thier product line for roof supports.
DHC is offline   Reply With Quote
Old 11-30-2010, 04:30 PM   #3
Rewards Points: 2,000
You could also take some wooden 4x4 blocks and ask the roofers to glue some vinyl to the bottom then put your own strut on them.
Old 11-30-2010, 05:26 PM   #4
Some one has a stick down version. You pull the plastic off the block, and stick it in place. I believe it's rated for all flat roofs, rubber and tar.
Old 11-30-2010, 05:29 PM   #5
Thanks, but they aren't they ones I've seen. They look expensive.
Old 11-30-2010, 06:54 PM   #6
Waaambulance Driver
Charlie K's Avatar
Rewards Points: 28
Check out Pipe Piers. www.gonefco.com go to page 205 or 206.
HTH.
Charlie
Charlie K is offline   Reply With Quote
Old 11-30-2010, 07:37 PM   #7
Rewards Points: 147
the dura-blok sleeper made by bline is are the best around in my opinion. they can handle alot of weight and look really professional.
Steve W is offline   Reply With Quote
Old 11-30-2010, 07:49 PM   #8
And made in canada Was my first job working on the assembly line making those suckers.
randas is offline   Reply With Quote
Old 12-01-2010, 10:44 AM   #9
There is no wieght. It's only one 3/4" pipe run around the perimeter to pick up building lights. The "maint man" for the apt complex put a weather tight bell box with romex connectors, and ran uf all over.
I might bid tar down PT 4x4 and one hole clamps.
They a cheap place to deal with.
Old 12-01-2010, 03:45 PM   #10
Jlarson's Avatar
Rewards Points: 4,124
I'd be tempted to use an idea I stole from 220/221, cut some PVC length wise into halves and tar those down and strap the run to that with one or 2 holes. That way there is no wood that will get all nasty and eventually rot out. Or use cinder blocks that works too.
Old 12-01-2010, 04:02 PM   #11
Bkessler's Avatar
Rewards Points: 2,002
I am not a big fan of the standard 4by4 with some glue slathard on it, but the prefab ones are expensive, on rooftops I usually put down a 4by4 every six feet or so with strut on the top.
When ls lunch?
Old 12-01-2010, 04:06 PM   #12
Jlarson's Avatar
I haven't seen any install here that was done with wood hold up over time. It gets sun baked and rots.
Old 12-01-2010, 04:09 PM   #13
Bkessler's Avatar
I bet, here to to a degree, although that hasn't stopped the company's I've worked for from having me do it, I've been forced to use 2" by 4"'s in the past.
When ls lunch?
This service has a roof! Magnettica Services and Service Equipment 18 11-28-2010 01:37 PM
Fixture supports TheBrushMan007 General Electrical Discussion 27 09-08-2010 12:08 AM
4"" conduit supports horsegoer General Electrical Discussion 46 09-06-2010 03:52 PM
Roof Conduits rchrisatcec General Electrical Discussion 2 03-17-2009 07:27 PM
GFI on Roof Top Losrod General Electrical Discussion 4 06-03-2008 05:52 PM
